Replacment bulb halogen headlamps! 320i
03-10-2010, 03:32 PM | #1 |
Rep 7
Hi
I want replace the bulb of my E90 320i car has , the current (original) ones works perfect but the lights are so yellow and want swap bulb with a more white , i was thinking buy the H7 extreme white from PIAA but i am afraid to create a error on the computer putting something not Original by factory , any advise to change to a more white light and just plug and play? also want have the same light on my fog lamps .... hope someone can help me in this issue , i dont want spende $70 dollars if i will have problem with the system of my car. Thanks |
03-10-2010, 06:14 PM | #2 |
Rep 17,017
You will want a 55w H7 replacement bulb. So long as it conforms to the factory rating, you will not get error codes or risk the factory housing/wiring.
One option are the Xenesis Tru Match bulbs which are a hyperwhite replacement. You won't get a true xenon match from a halogen bulb but they will be whiter than stock. |
03-11-2010, 09:24 AM | #3 | |
858
Rep 35,253
your fog lights are H11 55W. its probably best to get the same brand for perfect matching. in this case, MTEC super whites would be a perfect match to OEM, but pure white with no yellow like stock |
03-17-2010, 11:54 AM | #5 |
Rep 7
Hi
i change them and work wonderfull i am damn happy how they look , so white and clean .. will send pictures , but i make a mistake i just brought Low beams = Xenesis tru Match H7 1 set (2 bulbs) Fogs Lights = Xenesis tru Match H11 1 set (2 bulbs) but i forgot buy for High Beams can any help me with what i should buy? they use the same H7 or another number? Hope i can get answer soon!!! |
03-17-2010, 12:02 PM | #6 |
Rep 1,985
03-17-2010, 01:54 PM | #7 | |
Rep 17,017
