TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > aFe Intake Fix/Solution | Surging & Power Loss Issues Resolved
      08-18-2011, 09:26 PM   #1
eNineZero
eNineZero's Avatar
175
Drives: 2015 328i xDrive
Arrow aFe Intake Fix/Solution | Surging & Power Loss Issues Resolved
Hey guys,
I just purchased a used aFe Intake for my 2006 325i Sedan. After installation the intake sounded amazing however the car did not run right. After assembling and disassembling the intake several times and creating my own gasket for the maf I was about to give up. I compared the stock intake and the aFe to find that the MAF sensor sits alot higher up in the intake tube on the factory box.
Issues: I experienced a huge loss in power between 4000-6000rpm, and very evident engine surging (power for 200 rpms , no power for 200 rpm, power, no power, etc.) throughout the power band at WOT.
Solution: I created a spacer for the MAF out of 1/2 inch MDF board. I also made a gasket out of 1/16 inch thick sheet of rubber to go between the spacer and intake tube. I did not need a gasket for the MAF to spacer since the sensor already has an o-ring, however the hole in the spacer must be perfect for the MAF to stay sealed. Longer bolts (extra 1/2 inch) had to be sourced.
Here is a diagram:
Outcome: The car now runs perfect, cannot feel the slightest stutter, power seems to be good and engine revs smoothly regardless of throttle input.
I am glad I decided to try this instead of giving up, as this is the best sounding intake I have heard for the E90/E92. I hope this can help solve some of the other members issues with this intake since research showed there is quite a bit of you with similar problems.
Alpine White 2015 328i xDrive | H&R Sport Springs | 20" Niche M146 Essen | My Build Thread | Follow me on Instagram: @peternowacki
      08-19-2011, 12:18 AM   #2
tamster00
Uhh, Hi =)
Drives: 11' E90 335i, 12' Fit Sport
I was hoping that aluminum heat shield would've been plastic/silicon, that would absorbed less heat and not rob power, good fix though!
Was - 08' E90 328i|Sparkling Graphite Metallic|AA Tune|Steptronic|Navigation|Comfort Access|Sport|Matte Black Kidneys
Now - 11' E90 335i Performance Edition|Space Gray Metallic|Sport|Premium|Navigation|Steptronic|JB4|E R Charge Pipe|HP Autowerks Foam Filter
      08-19-2011, 08:09 AM   #3
eNineZero
eNineZero's Avatar
175
Thanks! I don't believe that the shield is really robbing any power. I understand that it gets hot, but it does not have enough time to heat up the ambient air with the type of airflow the engine has. Yes, from a stand still or a gentle cruise at low speed I can see how the aFe would ingest some of the underhood air since the shield isn't sealed well, but once the car is moving and at WOT especially if you have some type of scoops it should have no effect on IAT. Remember that on a dyno the car stands still, and those fans are really nothing compared to a car moving at 20+ mph.
      08-19-2011, 08:59 AM   #4
MaximusJ
MaximusJ's Avatar
300
Drives: 340Xi MG 2017
Good job! I had the symptoms as you did with that very same intake. But I must admit your symptoms were waaay more present then mine.
I am a bit concerned by the seal between the MDF and the MAF over time and heavy rain / snow conditions; but time will tell!
I just find it ackward that aFe never steped up with this kind of fix. You should contact them and sell them the fixes ;p
Good job on that sir!
Mineral Grey '17 F30 340XI
[Garage] // [Build Journal]
Jet Black '06 E90 325I
[Garage]
      08-19-2011, 10:16 AM   #5
eNineZero
eNineZero's Avatar
175
Thanks. I am planning on getting an aluminum spacer made by a local machine shop. I used MDF board for temporary/test purposes.
      08-19-2011, 10:54 AM   #6
shazzy04
shazzy04's Avatar
South Korea
29
Drives: '15 F22 M235i
Nice fix, I'm going to have to do this on mine
thanks
2015 M235i - Mineral Gray/Coral Red - Cold Weather/ Technology/Premium Packages
Mods coming soon
      10-22-2011, 07:31 PM   #7
soursamo
soursamo's Avatar
153
Drives: 2008 E92 M3
I'll be the first to say put me down for one if you decide to get them machined!
      10-26-2011, 08:06 PM   #8
krnboy817
krnboy817's Avatar
South Korea
43
Drives: 2008 328i coupe
so does this mean that this intake creates hp gains and no hp loss like most people say this intake tends to do?
driving is poetry in motion.
      10-28-2011, 02:48 PM   #9
arctic330i
arctic330i's Avatar
Drives: F15 35i
2014 BMW X5  [0.00]
2006 BMW 330i E90  [8.08]
2013 BMW 335is  [10.00]
Very interesting... I sold mine because of this issue. Once I hear this is a true fix I will have to look into it for sure!
See my full mod list in my garage
      10-29-2011, 06:01 AM   #10
berserkerx
berserkerx's Avatar
Drives: 2006 330i
I am one of the guys who just stuck with a stock air box and a K&N. If this is a real fix I may make the jump. But I am guessing this intake still suffers from heat soak?
