R1 Concepts | INTRODUCING R1 CONCEPTS FORGED SERIES BIG BRAKE KIT!
12-15-2014, 08:20 PM | #1 |
Rep 1,677
R1 Forged Series Big Brake Kit! "Maximizing brake performance to the highest level! R1 Forged Series Big Brake Kit is made for those seeking maximum performance in braking. R1 Forged Series Brake Rotors are manufactured with High Carbon (more Carbon, Chromium, and Molybdenum), the R1 Forged Series Brake Rotors offers increased braking performance and strength. A center split core castinf provides greater stability. Black Electro Coating protects against rust while extended rotor life. Mill balancing and double disc grinding reduces thickness variations for smoother stopping, minimal vibration and improved break-in. *AVAILABLE IN DRILLED ONLY, SLOTTED ONLY, OR DRILLED & SLOTTED Calipers
Rotor Hat
Rotors Sizes
Pistons
*IF YOU HAVE ANY QUESTIONS OR ARE INTERESTED IN PURCHASING, PLEASE PM OR EMAIL KEVIN@R1CONCEPTS.COM* Last edited by r1concepts; 02-19-2015 at 01:20 PM.. |
12-16-2014, 04:09 AM | #2 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
What are the piston sizes for a front kit for 335i assuming 356mm rotor?
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
12-16-2014, 10:59 AM | #3 | |
Rep 5,062
Drives: Black e92 335i
Let's see if I'm close.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
12-16-2014, 01:21 PM | #4 | |
Rep 1,677
-330mm come in either 4 or 6 piston -345mm in 6 piston only -356mm come in 6 or 8 piston -380mm and higher only come in 8 piston Piston size for a 356mm rotor is: 32.36,38. Last edited by r1concepts; 12-16-2014 at 07:26 PM.. Reason: read post wrong |
12-16-2014, 06:53 PM | #5 | |
Rep 3,251
but seriously, aluminum piston??? aluminum is like the probably the worst material for a brake piston due to rapid heat transfer from the pads and straight to your brake fluid... at the very least it should be stainless steel as standard. hell, many bbk calipers are starting to use titanium and ceramic pistons for this very reason. also, sup with the piston arrangement on the caliper shown in your picture? looks like an 8 pot design to me, but why are the two smaller pistons located in the middle? smaller pistons are typically located at the end of the caliper's rotating direction, to reduce the applied pad pressure at those region in order to eliminate any tapered pad wear that might encounter at higher temperature. make no sense to have the smaller pistons in the middle though... looks like whoever designed this is just trying to squeeze in as many piston as he/she can just for the bragging rights... but anyway, guess the profit margins for BBK are so high these days, everyone is trying to jump into the band wagon.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
12-16-2014, 08:28 PM | #6 | |
Rep 1,677
Attached to this post is the picture of how the inside of the caliper looks like. The reason why we use aluminum is to make it more affordable for the everyday street car. With the aluminum piston and the aluminum caliper when paired up, it is less likely to corrode. When aluminum and steel is paired up, it is more likely to corrode especially in wet saline conditions. However, the customer does have the option to upgrade the pistons to stainless steel at an additional cost and also to knockback springs as well. |
12-16-2014, 08:39 PM | #7 | |
1121
Rep 5,396
You Sir are spot on with the questions! Aluminum pistons are lighter, but they do indeed absorb a lot of heat. Stoptech offers piston noses made out of titanium for their ST60, ST40 and Porsche GT3 calipers to reduce heat transfer: Another reason why one puts different size pistons on a caliper is for better brake modulation. Fluid mechanics dictate that given the same pressure, a smaller piston will travel faster and further than a larger piston BUT with a smaller force. This means, small pistons are great for quick taps on the brakes to scrub of just a little bit of speed. Easy on, easy off. The big pistons are for when you brake hard. They move slower, but with greater force thus squeezing the pad tighter. Generally, progressive calipers are designed in such a way that the smaller pistons fire up first before the big ones as the fluid travels in the brake line. So naturally, you'd want them to be grouped together and right next to where the brake line hooks into the caliper, not in the middle. EDIT: Even TarOX's top of the line B400-GT16 caliper with ... you guessed it... 16 pistons has the pistons grouped by size.
12-16-2014, 09:07 PM | #8 |
1121
Rep 5,396
So I did some math here...
