Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 335i Turbos - Stage 2 now installed and reviewed!!
      11-05-2009, 09:46 AM   #45
ar design
ar design's Avatar
Drives: 04 M3
Lookin good Tony!
-Critter
      11-05-2009, 09:55 AM   #46
Sniz
Sniz's Avatar
654
Drives: e92 335 - gone // e36 M3 turbo
nice stuff!
looking forward to your impressions.
will you get this dyno'd again for comparison?
      11-05-2009, 09:58 AM   #47
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
Originally Posted by Sniz View Post
nice stuff!
The car has to be remapped again to take into account the new turbo performance so it'll be on the dyno again. I don't know how hard I want to push the car - theoretically I should be able to get over 500bhp quite easily, but I'm not really keen on the idea as having 470bhp with room to spare is more in keeping with the idea of durability!
      11-05-2009, 10:04 AM   #48
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
More pictures -
TD have machined completely new wastegate bushes from stainless billet to replace the worn bushes. These will be much more durable!
New wastegate bush machined from stainless billet
Name:  New wastegate bush, machined from stainless billett - small.jpg
New wastegate bush installed
Name:  New wastegate bush from the other side - small.jpg
      11-05-2009, 10:04 AM   #49
creepy coupe
creepy coupe's Avatar
1867
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
Jeez, you must have ragged that poor car everywhere tone
      11-05-2009, 10:11 AM   #50
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
Not really... I think it's the 150+ laps of the 'Ring that's done it
Still, someone's got to find out what the factory parts can handle, right?!
      11-05-2009, 10:11 AM   #51
marconi118
Drives: 06/07 e93 335i
TD are really doing a great job! new wastegate rod bushing, wastegate seat etc!!!
BMW should have done al this to solve the turbo rattling problem!!!!
Inpatient to have more pictures about the wastegate seat and the flap...
      11-05-2009, 10:13 AM   #52
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
BMW can't do anything like this, because it requires a complete redesign of the turbo by Mitsubishi. The amount of work gone into it is just too costly for an OEM fix.
      11-05-2009, 10:18 AM   #53
joec500
Drives: it has 4 wheels
I might just buy a set of used turbos and send these over to have them re-built when my turbos go kaboom!
      11-05-2009, 10:20 AM   #54
marconi118
strange thet mitsu designed such a crap turbo, normally they are doing well
why TD isn't installing a bigger exhaust turbine wheel? Only bend the OEM fins?
Really hope the spooling time won't be increased by the mod... pulling hard from 1500rpm till 7K would be insane
      11-05-2009, 10:44 AM   #55
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
You're right, only the compressor wheel has been enlarged and not the exhaust turbine wheel. The exhaust turbine hasn't been enlarged because it's really hard to get a bigger exhaust wheel into the housing for a few reasons. Firstly the size of the shaft, journal bearings and thrust bearings would all be different so as well as sourcing a new shaft you would need to find something that has the same outside-diameter journal bearings. This would be like searching for a needle in a hay stack. The second would be trying to re-profile the turbine housing would be very difficult especially for a one off. It would be possible in batches but then you come back to the first problem of finding the right size parts!
And just to clarify one point - the OEM blades aren't "bent" - Turbo Dynamics use a cylindrical grinder to remove literally a very tiny slice of material
      11-05-2009, 10:53 AM   #56
marconi118
WOW this is really High tech processing.
Hopefully they keep all the tools for future use, I think if everything goes well for you I will go to them with my spare turbo set
Do they specify the extra performance of the turbos cfm psi and spool time?
Or is it a surprise when you will test it?
      11-05-2009, 11:09 AM   #57
ianthegreat
60
Drives: n54
excellent, good luck
      11-05-2009, 11:14 AM   #58
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
263
Drives: Audi R8 LMX, BMW M550i xDrive
2009 335i  [8.90]
Looks all really neat and professional. Inspires confidence and makes me wish to have that, too!
One question: Can you drive the car with the upgraded turbos without the remap? Or do you believe that will trigger a limp mode? I assume you will have to drive the car to DMS for the remap, don't you?
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
      11-05-2009, 11:14 AM   #59
marconi118
what about the ASR turbine? only intoxicating info?
Name:  ASR Turbine Wheels - small.jpg
      11-05-2009, 11:35 AM   #60
Alpina_B3_Lux
263
2009 335i  [8.90]
ASR is using Garrett ball bearing turbos and have not upgraded the Mitsubishi ones like Turbo Dynamics do. But there's no detailed info about what they have done, at least so far and to my knowledge.
Alpina_B3_Lux
      11-05-2009, 11:44 AM   #61
marconi118
from the picture found on this forum it seems the housings are the same as OEM
indeed ball bearing would be better for the TD upgrade?!
      11-05-2009, 11:45 AM   #62
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
From Turbo Dynamics -
"Looking at the ASR turbine wheel, they have changed the CHRA (core assembly) for a Garrett CHRA which not only means a lot of machining and probably a welded adaptor ring on the turbine housing. It also means that you would have to change the oil and water lines which I can imagine isn't easy!"
I'm not a turbo expert by any stretch in terms of the design and components, so I'll leave it at that for now!
      11-05-2009, 11:55 AM   #63
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
Originally Posted by Nick.CBR View Post
This is awesome info. I love the good images of the progress. I really believe this level of attn to detail will win customers down the road. It's great to see the quality of their work.
On another note - it will be interesting to see what the next few years brings with regard to the mitsu turbos used on the N54 engine. I wonder if BMW reads threads like these - if I were an engineer, I would be very very interested in long term wear on a single engine that has that many laps 'round the 'ring. It sounds like the motor is ok though and it's more an issue with the turbo's?
Thanks!
Nick
The engine itself on my car is in pristine condition, and the head is totally clean too. The main issue is the degradation of the turbos as you have already seen. And yes, BMW UK are well aware of the condition of my car
      11-05-2009, 12:00 PM   #64
Yahoo
Drives: 335i e91 LCI msport
Alpina_B3_Lux
I have read a thread stating that ASR have driven their car using the standard map on their upgraded turbos completely limp mode free - this was prior to Vishnu's official involvement I believe.
They apparently made some gains over stock, but clearly no where near the potential of the upgrade.
      11-05-2009, 12:07 PM   #65
MIKEYBMW1
GT3
MIKEYBMW1's Avatar
England
47
Drives: PORSCHE GT3
Looks very impressive Tony, car will fly with all that power ,my old 335i was very rapid and that was with 370bhp God knows what 470bhp will be like from the 335i ,absolute rocket ship I assume.
PORSCHE GT3
      11-05-2009, 12:10 PM   #66
Ilma
184
Drives: 2008 135i
Originally Posted by rjm8282 View Post
Great write up, sounds really good.
I have just had my software upgraded and wastegates aligned, but I have noticed a lot of smoke coming from the exhaust on a standstill. I start the car in the morning, leave it running for 10 mins and still when I go into my boot I have to walk through a cloud of smoke. I expect some smoke due to the cold, but is this the norm?? Mines a early 2006 335 model.
I had myturbos replaced a few months ago on my 2008 135i so they are pretty new......and with the colder weather, I too have recently noticed what i consider to be an above average amount of smoke when the car is at idle.
However, as already suggested....the smoke has absolutely no odour to it at all and subsides once you rev the engine.
Looks like condensation to me but there is so much of it.....I can only assume that the stock pre-catalytics are doing a really good job of converting the exhaust gases to H2O.
boost, compressor, overhaul, turbine, turbo, turbo upgrade, turbocharger, upgrade
