TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 335i, coolant leak from rear turbo. What should I do? Where should I go?
      03-02-2014, 04:33 AM   #1
Debacle of Mass Eruption.
Debacle of Mass Eruption.'s Avatar
14
Drives: 2007 BMW 335i e90
Unhappy 335i, coolant leak from rear turbo. What should I do? Where should I go?
My e90 335i, that I just bought last november, started leaking coolant about a month ago. The light came on, I put coolant as directed. It came on again a week later, followed by vapor coming from under the hood. *SCARY SHIT*
Anyway, I went to a local shop in Mountain View and they told me It might be a head gasket leak. *SCARIER SHIT* They told me they weren't sure enough, so I should take to a "little shop down the road" that specialized in these types of cars, Dinan. The nice folks at Dinan checked my car and said my car had no coolant pressure.
After a full day with my car they told me the rear turbo had a leak, 2 water feed pipes and a return pipe. No big deal right? WRONG. The whole engine and tranny had to be pulled to change those pipes. (The price made my face pale and my stomach to ache.) I worked 12-hour days to buy this car and still do, I'm nowhere near raising the money they want.
Does anyone have any suggestions on what to do? Does anyone know any shops in the Bay Area that would give me a fair price for this repair?
Hope to hear from ANYONE on this matter, I can't drive my project car to work much longer...
2007 BMW 335i, My commuter car
2016 Jeep Cherokee Trailhawk, the other car
Driving Fast and Unsafe Around The Bay Area.
      03-02-2014, 07:25 AM   #2
BlackBB6
Drives: E92 335i 6MT
The initial price of the car isn't even that bad, what will get you is the maintenance and repair costs. Unless you start doing the repair work yourself I would look at another car. I would assume Dinan has a much higher labor rate than most shops, so that doesn't help the situation. Someone from the bay area will chime in with a better shop, after you give your first born to Dinan I would start there.
      03-02-2014, 09:09 AM   #3
Miller335
291
Drives: 2007 E92
You need to find a trusted Indy in your area and explain the situation and see if they have any ideas on the matter, maybe they know of a different way to deal with the problem.
If you do have to spend the few grand to pull motor I recommend you take that opportunity to have them replace all the orings/gaskets for all oil/coolent lines for both turbos.
      03-02-2014, 09:21 AM   #4
135Pats
135Pats's Avatar
Drives: A few BMWs
FFTEC is in your neck of the woods, give them a shout.
F30 N55 XDrive EBII
      03-02-2014, 09:47 AM   #5
Ingeniator
Ingeniator's Avatar
34
Drives: 07 335XI(90) 09 135I(82)
So are they the coolant supply and return lines to the turbos? See the RealOEM link. I wouldn't think you would have to pull anything beyond the normal stuff to get at the turbos. Even if it was the water pump you don't need to pull the motor. Dinan repair bills look like their performance part bills. A lot of dollars and not much sense.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system
      03-02-2014, 10:13 AM   #6
135Pats
135Pats's Avatar
Drives: A few BMWs
Yea I don't get why you'd need to pull the motor for that...Haven't done it myself but just look at the parts involved. Still going to take a long time, but nowhere near motor-out-of-car hours.
OP go anywhere but DINAN unless your goal is to hemorrhage money.
F30 N55 XDrive EBII
      03-02-2014, 11:34 AM   #7
MDORPHN
291
Drives: AW 1M
Don't know whether it's convenient to you but Bill Arnold (Bill Arnold BMW Repair) in San Rafael has an excellent reputation.
Neil
      03-02-2014, 01:29 PM   #8
sammy_0559
sammy_0559's Avatar
Drives: 335i
2008 E93 335i  [3.66]
thats BS, check the Breather line going from the expansion tank to the radiator hose from across the top of the fan shroud. usually gets brittle and breaks and causes the coolant to leak everywhere and evaporate when engine is warm.
From my experience if the turbo coolant lines are in they are IN and not going anywhere. Find a better shop or figure it out yourself.
      03-02-2014, 09:04 PM   #9
14
Thumbs up Thanks to everyone for responding
The price is what really has me feeling bummed out every time I see my car and can't drive it. (almost $3,000 USD) FML!
This is Dinan's list of what needs to be done:
  • o-ring x8, $6 each
  • waterpipe, return, $85
  • waterpipe, feed (901), $85
  • waterpipe, feed (899), $85
  • gasket ring x6, $7 each
and for some reason, i'm being charged for a $10 can of break cleaner
i can give exact part #s if anyone wants to know
thanks
ps,
Anyone hear anything about Palo Alto Bimmer, Sonic MS, BavPros, German Motor Specialist, or Bavarian MotorSport? I know those shops are in my area, just want to if anyone' heard good things...
Last edited by Debacle of Mass Eruption.; 03-02-2014 at 09:36 PM.. Reason: added more text
      03-02-2014, 09:20 PM   #10
Ingeniator
Ingeniator's Avatar
34
thanks
Yeah that labour rate must be crazy. Those are the turbo supply return pipes.
From Real OEM
  • 01 Pipe, supply, cooling for turbocharger ZYL. 1-3 1 11537558899 $71.68
  • 02 Pipe, return, cooling for turbocharger ZYL. 1-3 1 11537558900 $71.68
  • 03 Pipe, supply, cooling for turbocharger ZYL. 4-6 1 11537558901 $71.68
  • 04 Pipe, return, cooling for turbocharger ZYL. 4-6 1 11537558902 $71.68
  • 05 O-ring 8 11427558936 $1.73
  • 06 ISA screw M6X16 4 07129904588 $0.96
  • 07 ISA screw M6X12 2 07129903805 $2.14
I'm assuming the other 6 o-rings are for the intake manifold but agin not sure why they need to take that off. Maybe someone who has done a turbo swap can chime in on how easy these coolant lines are to get to. Also if they are only changing two hoses they should only need 4 of the 8 o-rings.
EDIT: I see now they call them gasket rings so they must be on the exhaust side. That means they want to pull the turbos. Not sure what they are doing but I'd go somewhere else and get a quote with the above info.
      03-02-2014, 09:47 PM   #11
14
From Real OEM
thanks for the advice
I can probably pay a grand if need be, but 3k is just too much for a car i'm still paying for. Dinan also want to charge me $120 to replace each DRL bulb. I'm new to Bimmers, I just hope I knew another n54 owner in my area to help me decifer all this. I might need to see if there are any meets in my area or something
      03-05-2014, 05:27 AM   #12
14
Bump
(for more help)
      03-05-2014, 07:34 AM   #13
14
Bump
(for more help)
      03-05-2014, 08:06 AM   #14
BlackBB6
Try the California subforum: http://www.e90post.com/forums/forumdisplay.php?f=43
      03-08-2014, 12:06 AM   #15
14
Question still Looking for Bay area shops
Anyone know any spots in the Silicon Valley area?
355i, bay area, dinan, n54, repair
