05-08-2012, 04:13 AM | #1 |
Never underestimate the Home-Bowl
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
Keyless theft via OBD key cloning
This is getting pretty serious in the UK with hundreds of cars going missing. There is even a CCTV video of a 1M being stolen with this method and the alarm not going off, as the OBD port is out of the range of the ultrasonic sensors.
http://pistonheads.com/gassing/topic...W+Thefts&mid=0 I'm disabling the OBD port on my e92 M3 tonight. If I need it, I'll happily re-enable it, but I will not leave it for scum to take my car without any resistance.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
05-08-2012, 05:04 PM | #2 |
303
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
How does one go about disabling the OBD port? Can I get my dealer to do it? Also, I assume the car does not react to lock/unlock if the jammer is used so making sure it is locked would be wise?
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
05-08-2012, 07:25 PM | #3 |
Rep 3,049
Drives: 2009 BMW 335d
What years are the cars being targeted? What models?
05-08-2012, 07:37 PM | #4 |
Rep 3,049
Some videos:
05-08-2012, 08:03 PM | #5 | |
Rep 85
you can disable the ODB port by pulling out one of the wires from the socket .. there is a diagram on page 7 of that thread the thieves don't need to use a jammer .. apparently there is a blind spot where they can break the window without tripping the alarm i think i'm going to pull out the wire in my ODB port
¯\_(ツ)_/¯
sup son |
05-08-2012, 08:17 PM | #6 |
77
Rep 1,208
Wouldn't the easiest way to lock your vehicle down is pull the fuse out for the OBD port, then physically lock the glove compartment? If you need to bring the car in for servicing or do any OBD coding, just plug the fuse back in. No fuse = no power to OBD port.
05-09-2012, 05:37 AM | #7 |
484
Rep 821
Interesting. Does the fuse only affect the OBD port, and if so do you know which one it is? I know I can use the little map, but not while I'm at my desk at work...!
05-09-2012, 06:41 AM | #8 |
484
Rep 821
I investigated that and it's not possible without compromising other systems.
05-09-2012, 03:34 PM | #9 |
Rep 8
All that's needed is to wire one of these into the OBD harness or the fuel pump relay:
http://www.ebay.com/itm/RFID-Key-Acc...item255e23e6da The OBD harness/port is probably more convinient as one would only need the RFID token to activate the OBD port vs using it every time to start the car if the circuit is wired into the fuel pump/ignition. -enjoy |
05-09-2012, 05:45 PM | #11 | |
77
Rep 1,208
05-09-2012, 07:14 PM | #12 | |
77
Rep 1,208
What if you could do a combination of both this and the glovebox idea? 1. Tap into the DC+12V line via the OBD fuse. 2. Ground the RFID unit to the ground bolt in the fuse panel. 3. Hide all of this behind the glove box area. 4. Lock glove compartment. I've got fuse taps that I've used to tap my dashcam directly to the fuse box so this whole install should take 15 mins to be honest. Only downside to that is you'll need to carry your RFID keyfob with you all the time but it'll be more secure since they can't just pull the wires out of the RFID unit and bypass the RFID unit to the OBD port. If these guys are stealing cars like this, I'm fairly certain bypassing the power on the RFID unit's not hard at all. However access to a physically locked glove compartment's going to be a lot harder. Also by tapping into the fuse box as opposed to splicing directly into the wiring, it's external to the BMW's electrical system so warranty won't be voided. (plus you can easily remove it before bringing it in to the dealership) |
10-09-2013, 08:44 AM | #14 |
Rep 2
I took my car into the BMW garage this week for another reason and they perfomred a software update whilst there to stop the car being stolen this way.
Surprised wasn't a recall! |
10-09-2013, 09:05 AM | #15 |
powerhouse
708
Rep 1,628
Drives: 2014 Porsche 981 CS
is there any real numbers or data supporting these claims beyond what is posted on forums and one-off news sites that we've never heard of?
maybe this is true but it strongly reminds me of old chain emails and hoaxes. of course someone will sell you something to fix this too.
no signature. except for this one.
10-27-2013, 03:47 PM | #16 | |
484
Rep 821
11-18-2013, 03:49 PM | #19 |
484
Rep 821
Exactly.
