Oil cooler question
03-30-2012, 09:56 AM | #1 |
Rep 638
Oil cooler question
Is there anything out there that replaces the stock OC core with a bigger unit while retaining most of stock plumbing for OEM look from engine bay?
03-30-2012, 11:05 AM | #2 |
Rep 452
IIRC the connections on the OEM oil cooler are a special design by BMW, so simply putting in another core won't work.
I looked into that, but you have to get adapters to connect to the new core to the existing plumbing, or buy new oil lines, plus there will be some fab work to do also. You're better off waiting until Black Friday and get a ER Sport oil cooler for less than $600. I think thats the best solution out there if you simply want to upgrade to a stock part to a more efficient solution and don't plan on hammering the car at the track regularly. |
03-30-2012, 11:50 AM | #4 | |
Rep 452
http://www.e90post.com/forums/showth...ighlight=sport Hey PM them and see if they can give that price to you now, won't hurt to try. Good luck |
03-30-2012, 04:27 PM | #6 |
Rep 6,989
Drives: 15 F80 M3, 22 G01 X3 30i
I got my ER sport oil cooler at a Black Friday price - you might just contact them and see what kind of deal they'll give you. It has adapters for its hoses that screw into the OEM fittings and aside from the fact that they're black nylon braided hoses, it looks "factory".
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
03-30-2012, 05:56 PM | #8 |
112
Rep 2,856
Drives: 2011 335is E93
Don't they have an intro. deal for their for dual-sport oil coolers? You can run em in the fog light locations.
03-30-2012, 06:24 PM | #10 |
Rep 4,392
You also have the Dinan Oil Cooler "system" that replaced not only the Oil Cooler that is two times the size of the stock, it replaced also the stock oil hoses with bigger oil hoses that are braided, a replacement air duct, and ventilation air flangs help to direct the air flow and to protect from stone flings from the wheels that can damage the oil cooler fins
It only cost $1600 . If your not planning on keeping the car then seek a cheaper solution |
05-30-2012, 08:14 PM | #11 | ||
Rep 2,396
Drives: '08 E90 335i
It's possible to custom fabricate an upgraded oil cooler kit. Buy a Setrab oil cooler core & the connection lines. Turner Motorsport sells a kit (~$900), but you could probably just buy the mount directly from them. Here is the description from the webpage for the product:
05-11-2014, 10:27 AM | #13 |
DIYER
614
Rep 5,521
Yep...custom lines and 180 degree thermostat are the way to go.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
05-11-2014, 10:29 AM | #14 |
DIYER
614
Rep 5,521
I will have to modify the setrab core since I am icing the stett bracket that goes underneath crash bumper. With this being under crash bumper it caused fitment issue with my 1M bumper because it pushed crash bumper out 1/8" - 1/4"
05-11-2014, 10:41 AM | #15 |
291
Rep 2,898
05-11-2014, 10:43 AM | #16 |
DIYER
614
Rep 5,521
I love it....great piece
11-13-2016, 04:30 AM | #18 |
48
Rep 263
You won't be getting a reply off rob he left this platform a while ago
UK
V8bait Tuned Built motor FBO 335i |
oem, oil cooler |
