330D E90 Cutting out whilst driving
06-06-2010, 03:24 PM | #1 |
Rep 34
I'm hoping someone can shed some light onto this for me.
I have a 330D, 55 plate which over the past 3 days has cut out whilst traveling between 60 - 80mph. I just seem to loose all acceleration, have to wack on the hazards and drift hoping nothing is going to whack me!. Once the engine is off and key removed it starts perfectly but then feels lumpy, sluggish and unresponsive. Like it's suddenly having to think about what its doing and is suddenly carrying more weight if you know what I mean. The first time it happened within minutes of each other, yesterday fine and car felt better then again today. Having to noticeably put my foot down harder to accelerate from roundabouts etc and seem to have lost the "head jolt" when putting foot to the floor. Unfortunately, i was so focused on trying to stop safely that I failed to notice what rev counter was doing or if anything strange or any light appeared during the failure but nothing that caught my eye. Any ideas? |
06-07-2010, 06:42 PM | #2 |
Rep 436
My guess is water contamination of the fuel. Change fuel filter, dump fuel if you can and run a fresh tank of fuel, you might even consider running some B5 if you can find it....
HS |
06-07-2010, 06:59 PM | #3 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
Did you get an error message? It almost sounds like your car went into limp mode.
If it did throw an error, go to the dealer to get it read out. |
06-08-2010, 02:37 PM | #4 |
Rep 34
What is B5? I am having to refuel as light is now on however i was at about half a tank when it happened. I only run on Shell - is this know to have problems?
06-08-2010, 02:39 PM | #5 | |
Rep 34
I am having a full service on the car on Thursday and getting all the filters etc changed so just have to hope it does not happen again. |
06-08-2010, 06:37 PM | #6 |
147
Rep 2,383
5% Doughnut oil
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
06-08-2010, 08:15 PM | #7 |
Rep 436
B5 is Bio Diesel 5%. There are allot of good things in running 5% bio. Bio will clean and lube the fuel system. If there are deposits on the valves and pistons it will clean those too.
HS |
