BMW 320d has slow acceloration please help
11-17-2009, 12:00 PM | #1 |
Rep 27
HI i have a BMW 320d SE saloon 55 plate. Which is very sluggish in gears 1 and 2. It has a very slow pick up from stop. Fine when in higher gears. Problem before and after service. Please help. Thanks
11-18-2009, 10:39 AM | #2 |
Rep 1,467
http://www.bmw.com/com/en/insights/t...oupe_320d.html
From 0 to 100 km/h in 7.9 s Is that about what you're getting? Was it always slow? Or did this just get slower than stock? -scheherazade |
11-18-2009, 11:55 AM | #3 |
Rep 1,838
lol!!! no disrespect to the the op but wouldn't it be funny if someone took back their 116d or whatever those tiny things are called and claimed he got a lemon cuz it goes from 0-60 in 9 seconds...
11-18-2009, 12:06 PM | #4 |
Rep 1,467
This is what confuses me.
320d : 0-60 in 7.9 4 cylinder honda accord : 0-60 in 7.3 (econo 'i don't care for going fast' version) 6 cylinder honda accord : 0-60 in 5.7 If it's a problem : he has to be getting 0-60 in like 10+ to notice the difference. If it's not a problem : did he bother to floor it during the test drive? -scheherazade |
11-19-2009, 04:11 AM | #7 | |
Rep 15,858
Are you new to diesel power? If I am reading your description correctly, (heard it described like this before), sounds as if you could have a turbo issue. I'd suggest you check, or get checked, the variable vane actuator mechinism. It could be sticking, or not allowing slow speed spool up. It is a common thing to get power at higher speeds, as the default setting is for controlling boost. So you don't get the benefit of the VGT at lower rpm. Sometimes the problem can be the EGR valve sticks open and that also is more noticeable from lower rpm. HighlandPete BTW, if you want lots of diesel user expertise, join us at BMWland.co.uk |
11-19-2009, 10:12 AM | #9 |
Rep 15,858
The one before an 06 plate. Here in the UK we often use the registation code to identify the age of the car. 55 is September 05 to February 06, My car's an 06, that is from March 06 to August 06.... 56 follows from September 06, and so on.
HighlandPete |
11-19-2009, 10:39 AM | #10 | |
Rep 5,732
By extrapolation and judicious application of Murphy's Law, we can therefore conclude with glee that the N55 engine, you know, the one with the variable vane single turbo that is supposed to eliminate the HPFP issues of the N54 engine, will suffer from the same issues as the variable vane turbo of the diesels in Europe........
__________________________
2016 435 xdrive GC white on black leather interior, Msport1, Msport2, premium package 2015 Lincoln MKX, silver on brown leather, premium package - that's right! Techno-Groovy baby |
