Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > RFT or NON RFT
      12-21-2011, 03:58 PM   #1
glo459
Drives: 08 335i convertible
RFT or NON RFT
Anyone got any recommendations as to stay with RFT tires or should I go Non-Run flat tires?
E93 front 225/40/18
Thanks!
      12-21-2011, 08:25 PM   #2
M-Steep
23
Drives: 2009 E93 M Sport
E93 front 225/40/18
Thanks!
Just got Michelin PSS non-RFTs to replace my OEM Bridgestone RFTs on my E93 M-Sport (18s).
Short first take: Much less harsh over sharp hits (e.g., seams, cracks, potholes); turn-in precision/ crispness still great, if not quite as sharp; ride is silky; can't say for sure about grip around turns until more miles; straight line grip under heavy throttle seems obviously better. Getting the Conti repair kit for the trunk.
      12-21-2011, 11:51 PM   #3
glo459
Thanks for the feedback!
Do you think it'll be a problem if I use non run flats for the front, and keep the oem run flats in the rear at the same time?
      12-22-2011, 07:25 AM   #4
M-Steep
23
I got conflicting advice on this; decided to replace all four, though the fronts were still ok. Glad I did, w that the money's spent.
      12-22-2011, 07:35 AM   #5
driverman
Drives: 2008 328i 6MT - SOLD
Big problem. The front tires won't be as stiff as the rears which will upset the balance of the car. I wouldn't do it.
Recommend you get 4 non-RFT's. The new Michelin Pilot Super Sports seem to be the best tire you can buy. You can find tirerack's test results here: http://www.tirerack.com/tires/tests/...y.jsp?ttid=148.
      12-22-2011, 10:11 AM   #6
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
+1
glo459, whichever way you decide to go, be sure all four tires are matching.
Tires http://www.tirerack.com/a.jsp?a=AH8&...ires/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      12-22-2011, 11:46 AM   #7
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
No problem - as long as you never drive on wet roads or over 25 mph on dry ones.
See Gary's post.
Tom
      12-22-2011, 12:15 PM   #8
glo459
Thanks you for all the advise! I'll be switching all four tires to Michelin PSS.
      12-22-2011, 01:17 PM   #9
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
+1
If you are going to make the switch to non-RFTs, you should do all four rather than just a pair. Overall though, those who do switch over are often pretty satisfied with their decision.
      12-22-2011, 01:58 PM   #10
Brian@bavarianx
Drives: E36 M3
Non RFT all the way!!!
      12-24-2011, 01:06 AM   #11
rg87
rg87's Avatar
51
Drives: E90
+1 The RFTs are heavy and cost waaay more than a good set of non-rft tires.
If you decide to go the non-RFT route, replace the whole set and buy a road side kit for flat tire emergencies!
      12-26-2011, 10:04 PM   #12
o2centre
Drives: 2008 E92 328i Jet Black
Switched from the OEM runflats to a set of Michelin PSS non-runflats a couple months ago. Thrilled with my decision. Your spine will appreciate it going over bumps (especially if you've got a sport-tuned suspension). Had them out at the track twice and performance is sweet.
      12-26-2011, 10:10 PM   #13
driverman
How about steering response and noise compared to the RFT's?
      12-27-2011, 12:23 PM   #14
witeagle
Drives: 14 BMW Z4 2.8i * 10 BMW X3
I am in the same process and going non-RFT. I just havn't made up my mind which tire to go with.
I am also pondering going with a performance all season as I don't have a winter set. On my 325ci I had winter tires and used them for one season. The car ran fine with summer ultra high perf tires. I am not sure if the 335i will react the same in the snow!
driverman's question regarding steering response is actually very good and I have the same question along with another related question about steering response/performance with an all season over a summer performance tire.
'08 335i Coupe / 6MT / Sport / Premium / Nav / Cold Weather Pkg / Space Gray / Black Dakota Leather & Aluminum Trim
'10 X3 SAV / Premium / Nav / Cold Weather Pkg / Alpine White / Sand Biege Nevada Leather / SAV Pkg
      12-27-2011, 11:20 PM   #15
o2centre
I never tracked the car with the run flats so can't speak to the difference in steering response under high performance conditions. As far as everyday driving goes though, I don't detect much change in handling. The primary difference is a more forgiving ride over bumps and ruts. The car does less of that jerky "shimmying" right and left when going over bumps.
Haven't heard a noticeable change in noise level.
      12-27-2011, 11:27 PM   #16
o2centre
Was just back on the east coast visiting my folks for Christmas. They live halfway up a mountain and my dad has Hakkapeliitta studded snow tires on his car. Loud as hell and they eat at least 5 MPG off his gas mileage. Made me thankful I don't have to worry about that here in socal!
225/40/18, e93, non rft, rft, tires
