The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Canadian DRL Delete
      01-25-2011, 08:46 AM   #23
matrix76
matrix76's Avatar
61
Drives: 2020 Z4 M40i Black/Red
Originally Posted by Geby-E90 View Post
I'm kinda experienced in using NCSExpert. Is there a way to code the Halogen DRL off and code it so the AE's act as the DRL or is it only done thru hardware?
*Sorry for the threadjack.
Post #10 solves one of your isuues.
Brian
Black Sapphire, Black w/Burrwood Trim & Shifter, 162's, Mtec H8 AE's, DS1 HID 6000K
      01-31-2011, 02:57 PM   #24
Noxious_
27
Drives: 08 E90
Not sure. I got Miguex to code my vehicle, hes a pro; he might know how to do it.
As far as I know, the daeos is the easiest way to do it but there is also a DIY that uses wiretaps but that is with hardware. I would think that it could be done with software thought.
I'd keep an eye on the coding excel spreadsheet people are adding to. It has all the coding functions and what module they are located in.
      01-31-2011, 09:12 PM   #25
k3m0-330i
k3m0-330i's Avatar
Drives: 08 335xi
2006 330i  [0.00]
Originally Posted by Noxious_ View Post
You need the Daeos harness now. There is a DIY that requires some wiring but it is just easier and less messy to order the daeos.
I cant get ncs running or communicating with my car. I have downloaded the drivers for the DCAN cable so well see if that helps.
Every time I start NCSEXPERT on windows 7 virtual XP mode it says cannot find api.dll or something similar to that. I am thinking this is a registry error. Anyone know how to fix it?
no its not messy one 1 wire for one head light to the other and in
Current 2008 M6 e63 v10 6mt
Current 2012 e70 x5 35i -jb4
2008 335xi e92- Sold
2007 335i e90 - Sold
2002 Taig / Red / / / M3 - SOLD
      01-31-2011, 09:39 PM   #26
xxxjecxxx
xxxjecxxx's Avatar
Drives: F30 335i M sport
2013 BMW 335i  [0.00]
2006 BMW 325i  [0.00]
a member moved to germany and brought his car to germany (BMW came back home lol) he wanted to code an option that was only available in the US so he changed his VO to reflect a car "purchased" in Germany.
You should try and change your VO to US specs. then you can code the same things we can.
      02-02-2011, 05:37 PM   #27
SaviorSelf
SaviorSelf's Avatar
Drives: 2007 BMW 335i
Hmm, thats interesting.
      02-03-2011, 09:49 AM   #28
matrix76
matrix76's Avatar
61
Nothing yet that I know of, I am still looking , , ,
Brian
      02-24-2013, 01:24 PM   #29
6MT_Addict
6MT_Addict's Avatar
283
Drives: 08 135i M Sport 6MT, 15 X3 35i
2008 BMW 135i  [10.00]
Coding Success
Got this working on my 09 323i w/ halogens (LED retrofit).
Left all of the TAGFAHRLICHT_ECE values alone
(TAGFAHRLICHT_ECE & TAGFAHRLICHT_ECE_0 seem to be DRL on/off switch. TAGFAHRLICHT_ECE_1, TAGFAHRLICHT_ECE_2, TAGFAHRLICHT_ECE_3 changed nothing for me when turned off)
All I changed was the VERHALTEN_DRL_TFL value - set from drl_h (DRL = high beams) to drl_s (DRL = angel eyes) as per the description in the coding spreadsheet.
Oddly enough though, after my angel eyes would no longer come on when I unlocked the car, going to try a couple things to get this working again, 90% sure I know what it is.
      05-24-2013, 09:40 PM   #30
Solscud007
Drives: 2010 323i Space Grey
I got a 2010 323i. Halogen lights. No angel eyes. It is Canadian. How do I disable DRL? I tried the in dash settings but it is not there.
      05-24-2013, 10:09 PM   #31
melenkae90
melenkae90's Avatar
Drives: 2007 e90
Canadian cars don't give you the option to turn on and off. You need to get that option coded to turn on.
canada, drl, h7 bulb
