BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
Mporium BMW
      12-01-2014, 10:01 AM   #1
CarbonX
Drives: F15 X5
Front Lip Getting Loose
Hello my fellow enthusiasts. This is my first post to this forum as I just purchased my first M3. It is a 2011 Jerez Black E92.
The car has a Front Lip Spoiler that is getting loose. I can see the gap and the tape that was holding it on. See attached photos.
This may be a long shot, but can anyone identify the type of lip and maybe help me narrow it down to the manufacturer? I would like to ask them to address the issue or at least cover the replacement tape and provide suggestions on preventing it going froward.
I bought the car from a dealer, so they do not have any info on the lip.
Thanks for any help you can provide.
      12-01-2014, 10:16 AM   #2
Evolve Automotive
Evolve Automotive's Avatar
Drives: E46 M3 . E90 M3
I had the same issue as well. You have this with many of the lips. Have you checked to see it is just double sided taped and using the stock bolts? If not I would suggest adding some screws and some of these
Once you put some screws in they will not move
      12-01-2014, 10:48 AM   #3
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
That's an ARKYM lip. Prob wanna look into some self tapping screws into the bottom of your bumper.
      12-01-2014, 11:56 AM   #4
W///
W///'s Avatar
7484
Drives: F82GTS, E36/E92M3, Z4M
Pretty normal because the front of the car sees so much debris. Not much you can do but take it off and maybe see if you use more tape. Also make sure that the lip is actually bolted (hopefully the previous owner wasn't dumb enough to use tape alone)
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      12-01-2014, 01:52 PM   #5
CarbonX
Drives: F15 X5
Awesome!! Thanks for the info.
      12-01-2014, 01:54 PM   #6
CarbonX
Drives: F15 X5
Screws
I'll definitely add some screws to make it more rigid. Thanks for your direction everyone.
      12-01-2014, 01:57 PM   #7
CarbonX
Drives: F15 X5
These look like they will do the trick. Can you provide more info so I can purchase them?
      12-02-2014, 08:26 PM   #8
tinman831
Drives: M3
Most autoparts stores will carry them. You can use these or self tapping screws.
      12-03-2014, 02:10 PM   #9
Gfunk720
Gfunk720's Avatar
13
Drives: E92 M3- AW
2008 BMW E92 M3  [0.00]
It probably just needs to be removed and re-installed. It looks like the original owner didn't use enough tape, and the tape may not have adhered properly.
Mine is attached only using tape and stock hardware and doesn't sag. It withstands high speeds and doesn't budge.
Alpine White E92 M3 - 6MT
ESS Tuned
      12-05-2014, 08:48 PM   #10
wrecklessfool
23
Drives: E92 M3
Same with mine. Good quality tape and the stock hardware for the bumper attaching the back of the lip to the bumper.
      12-08-2014, 07:31 AM   #11
Evolve Automotive
I had a bunch laying around from my old RSX, you can get them from any car part store.
front spoiler, lip, loose
m3post
