      03-18-2014, 08:40 AM   #1
ryan.ferguson
Drives: 2013 335is Coupe DCT
Low Pressure Fuel Sensor Replacement While Walnut Blasting
I'm getting the 29F3 code from my car, and I know that doesn't necessarily mean that it needs to be replaced right away but I'm getting my car walnut blasted in a month or so and was wondering if I should just replace the sensor while getting it done sense most of the major parts will be out of the way? ECS has a replacement sensor for $84 dollars so it doesn't seem to be too bad. Thanks for all your help!
Current: 2013 335is Coupe DCT Black/Red
Previous: 2008 135i Coupe Montego Blue
"Speed never killed anyone its very important to get that straight, Speed has never killed a soul. Suddenly becoming stationary thats what gets people." - Jeremy Clarkson
      03-18-2014, 09:08 AM   #2
Ginger_Extract
California-bound
Ginger_Extract's Avatar
Drives: BMW 135i
Do you know if it's the sensor, or is it actually the fuel pump dying?
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18
https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3
      03-18-2014, 09:26 AM   #3
ryan.ferguson
I had the fuel pump replaced about 15,000 miles ago with the most updated version so I would assume its not the fuel pump
      03-18-2014, 04:09 PM   #4
135Pats
135Pats's Avatar
Drives: A few BMWs
Yes, replace it. Very easy to do once the mani is off.
P29F3 is a failing LPFP sensor, nothing else i've heard of causes it.
F30 N55 XDrive EBII
      03-18-2014, 04:37 PM   #5
Dackelone
European Editor
Dackelone's Avatar
Germany
10523
Drives: N54 e82
This sensor you refer too is the one of the feed line to the HPFP right? If so, yea... I would replace it while the intake manifold is off. I'vee lots of guys say this sensor goes bad. Most dealers even seem to want to do a COD(ie you pay!) repair while replacing the HPFP under the extended warranty('08's thru '10's N54's).
Has your HPFP been replaced before? Maybe this sensor has been replaced and can be replaced again? (under a parts warranty). IF it was replaced as part of a HPFP, BMW would foot the entire bill. ~$84 doesn't sound bad for the sensor though. I would just replace it yourself or have the shop that is doing your walnut blasting.
G.L.
Dack
      03-19-2014, 07:53 AM   #6
ryan.ferguson
Thank you guys! Yeah I had the HPFP replaced about 15,000 miles ago, but the replacement of the sensor was not on the work order. I'll talk to my service guy about refunding it but in all honesty a $84 sensor is something I don't mind footing myself.
      03-19-2014, 10:39 AM   #7
E82MSport
E82MSport's Avatar
Drives: 08' Crimson 135i
I replaced mine at the same time the valve cleaning service was performed.
29f3, lpfs, n54
Search this Thread:
