TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > 328i drivers! i need an opinion!
      06-22-2012, 08:50 PM   #1
yxjackxh
yxjackxh's Avatar
Drives: 14' F32 AW MSPORT
so im repainting my car and i was wondering if you guys think i should just get the single outlet mtech rear for my 328i while im getting my car painted, or just get the oem repainted and wait because i want to get a custom quad exhaust set up!
any insight?? what would you guys do??
buy mtech rear and just keep single outlet exhaust or wait for the quad exhaust??
      06-22-2012, 10:08 PM   #2
_shim
Drives: an e90
I'm a 335xi owner so take this however you will, but imo, get the m-tech rear and keep the stock exhaust (maybe look into some new tips, aka cyba or dimisa) and get the quad exhaust and a diffuser later on. Just my 2 cents.
      06-22-2012, 10:41 PM   #3
E90Company
E90Company's Avatar
194
Drives: Car
+1.
      06-23-2012, 12:29 AM   #4
yxjackxh
yxjackxh's Avatar
Originally Posted by E90Company View Post
+1.
Hmm cuz the thing is, if i get a quad exhaust then im going to need the 335i mtech rear so i dont wanna waste another 400-600 buying the rear bumper again if i get the 328i mtech rear
      06-23-2012, 12:42 AM   #5
ObiChen
ObiChen's Avatar
82
Drives: 11'E90 / 18'F82
2018 BMW F82 M4  [0.00]
I think the mtech bumper for 328 and 335 are the same, just the diffusers are different. buy the mtech bumper and quad tips diffuser and install them if u sure u gonna go for quad exhaust. the driver's side outlet on single tip diffuser and on quad tips diffiser are in the same place.
      06-23-2012, 12:50 AM   #6
ObiChen
ObiChen's Avatar
82
Well, I was talking about E90, if u say E90 and E92 r different, then thats another story..
      06-23-2012, 01:07 AM   #7
yxjackxh
yxjackxh's Avatar
well i wanted to get the 335i bumper because the placement of the exhausts is how i want them to be. On the 328i bumper im going to have to alter the opposite side of the bumper to fit the other exhaust tips but they are too far apart, which i dont really like the look of it.=/ but thats just my opinion!
      06-23-2012, 01:26 AM   #8
Bruce li
27
Drives: 2011 e90 lci
Bumpers are the same only diffuser is different. I have a 328 and made the conversion to the 335 setup. Just realized you have a e92, sorry
      06-23-2012, 02:59 AM   #9
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
bumpers are identical. get the mtech now. you can get a quad diffuser later when you get your exhaust done.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      06-23-2012, 09:00 AM   #10
Dark_Knight_335
Came to the N55 Darkside
Dark_Knight_335's Avatar
Drives: 2011 335 E93 M-Sport
Shim has the right idea.
      06-23-2012, 12:34 PM   #11
_shim
Drives: an e90
OP, you can change the exhaust outlet position from a 328 single diffuser to 328 or even 335-style (more centered in the bumper) with a new diffuser and an exhaust shop. Just get the M-tech now
      06-23-2012, 01:44 PM   #12
edirtaynine
Drives: e92
just fyi, thats a "328" quad exhaust. it is NOT the same as the 335 quad exhaust. the "drivers side outlet" are definitely not the same for 328 and 335. there are quad setups for the 328, and then there are 335 quad conversion for the 328.
but yes, whether you have a e92 or e90, if you have the mtech bumper, you can change the diffuser piece later. e92 bumpers are the same with each other, and e90 bumpers are the same with each other. just dont try to mix n match e92 and e90.
e90post killed plastidip
Just say no to painted stock wheels
jm3as hooks it up
      06-23-2012, 05:18 PM   #13
yxjackxh
yxjackxh's Avatar
Originally Posted by edirtaynine View Post
just fyi, thats a "328" quad exhaust. it is NOT the same as the 335 quad exhaust. the "drivers side outlet" are definitely not the same for 328 and 335. there are quad setups for the 328, and then there are quad conversion for the 328.
Oh so if i get a 328i mtech rear, i can later convert it to make it look like a 335i quad rear? how does that work? because the 328i mtech rear already has the single outlet on the far left as opposed to the 335i the dual exhaust is more inside in the middle, which is the look i want compared to the far separation of exhausts for a 328i
      06-23-2012, 06:07 PM   #14
edirtaynine
Drives: e92
you can just take off the "328 diffuser" and replace it with a "335 diffuser"... BUT you will have to get the exhaust/muffler piping re-done by a shop to fit the outlets. and you keep the rest of the bumper the same.
jm3as hooks it up
      06-23-2012, 09:01 PM   #15
yxjackxh
yxjackxh's Avatar
oh okay so i might as well get the 328i mtech rear while im painting my car and just get the diffuser when i get my exhaust done right??
      06-23-2012, 09:16 PM   #16
chrisE92
chrisE92's Avatar
Drives: Monaco Blue E92
Yes.
Obviously, you should do this now so that you don't end up paying to paint two bumpers (stock AND m-tech in the future).
To restate what everyone else has already said:
- The m-tech rear bumper for both the 328i and 335i are identical, except for the diffuser.
- You can buy the 328i m-tech rear bumper now, and keep the stock 328i exhaust and stock 328i diffuser until you are ready to change the look.
- When you are ready, you can simply purchase a new diffuser made for 335i m-tech rear bumpers, and replace your 328i diffuser with it.
- In addition to changing the diffuser, you will need a custom exhaust setup if you want something that looks like a 335i.
I did this exact same thing years ago. I bought a 328i rear m-tech bumper and later replaced the diffuser with a carbon fiber one made for a 335i. Then I bought some quad tips, got custom piping done, and now my rear end looks like this.
      06-23-2012, 09:43 PM   #17
yxjackxh
yxjackxh's Avatar
Originally Posted by chrisE92 View Post
Yes.
cool! thanks alot chris! do you have any preferred exhaust tips or exhaust brand or anything like that?? i know its all personal preference, but are the remus and pe exhausts the usual ones people do?
      06-23-2012, 10:40 PM   #18
chrisE92
chrisE92's Avatar
The remus quads made for a 328i are spaced out farther than 335i quads, so you won't want that. I wouldn't want to hack up the performance exhaust to do a custom quad setup; it probably won't be as loud as you want it to be after the extra piping muffles the sound.
I personally think the best route (and from what I've seen, most popular) is to purchase your own tips, a magnaflow muffler or something like that (search for the models people have used) and get a good shop to do the custom work for you. I purchased my tips from "cyba", a vendor on here. You can search for his threads and check out his selection.
If you can stand the drone and don't need the muffler, then you just need to buy the tips and get straight piping done.
      06-23-2012, 11:20 PM   #19
ObiChen
ObiChen's Avatar
82
Yes, u r right, I was just talking about the driver's side outlet of stock 328 and quad tips 328, nothing to do with 335
      06-24-2012, 01:24 AM   #20
yxjackxh
yxjackxh's Avatar
yeah ill probably buy my own tips, as long as the sound is much more aggressive than it is my stock exhaust ill be satisfied=). because i dont like it too loud either. do you have any sound videos or anything?
      06-24-2012, 03:47 PM   #21
E90ROXS
E90ROXS's Avatar
225
Drives: E90
I have an unused quad cf diffuser (made for the e90 328 mtech bumper). $100 shipped. Pm me if you're interested.
      06-24-2012, 05:22 PM   #22
yxjackxh
yxjackxh's Avatar
Sorry i got a e92=/
328i, bumper, exhaust, mtech
