Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > best intercooler for e92 N54 335i
      11-17-2011, 02:26 AM   #23
dlouie87
dlouie87's Avatar
31
Drives: 2007 AW 335i e90
someone got OWN'd
      11-17-2011, 07:07 AM   #24
nitehawk
nitehawk's Avatar
102
Drives: e92 335i 6MT
Originally Posted by Zeph View Post
AMS, hands down. I know this has been but I don't care. No other FMIC has better flow characteristics and keeps the weight down. HPF is comparable for flow, but then again you are adding more weight way up in front of the front axle. Nothing is as light as stock, but nothing works better and keeps the weight as low as possible as compared to AMS. If you think square end tanks and 2.25" connectors is "good flow" you need to consider your bias and IQ.
Zeph
ETS end tanks may not be cast, but I would hardly call them square. Also, the ETS reworks the restrictive stock piping, eliminating the 2.25" connectors. It also has 10 charge rows, not to mention it is 5 lbs lighter than AMS
Just saying
      11-17-2011, 07:53 AM   #25
secretsquirrel
secretsquirrel's Avatar
130
Drives: f80
Just be sure to get the yellow springs.
      11-17-2011, 08:03 AM   #26
Royal Flush
Royal Flush's Avatar
Drives: BMW
Zeph
      11-17-2011, 09:08 AM   #27
a7med606
a7med606's Avatar
Bahrain
41
Drives: 1 ///M + F80 M3
thanx alot guys
i dont care about a little weight increase
just go for a diet and you will make balance between the intercooler and ur weight jk
      11-19-2011, 08:51 AM   #28
Zeph
Drives: 2008 E92 335i 6MT SGM CR/BD
Apparently, without even mentioning nor referring to ETS, I have upset the ETS followers. No, the lightest FMIC isn't the best because the stock one is the lightest and it is probably the worst. My point was that some of the FMIC's offered are oversized and therefore excessively overweight (again, not ETS)... some hide 1/2 of the core behind the bumper hiding from any airflow. Some have square end tanks, some use the stock restrictive connections. Buying the "best" FMIC is going to depend on efficient use of your bumper's air inlet hole, as well as a quality core and great flow characteristics. Trying to limit pressure drop is another area of consideration. My point was that, in my opinion, the AMS is one of the best FMIC's for a 335i which does a combination of all of those things without really having a huge negative side. It works well, isn't too terribly heavy, flows well... not the "best" in one area but great all around for the stock turbos.
Try to not get so offended in a discussion, not everyone is going to agree on every product. HPF and ETS I like as well; I would probably want to "upgrade" to an HPF FMIC if I ran bigger turbo/s depending on how well the AMS one held up to high boost numbers. But for now, on stock turbo's, I don't feel like I need the larger/heavier HPF.
Zeph
      11-19-2011, 08:52 AM   #29
chrisw335i
chrisw335i's Avatar
13
Drives: 2007 BMW 335i Coupe
helix...imo
2007 335i Coupe 6AT - Sports Package - Premium Package - Procede V5 Rev 2.5 - Vishnu PWM - Vishnu DCI - Vanguard Exhaust - AR Downpipes - Helix FMIC - 19" Avant Garde M6 Reps - Michelin Pilot Super Sports - Bilstein PSS10 - M3 Suspension Bits - M3 Sway - M3 Strut Brace - GP Thunder -Forge DV -15% Tint - Aero Lip
      11-19-2011, 09:13 AM   #30
a7med606
a7med606's Avatar
Bahrain
41
i think the weight is not important that much
and in my opinion if it was heavier it would be better to make the front side of the car face down
so it will make down force while driving so it will make better air dynamic
what you guys said about that ????
      11-19-2011, 09:24 AM   #31
Zeph
Well, kinda off topic but I use KW coilovers and I lowered the front a tad more than the rear for that more aggressive stance. It helped a little to reduce understeer as well, that plus running a few psi higher in the rear tires. I wouldn't purposefully "add" weight outside of your wheelbase just for the purpose of making a height adjustment.
Zeph
      11-19-2011, 10:00 AM   #32
dicostal
dicostal's Avatar
Italy
55
Drives: 2007 335i
from the research I've done, i think the best intercoolers are for me.
1) Helix
2) Stett
3) ETS 7"
4) AMS
I do not know about others so i cant comment....
Helix is having a group by now, so I am all over it since this is one of my next upgrades
although all these talks of warranty being denied is making me have second thoughts to install these.
