Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Bmwhat app (Carly for BMW)
      11-16-2014, 08:22 AM   #265
mickyboy1
Drives: BMW E92
Just tried it. Mine is a 2007. It says usb not working! I wonder if i have to tell my andriod phone to connect via usb (only.had this phone one day. Come from iphone)
      11-16-2014, 12:59 PM   #266
mickyboy1
Drives: BMW E92
Woohoo i got it connected. I needed the cable in the phone first and set connection to alternative. Ive sent my log off to the developer. See what comes back
      12-18-2014, 12:22 AM   #267
Anth0nyD
Anth0nyD's Avatar
26
Drives: White 335i
looking to buy a BT adapter, anyone know if this would work with the app?
http://www.amazon.com/iKKEGOL-Wirele...A2VDCJH6QLAPQL
      12-18-2014, 04:46 AM   #268
OpopO
Drives: 320i e92 M-sport
Is there an coding option for Angel eyes/DRL sensitivity? So option to set when lamps turn off and on? Light sensitivity?
      12-18-2014, 01:07 PM   #269
chumley
chumley's Avatar
50
Drives: 2009 335
I bought this one and it had worked flawlessly every time. I have an HTC M8 FWIW.
Bluetooth OBD2 scan tool
MHD flash, DCI, BMW PE, ETS FMIC, Powerflex, SWS8xi's, VMR 803's in Solar Rain, LUX V4
      12-18-2014, 01:14 PM   #270
chumley
chumley's Avatar
50
Drives: 2009 335
See list below for current options. Make sure to click on the 1/3 tab and scroll down. They are always adding new things. I just added "digital speedo" and "ignore voltage" on my reverse lights - avoiding having to add resistors on my led reverse bulbs. There are some entries for Angel Eyes.
List of options -
      12-19-2014, 04:19 PM   #271
N54Twin
N54Twin's Avatar
413
Drives: F85
You will not be able to code some feature with this adapter i have it, & have the original one that let me do the coding on all..
Sweet Pie
      12-20-2014, 11:44 PM   #272
bd5400
16
Drives: 2012 328xi E92
Yes. They claim it may not work with iDrive cars but it worked fine with mine.
      12-21-2014, 10:16 AM   #273
Pa951
Drives: E91 320D
I used the app for the first time yesterday, works great!
What i can't get working is the us sidemarker function as drl. Any suggestions? Activated them and they are on when tje lights are on but not on position 0
I have the daeos wiring harnas so the angel eyes are on when contact us on but would like to have the amber lights to be on aswell.
It is a european car. 2006. So the frm1 module.
Help..
      12-21-2014, 11:19 AM   #274
Tim603
Tim603's Avatar
Drives: 2007 335i E90
2007 335i  [0.00]
Help..
That should be an option when using your steering column stalk to do vehicle settings
      12-21-2014, 01:55 PM   #275
Pa951
Drives: E91 320D
The option drl on a european car does not do that.
I want the angel eyes and sidemarkers on as drl. The angel eyes can't be on without the daeos cable on a 2006 car with the frm1 so i have the daeos but can't get the sidemarkers to go on at ignition. Only with lights ôn they are on.
      12-21-2014, 06:54 PM   #276
Anth0nyD
Anth0nyD's Avatar
26
Drives: White 335i
Which feature can't i code with it? I ordered it already and it should be here next Wednesday, where did you order the bmwwhat adapter and how much?
      12-22-2014, 03:04 PM   #277
zero2sixtyZ
Drives: e92 + f15
The latest update says "corner delete" as an option. Haven't been able to find this one yet. Anyone have luck?
11/06 build, Android via USB.
      12-25-2014, 09:31 PM   #278
Anth0nyD
Anth0nyD's Avatar
26
Drives: White 335i
Got my turn signal to be turned off but I wasn't able to turn the outer led bulb to turn off. Anyone have any luck with that?
      12-26-2014, 09:22 AM   #279
zero2sixtyZ
Drives: e92 + f15
+1
      12-26-2014, 03:44 PM   #280
cfc67
Drives: E90 330D Auto
Anyone know why I can't access the catalyst soot filter option on my app? Is my car not compatible? E90 330d
      12-28-2014, 11:47 PM   #281
woodpecka
woodpecka's Avatar
68
Drives: E91
Originally Posted by Meeni View Post
Yes and no. You can read the fault reports and do some maintenance tasks (like what you can do with INPA, but it is all immensely simpler to install and use).
You cannot code with a ELM BT adapter, and it is not very clear to me at this point if you can code with an OTG USB cable.
So it can also clear errors like with INPA?
      12-29-2014, 12:01 AM   #282
techie182
48
Drives: 328i coupe
Can you code bulb error check? Upgrading to LCI tails nextweek
      12-30-2014, 02:54 PM   #283
I6TT
I6TT's Avatar
14
Drives: 2007 BMW 335i
Sweet app, i got the digital speedo working. Also got windows up/down with lock/unlock button function to work.
      12-30-2014, 03:45 PM   #284
toneatles
Drives: 2011 328xi
which settings do i turn on for the windows up/down?
      12-30-2014, 04:01 PM   #285
W37V
[Oo=||=oO]
1103
Drives: e92n52 & f15n57
Which version of app is better between iOS and Android? Is there any difference?
I am debating which one to get and which one will better. Android version provides battery registration, and I don't see that option on ios.
      12-30-2014, 09:17 PM   #286
WOT Bimmer
WOT Bimmer's Avatar
Drives: 2018 BMW M2
Guys, is it possible to clear SES using this app? I have the lite version right now.
If not, can I at least pull the code? I will being using iOS
bmwhat app, coding