      10-29-2011, 02:23 PM   #11
krnboy817
krnboy817's Avatar
South Korea
43
the theory is that the ambiant heat surrounding the intake isn't effecting the incoming air since the cooler air going into the intake is moving at a certain rate where at that rate, there is just not enough time for heat to be infused to make the air rise in temp.
this is true to a point but a lot of factors play a role to make this true. and one thing off the back that doesnt make it true for afe heat shield is that its paper thin aluminum, which over a certain period of time of exposure to heat it will be something that will transfer heat (metal holds heat and radiates the heat it holds.)
my other argument is in a tightly enclosed case this theory is possible but that heat shield isn't something that you can call tightly enclose space. and although the ambient heat my not transfer to the cooler air, but the hot air that is already infused with heat may leak into the very area the heat shield is supposed to create.
so for a stock intake box the theory can be applied, since it creates a tightly sealed enclosed space. but it cannot be applied to AFE heat shield since it does not create this encasement. and im sure there is a reason why BMW made the intake box casing material as thick as it is.
so the only way for AFE to be effective is when the out side temp is low enough to offset even after all the heat factors are added and still have the temp of the incoming air cooler than what stock box can hold.
      10-30-2011, 07:12 AM   #12
berserkerx
berserkerx's Avatar
Drives: 2006 330i
So are you still saying basically that the stock intake with a K&N is still the best thing for our cars? Maybe I am a skeptic but I have always felt like an intake basically is just there for making noise for a high price.
      11-23-2011, 05:41 PM   #13
325xi-06
manifold conversion 325/330
325xi-06's Avatar
Faroe Islands
Drives: 325xi 06
i will have to try this fix also. as my car runs un-smooth :P
      11-23-2011, 05:59 PM   #14
RupertPupkin
RupertPupkin's Avatar
Drives: Freak Beast
Just installed the Injen SP1121BLK Intake in my 2006 330i. I have experienced no loss of power, surging, or anything negative at all. It sounds amazing and may have gained some power and responsiveness, but definitely didn't lose any. I have had the car sitting after long drives and then gotten in and there are absolutely no heat soak issues to be noticed.
I'm sure that with a thermometer and a scientific analysis it may be sucking in some warmer air, etc but the real test for me was real world experience and all I can say is it is night an day with the stock airbox.
Couldn't be happier with it.
      11-25-2011, 02:58 PM   #15
blazex4
blazex4's Avatar
Drives: '14 Cayman S
Could this fit in the '06 325i?
I've been reading threads about power loss with the afe intakes
      11-25-2011, 03:06 PM   #16
RupertPupkin
Drives: Freak Beast
Yup. Pretty sure its the same part number from Injen. Check their site.
www.injen.com
      11-25-2011, 05:02 PM   #17
1QuikWS6
No 55mph
1QuikWS6's Avatar
1616
Drives: F32 435ix MSport
Innovative fix!
But how about everyone just NOT buying AFE intakes?
I see this problem day in & day out on the forum, resulting in quite a few AFE intakes being sold second hand on the forum.
You would think by now that people would simply quit buying the pieces of junk and send AFE a real message...
There are other intakes available
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      11-25-2011, 06:13 PM   #18
Mwishlist
Mwishlist's Avatar
Drives: 2008 328i
Just curious, how did you figure out that the spacer would fix the issue? I would have never thought about that.
Interviewer: The most exciting moment during the race weekend?
Kimi: I think so it's the race start, always.
Interviewer: The most boring?
Kimi: Now.
      11-26-2011, 08:06 AM   #19
eNineZero
eNineZero's Avatar
175
Originally Posted by 1QuikWS6 View Post
Innovative fix!
The AFE Intake is great, but has a design flaw which can be easily fixed. It's also the best sounding intake hands down. The sound part is the selling feature I believe, nobody buys them for power gains.
      11-26-2011, 10:54 AM   #20
onephattai
20
Drives: e90
yes the sound is awesome but I feel like the intake sound gets a little softer after a few days. I don't know maybe it's just me. My problem with this intake is I don't have power in low rpm, like from 1k to 2.5k. If I apply more gas around these rpm range, then the car will surge which really annoys me. I'm thinking of doing what you did with the gasket. Hopefully it will solve my problem otherwise I'll have to go with something else. On DS mode, the car runs great. Still a little power loss at low rpm but no surging.
to the sound but it comes with a problem
      11-26-2011, 11:51 AM   #21
krnboy817
krnboy817's Avatar
South Korea
43
its because you just spent $200+ and your brain is trying to cope with money wasted by telling your self "there is a gain... there is a gain..." its a placebo effect. its like 200hp civic si feels different perhaps slower/lagging than 200hp gti because its not boosted, but in the end its still 200hp.
      11-26-2011, 02:37 PM   #22
RupertPupkin
Drives: Freak Beast
I bought it for sound. I didn't expect gains and don't think there were any. I didn't say it did. I said it sounds great and have no issues especially the power loss everyone talks about. I said it MAY have gained some but even if it did I wouldn't be able to feel it. I've modded many cars before and know what to expect.
Troll
afe, issues, power, problems, surging
Search this Thread:
