Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Bmwhat app (Carly for BMW)
      07-28-2014, 03:51 PM   #89
ferocity02
Drives: 2013 135is
Originally Posted by WilliamS View Post
The cable came in today as well the $9 bluettooth adapter. I can confirm the bluetooth adapter, I will test the OTG cable tonight.
Yours might be one of the oddball with the leftover parts so you may need the cable instead of the bluetooth.
I worried that that's the case, and I specifically looked for an 04/2007+ so I could flash the TCU. I'd be pissed if mine is an older style.
What bluetooth adapter are you using? I tried with my ELM327 and the app said my model can't be coded through bluetooth. But I was using the "lite" version of the app.
      07-28-2014, 03:57 PM   #90
WilliamS
GoofBall
Drives: 2008 E92 N54 Xdrive
The TCU might be the new one on your car but have an older DME.
      07-28-2014, 08:55 PM   #91
WilliamS
GoofBall
On my 2008 I can code both using the OTG cable and Cable, or Bluetooth adapter. Its a win no matter what for me! If anyone is thinking about this app, buy it! Its not a master coder, but in less than 10 minutes and not using a single program I do not understand I was able to code.
Mirror Fold on lock
Comfort Close windows and moonroof
Amber Corner Delete
Speedometer on Dash
Seatbelt Warning <--- I always wear it, but man its annoying when you are sitting
Windshield wipers finish even when car is off
Unlock on turn off
Fog lamps with Highbeams
Dash lights always on
Im sure I will find more to do with it soon. It wont find the Cic module to turn off the warning but Im going to email the request to the originator.
Anyone in Tampa Id happily help for a nice cold coke. Im no master coder but the app helps a ton, as well I can do the alpina flash.
Again great app, expensive but man its paid for itself already for me.
FYI the OTG cable and K+D-Can cable with OTG USB on android as well the Bluetooth adapter can also be used with the Torque app. If you havent looked at that app, the video with gauge and map overlay is amazing and worth every cent. If anyone has any questions please feel free to ask. I spent the money and Im happy I did. It is an expensive app but I will happily justify it with you if you need someone to push you.
      07-28-2014, 09:07 PM   #92
ferocity02
Drives: 2013 135is
Mirror Fold on lock
Amber Corner Delete
Speedometer on Dash
Unlock on turn off
Good to hear! What phone are you using? I'm not sure if mine can be used with OTG.
This app can do the Alpina trans flash?
      07-29-2014, 10:03 AM   #93
WilliamS
GoofBall
The OTG cable is for newer android based phones to add a USB port to plug usb devices into. No it cant do the Aplina flash. I have the Galaxy S5 but there are many phones that are OTG compatible.
      07-29-2014, 10:06 PM   #94
ATTN
ATTN's Avatar
Australia
96
Drives: 335 E92 DCT
2009 BMW 335i  [10.00]
This app is actually pretty cool.
what about coding things like TV while in motion? I didn't see that option in the youtube clip?
      07-31-2014, 09:18 AM   #95
Googlyamnesiac
Googlyamnesiac's Avatar
59
Drives: 2013 F10 520D
Originally Posted by CodyJ View Post
So my 2006 330i was able to be coded for almost everything, except the FRM module, which is where I would code out the amber corner lights, correct? You were able to do this on your 2006?
Am I missing something, or did I miss an option in a different module?
Thanks again!
Yeah, I did my corner delete. I wonder if someone upgraded the FRM in my vehicle before I purchased? I can definitely code the FRM on my 2006 330xi ... weird.
      08-04-2014, 01:43 PM   #96
datbimmer
Wastegate Rattle
113
Drives: 335i m6t nav sport
So my car is a 03/07(with after 03/07 "hardware") and I am not able to code with the app. It asks for cable... this sucks.
      08-04-2014, 03:19 PM   #97
Googlyamnesiac
59
Are you using bluetooth? I wasn't able to code with bluetooth, only read errors. With the cable I was able to code though.
      08-04-2014, 03:27 PM   #98
datbimmer
Wastegate Rattle
113
Yes bluetooth. They say cars before 03/07 need the cable...
      08-04-2014, 04:11 PM   #99
ferocity02
Drives: 2013 135is
Mine is 04/2007 and it also says I need the cable
      08-05-2014, 07:22 PM   #100
CamboSlice
CamboSlice's Avatar
Drives: 07 335i E90
2007 BMW 328xi  [0.00]
Coded comfort eject, windows and sunroof up/down with lock and unlock on key fob, alarm by holding trunk unlock on fob, but I can't code anything in the FRM module.. message comes up saying something along the lines of "error. Code writing failed. None of the cars settings have changed."
I'm using the K-DCAN ODB II with a OTG USB on my galaxy s5. Anyone have any ideas why I can't code the FRM module?
      08-05-2014, 10:33 PM   #101
E9XMC3
E9XMC3's Avatar
Drives: 2007 e92 335i
i have a 2006 so it looks like ill be going to wired route. i was just wonderingif i can use an OTG cable with an iphone or does it have to be an android to be able to use an OTG cable?
      08-06-2014, 09:26 AM   #102
Nido_5
BiH
Nido_5's Avatar
28
Drives: 335i
So what is the reason for people coding on their own instead of through this app? What can this app not do that is needed through other coding? This app seems perfect to me.
Has anyone had any serious issues like messing up their car? bricking? or has everyone been happy with it?
Also, is there a code on there to delete the safety/warning screen on the nav at startup?
      08-06-2014, 10:09 AM   #103
ferocity02
Drives: 2013 135is
People do their own coding because it is generally cheaper and there are more options available than in bmwhat. But setting up and understanding the software is a bit of a pain. The bmwhat apps takes a lot of the pain away and offers 1-touch coding basically. There was a report of one person bricking their FRM with bmwhat, I believe it was earlier in this thread.
      08-07-2014, 11:19 PM   #104
koches
Drives: 2009 328i xDrive
I have an 06 330xi. How do I know this app will work with my software? A couple posts up the guy says his 06 330xi works fine and the other says it doesn't let him code out the corners...I'll be getting an Apple OTG cable and then the other cable to hooku up to the car. Just a little worried about wasting $50 on this app if I can't use all of it.
      08-08-2014, 02:51 AM   #105
Scrippy
Lord Scrip
Scrippy's Avatar
Drives: 2011 M3 Coupe
  [0.00]
2007 BMW 335i  [0.00]
Originally Posted by Extacide
So I just coded a handful of stuff:
-Angel Eyes as DRL (No Amber Corners)
-Key Fob Fold Mirrors
-Key Fob Open/Close All Windows
-Digital Speedo
Probably something else I am forgetting, but I used a basic ELM327; however, I can't disable to the seatbelt chimes since I can't get into safety stuff using my basic ELM327. Anyone have a recommendation for an ODB2 (who've done it without using the BMWhat ODB2) that can disable that stuff?
Thanks!
I have the Elm327 and I can't code. What are you using iPhone or android?
      08-08-2014, 10:27 AM   #106
Kaisah
72
Drives: 340i F30 LCI
2017 340i  [0.00]
Hey guys,
I have a 2010 e92 with led corona angel eyes. I've been trying to code the angel eyes to stop dimming when the low beams are on. The app lets me into the FRM module and I have changed the angel eye brightness for 3 options to very high, angel eyes as DRL/standing lights/parking lights. The app says coding is successful, however they do not seem to change intensity.
Any ideas what I'm doing wrong?
      08-08-2014, 10:36 AM   #107
WilliamS
GoofBall
Originally Posted by Kaisah View Post
Hey guys,
In order to stop my 08 from dimming I had to set all the EU setting to very high, as well american settings to very high.
      08-08-2014, 10:37 AM   #108
WilliamS
GoofBall
You need the proper adapter based on the phone. Android and Iphone do not use the same ones so his website is specific.
      08-08-2014, 10:49 AM   #109
Kaisah
72
2017 340i  [0.00]
The only 'US' options I see are for the corner markers. There is an option for 'drl us' which only has the enable/disable option. I enabled this. Still no difference. Hmm.
Do I need to change the corner marker brightness? These are disabled at the moment.
      08-08-2014, 10:56 AM   #110
datbimmer
Wastegate Rattle
113
I tried both Cable and Bluetooth on 2 E46 2001 and it didn't work.
Works well with my 03/07 with my OBD cable to my Note2
bmwhat app, coding
