Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 335i Turbos - Stage 2 now installed and reviewed!!
      04-15-2010, 11:38 AM   #375
midlife
ocasionally in crisis
midlife's Avatar
52
Drives: '08 335i cabrio
Originally Posted by enrita View Post
In my opinion an upgraded Radiator for the water temps is really needed. i will soon get a Beta version from a renowned company. Going to be very interesting and definetely help keep the turbos on the cool side.
keep us posted on this please.
... i think VK is working on a radiator upgrade also. i hope VK use better cores this time though LOL (a la e92fan)
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs /
M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 /
      04-15-2010, 11:42 AM   #376
midlife
midlife's Avatar
52
Originally Posted by marcel b View Post
thanks Tony, already had contact and they indeed said "easy, no worries, we have this or can order it if needed"
Really looking forward to see the impact of all the mods and to be able to go flat out without having to worry about 140 degrees or more oiltemps.
marcel,
are you changing out your VK OC core as well and using a serab core?
... do you have the part number ??
thanks
      04-15-2010, 11:49 AM   #377
marcel b
marcel b's Avatar
132
Drives: F31 340i
Originally Posted by midlife View Post
marcel,
thanks
yup, my shop received the Setrab core which the will put in the VK bracket. I wanted the best possible cooler and was not willing to take risks. Setrab IMO is on top regarding quality and performance.
As Tony arranged this core for me, I do not have any number unfortunately. Maybe Tony has the invoice lying around with the number on
      04-15-2010, 11:52 AM   #378
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
marcel,
thanks
I supplied Marcel with the Setrab core
I'll get you the STD part number...
      04-15-2010, 01:16 PM   #379
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
263
Drives: Audi R8 LMX, BMW M550i xDrive
2009 335i  [8.90]
Originally Posted by E92Fan View Post
I'm working on exactly the same thing! Should have the radiator for testing on Monday
That sounds very interesting - it's an option I've been interested for a long time, and as VK Motorwerks doesn't seem to come around with this, I'm all ears!
BTT on the turbo upgrade: I received a lot of questions on the German boards (where I posted the info from TD about the upgrades) about the ability of the HPFP to cope with the upgraded turbos. Do you believe with pushing more than 500hp we're still within limits of the stock HPFP? Considering there's no alternative available presently...
Another question: As we're entering a territory of around 200hp more than stock 335i, do you think that other pistons or piston rods are necessary? I seem to remember you installed the low compression Mahle pistons - do you think that is essential? My garage also thought that with pushing the engine to around 500hp better piston rods should be taken into consideration.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
      04-15-2010, 04:29 PM   #380
midlife
midlife's Avatar
52
Thanks - will await your part number.
Note that the part number of you competition core would not hurt either.
      04-21-2010, 09:37 AM   #381
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
thanks... i will add a second OC unit soon.
and JP: do not push your luck man ! you have bigger turbos and not even the stock OC
oil temps aren't any higher so far, but i'll be keeping an eye on it
      06-17-2010, 03:29 PM   #382
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Awesome project bro!
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      02-28-2015, 07:48 AM   #383
Cerbera9
9
Drives: E92 335i 2007
Are there any updates or dyno results now?
      02-28-2015, 02:26 PM   #384
Kerr
Scotland
112
Drives: BMW M235I
A 6 year old thread and the OP hasn't posted in 3 years, I'm guessing this is long gone.
boost, compressor, overhaul, turbine, turbo, turbo upgrade, turbocharger, upgrade
