12-01-2014, 08:53 PM | #23 | |
Rep 252
That was kind of my thought process getting into this whole mess, now that it's been to the dealership 4 times for unfixed CEL's, isn't this history available for a future purchaser? |
12-01-2014, 08:58 PM | #24 |
Rep 1,961
Let me ask you this; Have you driven another car to see if the same thing happens? If you have and it didn't, then you have a better chance than if you have and it did. If the same thing happened in another car they can say its working as intended to keep emissions in check.
As far as future purchasers, dealerships are not supposed to give out the service history to anybody except the owner of the car. It says so right in the software and they have to agree to it to even get the history. My friend went through hell trying to get the service history of the X5M he bought. |
12-01-2014, 09:05 PM | #25 | |
Rep 252
Good insight on the service history, I appreciate it. |
12-11-2014, 09:54 PM | #26 |
Rep 252
Well, small update- Service manager claims that he spoke with BMW and a software fix is due in March for this issue.
In the meantime, he said we can replace the mppk airbox with the stock one and that this should fix the issue. Anybody buy this? |
12-11-2014, 10:00 PM | #27 |
Rep 1,961
How can the airbox be the issue, when its basically stock with a hole cut in the front? If that was the case, everybody with aftermarket intakes and the MPPK would have the same problem. I don't buy it for one second.
12-11-2014, 10:01 PM | #28 | |
Rep 252
Think about it this way, they're going to supposedly fix a software issue with hardware? Confusing. |
12-12-2014, 07:27 AM | #29 |
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
It takes all of 20 minutes to change out the lower airbox back to the stock one. Why not try that and see if it does fix the problem? That hole in the airbox allows slightly more air into the intake, supposedly to increase the intake sound, but it could have an effect on what the MAF sends to the ECU.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
12-12-2014, 07:29 AM | #30 | |
Rep 252
Totally agree, problem is that I don't have my stock airbox. My MPPK was port installed so I never got it. I'm waiting on a call back from the dealer, going to make them foot the bill on this one.
12-12-2014, 07:30 AM | #31 |
Rep 6,990
I still have mine (installed it myself, dealer installed the software). Where are you located? Mine is just taking up space on a shelf in my garage. Or, you could see if the dealer would locate one for you or maybe someone in your area has theirs. Last, and probably least desirable would be to plug that hole with duct tape or some other method.
12-12-2014, 07:31 AM | #32 |
Rep 252
MN. Thanks for the offer, I'm fairly confident that the dealership will have no issue acquiring and installing a new one.
12-12-2014, 07:42 AM | #33 |
Rep 6,990
Yeah, I'd think so too...I know mine would. One other thing...you're in a fairly cold climate area. I wonder if that might be a contributing factor?
12-12-2014, 07:44 AM | #34 | |
Rep 252
I'll keep the thread updated as to what happens, thanks! |
12-12-2014, 07:56 AM | #35 |
Rep 6,990
Ok - we'll all be listening in. Meantime, maybe the duct tape thing would be worth trying, just to prove a point? Looking at the airbox in mine, there is a sensor in the upper half, but nothing on the bottom, so it's got to have something to do with airflow - unless that opening has some sort of "harmonic" effect, causing the sensor to send a fault signal.
12-12-2014, 08:37 PM | #36 |
Too much is never enough
655
Rep 3,079
Now I remember why I don't come around here any more. Thanks for the reminder. Please sell your BMW and buy something else. This is EASILY the most ridiculous "lemon" claim I've ever heard.
By the way, suddenly throwing a car that's been cruising at speed into neutral will thermally shock the cats, and potentially skew O2 readings on a motor as lean as these. It's generally not a good thing to do and there's zero reason to ever do it. |
12-12-2014, 08:40 PM | #37 | |
Rep 252
12-12-2014, 08:50 PM | #38 | |
655
Rep 3,079
What you're doing is suddenly and rapidly shocking the system which is irrational and definitely something that any engineer would ever anticipate during the development cycle. I might give you the benefit of the doubt if you did't pull the lemon card. That's assinine. This in no way affects the operation, performance, or safety of the car. You're just being a Mr. Whiney Pants. Sorry if you're offended. But you're abusing a system that was designed to protect consumers from legitimate defects and irresponsible manufacturers/dealers. Again, please just sell your BMW and move on. Have a nice day. |
12-12-2014, 09:15 PM | #39 | |
Rep 3,403
12-12-2014, 10:28 PM | #41 | ||
Rep 252
12-12-2014, 10:31 PM | #42 | |
Rep 252
03-26-2015, 01:24 PM | #43 |
Rep 4,323
I just got this.
MPPK. 2012 build. So goofy....
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
03-26-2015, 01:41 PM | #44 |
Rep 252
The issue is pretty strange, I will admit this.
To give a update, my dealer pulled the MPPK airbox and put a new stock one in, and I haven't been able to reproduce it yet. As of now, we're still waiting on the software update thats supposedly due out soon. Once thats out, we'll update and replace the airbox w/ the MPPK one. Seems janky as h*ll, but I guess thats the way the cookie crumbles. |
100201, 335, cel |