R1 concepts 6 piston with 32mm, 36mm and 38mm pistons have total piston area of 212mm per caliper. Stoptech ST60 for our cars has 30, 30 and 36mm pistons for total piston area of 192mm per caliper OEM Calipers have a single 59 mm piston, but because the caliper is floating, this makes it 118 mm total area. I wonder how would the brake balance be affected?
12-16-2014, 09:26 PM | #9 |
1121
Rep 5,396
Another question: How is it that the calipers say "Forged Series" when it definitely looks like a cast piece?
12-17-2014, 08:40 AM | #10 |
Rep 3,251
12-17-2014, 09:14 AM | #11 | |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
OEM piston area = ((59mm/2)^2)*3.14= 2,734mm^2. STOPTech piston area = (((30mm/2)^2)*3.14) + (((30mm/2)^2)*3.14) + (((36mm/2)^2)*3.14) = 2,432mm^2. R1 Concept piston area = (((32mm/2)^2)*3.14) + (((36mm/2)^2)*3.14) + (((38mm/2)^2)*3.14) = 2,956mm^2. (By the way you only calculate per pushing side, not both, so you do NOT multiply by 2 for fixed calipers) Draw your own conclusions. Based on the above calculations, the STOPTech calipers would make the brake pedal stiffer, while shifting 10% of brake bias toward the rear. R1 Concept kit would make the pedal softer, while shifting brake bias further front.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
12-17-2014, 06:22 PM | #12 |
1121
Rep 5,396
Duuh. I totally zonked out on the math. You are correct. I was doing math with radius not area.
12-18-2014, 06:11 PM | #13 |
Rep 1,677
All of our BBK calipers are from forged aluminum. Then it is CNC to precision specs. For our anodized calipers, we first sand blast them before anodizing them. Therefore, the texture you see there are from sandblasting, not casting. Which is also also a unique look that we offer with our anodized calipers.
02-13-2015, 03:35 PM | #16 | |
Proud Father of a Univ. of Mich. Chemical Engineer
193
Rep 643
Thanks
Current: '16 F82 M4, Avus Blue, DCT, BavSound, Winters-19" 437s, Summers-19” BBS FI-Rs Past: '13 E92 M3-Jet Black, '12 E92 335is-Space Gray, '06 E90 330i-Jet Black, '99 E46-328i-Green, '96 E36 328is-Jet Black
02-15-2015, 03:47 PM | #18 |
193
Rep 643
Any reviews on these?
I am really interested in these, they seem to fit my needs... Ie, a less expensive alternative to Stoptechs. However, I first need to see pics of the anodized calipers in red and blue (r1concepts website needs updated to show pics of all their products), and also research what the industry has to say about these new BBKs before I place my order. By my calculations, I estimate an $800 savings compared to StopTechs.
02-16-2015, 04:48 PM | #19 |
Rep 1,677
We don't have set prices listed because pricing can change anytime since we just released this BBK about a few months ago during SEMA. Also there are different options to choose within this kit such as going with the 4, 6, or 8 piston as well as upgrading from a fixed 2 piece to a floating 2 piece. I'll go ahead and send you over an PM.
02-16-2015, 05:24 PM | #20 | |
Rep 1,677
We did sponsor a Formula Drift driver by the name of Ryan Kado and had our R1 Forged Series BBK on his 350Z. He did give us a review and the kit worked out great for him on the track! However, he was eliminated from the competition early. Here's a quick video of the kit on his 350Z: |
02-16-2015, 08:45 PM | #21 | |
193
Rep 643
This video is great, I saw it this weekend when I was scouring the web and youtube trying to catch a even the slightest glimpse of your anodized calipers...to no avail. All your YouTube marketing videos, SEMA boothes etc., are all really cool videos with lots of hot chicks and sweet rides, but surprisingly none of these videos show your line-up of calipers. There must be some where we can go to see your entire line up? Please advise.
02-17-2015, 08:14 PM | #22 | |
Rep 1,677
Keep in mind, we haven't officially launched this R1 Forged Series BBK to the all of our customers worldwide just yet. I was given the opportunity to to post this here on E90 post ahead of time so the forum members have a fist chance at purchasing the kit first. You can say this is a "soft" launch for our BBK. |
bbk, big brake kit, r1 concepts, r1concepts, stoptech |
