11-21-2014, 08:51 PM | #7635 | |
General
10413
Rep 40,650
Apps requires a 9C FSC Code issued by BMW AG for your VIN be imported and activated in Head Unit, and then car coded for 6NR. I have no idea on Portuguese voice control.
11-21-2014, 08:53 PM | #7636 | |
General
10413
Rep 40,650
Did you merge (copy) it into your old version rather than delete and replace it? Did you have any errors extracting your PSdZData?
11-22-2014, 12:47 AM | #7637 |
Rep 524
I deleted the old data and replaced the set. No errors extracting the PSdZData. I'll try again to extracting it again.
11-22-2014, 04:03 AM | #7638 | |
Rep 23
Thank you Shawn. Where can I get and read about 9C FSC? Only BMW can do this code? For that I need full psdzData? I'm downloading lite. My car has 6NRA, but works only with IOS (Jun-2013). Card made after Jul 2013 works with IOS and Android. My VIN is F940497. Regards Last edited by hugoalvim; 11-22-2014 at 12:09 PM.. |
11-22-2014, 08:35 PM | #7639 | |
General
10413
Rep 40,650
For Android Apps, NBT needs at least 50.4 firmware, and the following coding: HU_NBT => A4A_ANDROID = aktiv
11-23-2014, 09:54 AM | #7640 |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
Shawn,
Could you please send to avgor111@yandex.ru file cafd_00000794-012_035_116 if you have it. |
11-23-2014, 12:51 PM | #7641 | |
General
10413
Rep 40,650
11-23-2014, 01:01 PM | #7643 |
General
10413
Rep 40,650
PM sent.
11-23-2014, 01:03 PM | #7644 | |
Rep 23
I want also do add launch Control (I code it but don't works) Upgrade my GPS Map (Latin America, 161112.3.115 Road Map South America Next 2013 NBT_D12505I) Upgrade my firmware to 50.4 (My I-Step is F020-13-03-503) and change oil service from S8KPA (8000 KM/ 12 MOUNTS) to S8KMA (12000KM/ 12 MOUNTS). This is only FA change? I need code any ECU? Sorry so much questions. Hugo |
11-23-2014, 01:14 PM | #7646 | ||
General
10413
Rep 40,650
Launch control may need EGS Flashed with newer firmware. Changing Oil Service Interval requires DME flashed with 8KM in FA. You can update your map to Road Map South America Next 2015. You need complete PSdZData for flash ECU. 54.1 is the latest. There is no guide for this, but here are the basic steps: You will need to put the car on a commercial grade charger, good for 50 amps minimum, as you cannot run the motor while flashing. Go to Comfort Mode => TAL-Calculating - Read and Save FA - Activate FA - Read and Save SVT Actual as SVT_ist - Create an SVT Target Under KIS/SVT Target Calculation Strategy, select Complete Flash Select I-Step (shipm.) to match your original I-Level as read and shown in VCM I-Step (Shipment) I-Step (target.) will be unselectable as it is fixed based on current PSdZData I-Level Do a KIS/SVT Target Calculation and Save as SVT_soll - Do a TAL Calculation and Save as SVT_tal Go to Expert Mode => TAL-Processing Load TAL (SVT_tal) Load SVT Target (SVT_soll) Select "Read FA" button. Check radio button for "read VIN out of FA" On ECU Tab, uncheck let top box in column "All" (All checked boxes should toggle to unchecked) On ID Base Row for every ECU you want to flash, make check boxes in blFlash, swDeploy, cdDeploy, and ibaDeploy columns. Press Check software availability Press Start and it will proceed with processing TAL to flash selected ECU's with new firmware.
11-23-2014, 06:26 PM | #7648 |
Rep 60
Drives: 2017 330i Sport
Shawn, can you PM details on the latest PSdZData lite download? Many thanks!
11-23-2014, 07:27 PM | #7649 |
General
10413
Rep 40,650
PM sent.
11-24-2014, 01:06 PM | #7650 |
36
Rep 398
me too please shawn
f31 330d mineral grey/black interior with extra stuff fitted
11-24-2014, 01:13 PM | #7651 |
General
10413
Rep 40,650
11-24-2014, 04:25 PM | #7653 |
General
10413
Rep 40,650
PM sent.
11-25-2014, 09:18 AM | #7654 |
13
Rep 68
Drives: F31 Sportline
Hello Shawn,
can I also have a link for the latest PSdZData lite download? Thanks for all! |
11-25-2014, 09:32 AM | #7655 |
General
10413
Rep 40,650
PM sent.