GIAC stage II|AA DP|AA Charge pipe and BOV|AFE S2 Intake|HELIX FMIC
      11-19-2011, 12:46 PM   #33
Daya
Daya's Avatar
Drives: e92 335 space gray/coral red
2007 E92 335  [9.66]
AMS - hands down, I was a test car for them and we did before/after dyno during install on stock tune and got 11 additional WHP. Gains and consistency are even better on higher boost applications
GIAC S2 | Brembo GT BBK 355/345 | BBS CH-R | Michelin Pilot Super Sports | AR Design: DP, S1 Oil Cooler, OCC | AMS FMIC | Bastuck Quad Exhaust | Borla MP | KW V1 | Stett: CAI, CP | Forge DV | P3 Boost Gauge | Arkym: Front Lip, Rear Quad Diffuser | Vorsteiner CSL Trunk | LUX H8 | ModMyNav | MFD M3 Sideskirts | BMW M-Tech Front/Rear Bumpers, Edition Grills
      11-19-2011, 01:06 PM   #34
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Drives: C6 Z06, 09 335i, 10 335xi
Originally Posted by 335coupe2007 View Post
no one ever really talks about the AA FMIC..... do they suck that bad?
Actually its a great intercooler, but there are other great intercoolers at a lower price point which dissuade many people.
I would just worry about the performance of the intercooler , budget, and the odds and ends of each different intercoler like install trimming connection and end tank and piping.
If you want to drop 6 lbs in the car go on a diet.
      11-19-2011, 01:23 PM   #35
Wedge1967
Drives: '07 e92 AT Sport Montego Blue
Good point Jeff. I actually installed a FMIC that weighted more because it balances out the fact that my fat ass isn't getting any lighter. So, if you're not worried about a few extra lbs and you want a good quality 7" FMIC that uses the stock C clips, check out Horse Power Freeks. I'm not saying it's the best, but the added weight will help in the corners on the track. LOL
      12-15-2011, 09:33 PM   #36
a7med606
a7med606's Avatar
Bahrain
41
i have checked the HPF intercooler
i think i will order it because its using the stock C clips
there is any other 7" FMIC that uses the stock C clips ???
and i want to know what is that black pipe or hose in the driver side that its connected
to the intercooler from down side ??
is it the charger pipe ??
      12-15-2011, 11:39 PM   #37
nitehawk
nitehawk's Avatar
102
Take a look at ETS ICs. They do not use the stock clips, but rather replace all the plastic piping - for good reason. It is very easy to revert back to stock if that is your concern. All you would require is to replace the worm clamp that you would be cutting off.
That other pipe you are referring to is the "elbow" running from the intercooler to the chargepipe. The ETS kit also replaces this plastic pipe with one that is stainless steel and without dimples.
      12-15-2011, 11:55 PM   #38
taylors335
taylors335's Avatar
Drives: Space Grey 08 335i
2008 335i  [7.00]
Originally Posted by MyE92 View Post
This one.
i just installed that on my e92 , had great reviews and made pretty good power too , next is the ceramic muffler bearings and then synthetic blinker fluid !
      12-16-2011, 02:55 AM   #39
EJ_3
EJ_3's Avatar
Drives: e92 335i, e34 525i & e60 530i
2007 BMW 335i  [8.34]
2016 Ram 1500 Sport  [8.00]
1994 BMW 525i  [10.00]
2007 BMW 530i  [8.66]
Evolution Racewerks
ETS
Helix
AMS
AA
Big Tom
You'll win with either one. Until they do a road/track comparison test, there's no real way to determine which one is 'the best.' Yeah, this company claims this and that one says that, and oh look, here's a pretty chart... I just don't buy into that crap. And no offense, some members are bias, so I dont buy theirs neither. They all do what they're designed to do, reduce heat soak, lower IAT, provide a decent gain, and have lower pressure drop than stock. Just pick one and enjoy.
      12-16-2011, 04:47 AM   #40
**335i**
**335i**'s Avatar
Switzerland
184
Drives: TOYOTA & 2008 E92 335i 6MT
2008 335i  [9.00]
for money Big Tom and performance
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
      12-16-2011, 07:14 AM   #41
Bash
Bash's Avatar
Drives: E92-335i
OP- you live in bahrain where its scorching hot most of the year, but do you have a tune?
I would say get the ETS 7", it will support any boost on stock turbos, and will handle upgraded turbos too, plus you need the extra cooling efficiency in that country.
This is coming from someone with NO FMIC at all, tuned at 15psi boost in a hot climate country too Lebanon. But from the countless threads about these questions well ive memorized them.
COBB S2+ - Mr.5 CAI, Catless DP, Catless MP, AMS FMIC.
      12-16-2011, 07:19 AM   #42
bmwm3redblack
bmwm3redblack's Avatar
59
Drives: BMW ///M3 E46, BMW E92 335Xi
How much is big tom intercooler and where can i get it????
      12-16-2011, 07:33 AM   #43
Bash
Bash's Avatar
Drives: E92-335i
..and this is the guy who told me to go to the amg forums...
Search big tom FMIC and you'll know
      12-16-2011, 08:39 AM   #44
a7med606
a7med606's Avatar
Bahrain
41
i made a search about the ETS 7'' intercooler but i didn't find any pictures or discussion
and what will bi different between the ETS and HPF if they are both 7 inch
will the elbow and pipes makes a difference ???
ets, fmic, intercooler
