Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > VMR Wheels - VB3 19x9.5 19x10 on E92 335i
      10-21-2009, 11:48 AM   #45
1985mb
1985mb's Avatar
Drives: BMW & Audi
Originally Posted by Peter@VMRWheels View Post
Front Wheels: VMR Wheels VB3 19x9.5 ET33
Front Tires: 235/35/19 General Exclaim UHP
Rear Wheels: VMR Wheels VB3 19x10 ET38 + 5mm Spacer (19x10 ET33)
Rear Tires: 265/30/19 General Exclaim UHP
What's the highest profile tyres I can run on this setup (cr@ppy roads around here)? Is the following possible on a stock E93 ZMP:
F: 19x9.5 +33, 245/35
R: 19x10 +38, 275/30
Current: E60 535i M-sport
Former: 2012 Mercedes-Benz E350 BlueTec, E90 330i ZSP, E93 335i ZMP
      10-21-2009, 04:28 PM   #46
info@VMRWheels
info@VMRWheels's Avatar
31
Drives: BMW
It's possible to run that, however you might run into slight rubbing issues up front. We have a customer lowered on sport springs with the exact wheel set you are describing, however, he is running 235 tires and reports no rubbing. So, in short, with the 245 tires you may be able to do it as long as you don't lower the car.
      10-21-2009, 10:02 PM   #47
1985mb
1985mb's Avatar
Drives: BMW & Audi
Sounds good car will not be lowered, one needs the clearance and sidewall around here.
      10-21-2009, 10:06 PM   #48
catch
catch's Avatar
668
Drives: F80 M3
very nice!
2016 F80 M3 Mineral White/Sakhir Orange
2013 BMW S1000RR Flat Silver <stolen>
2007 BMW E92 335i Jet Black/Jade Grey <sold>
      10-21-2009, 10:53 PM   #49
yowhuddupb
Stuntin'.
yowhuddupb's Avatar
22
Drives: //Mtrey/K7 GIX600
1998 Prelude  [0.00]
2008 335i  [0.00]
im running this same setup but w/ lower offset in the rear. the front is flush w/ 235's. i am running H&R race springs too!
      03-06-2010, 11:05 PM   #50
ClayMan
18
Drives: E36, E39, E86
After lowering the car, I put a 12mm spacer up front, effectively making it a 19x9.5 ET21. I thought there would be some massive "poke" but not so much with camber at -2.5*
Peter, got any pics of this?
      03-07-2010, 07:40 PM   #51
ton741
BMW 335I
ton741's Avatar
9
Drives: 335I Sprt Pkg Sp black
do you have any rubbing issue at front due to 9.5"?
      03-08-2010, 01:24 AM   #52
itsjappo
itsjappo's Avatar
19
Drives: 2013 335i M Sport
more pics of the setup please.
      03-31-2010, 11:12 AM   #53
MTibbs
MTibbs's Avatar
Drives: 2011 335i
Looks great.
      04-22-2010, 01:46 PM   #54
NiVeDh
NiVeDh's Avatar
Drives: '08 E90 335i, '99 E36 M3
I am set on the 19x10 ET38 with 275/30/19 for the rears.
Would 19x9.5 ET33 with 245/35/19 Hankook Ventus V12 fit the front of an E90 with ZSP? I'm not planning to lower the car and I don't want to roll the fenders.
      04-23-2010, 09:18 PM   #55
caliban
Drives: BUS
just helped a friend installed a set of exact setup 19x9.5 +33 front and 19x10 +38 rear (235/35/19, 265/30/19) on his E93. The car is lowered on MR coilovers. We found the front will require at least 5mm spacer to clear lower collar of the coilover.
      04-24-2010, 04:16 PM   #56
ClayMan
18
I just setup 265/30 all-around on 19x9.5 ET32 on an E93 lowered with Eibach Pro-Kit springs and front camber at -2.5 deg using camber plates... Looks awesome.
      04-25-2010, 08:25 PM   #57
UltraRacer13
Wannabe Track Rat
UltraRacer13's Avatar
British Virgin Islands
68
Drives: 17 OG M2
ty- can you pm me a quote on a set of 19" vb3's gunmetal to fit my 08 335xi. have no idea about the offsets- With hancook evo 12's mounted. 245/275
thanks-
      04-29-2010, 04:58 PM   #58
e93 me
Drives: E九三
Yes, the car is lowered now, you'll see pix soon
update with pics?!?! :]
      04-29-2010, 06:16 PM   #59
Peter@VMRWheels
Peter@VMRWheels's Avatar
Drives: P85D
I posted the updated pix in a different thread, but ever since then the setup changed again.
My car is at the dealership today for its 3rd HPFP and when it gets back I'll do another "proper" photoshoot for you guys!!
      04-29-2010, 06:20 PM   #60
e93 me
Drives: E九三
sorry to hear about the HPFP! but can i get a link to that thread? :] thanks in advance!
      07-29-2010, 01:38 PM   #61
missingsin
Drives: bmw 328i
omg!
Originally Posted by VTECaddict View Post
I want to copy you... LOL
me too!
      10-13-2010, 07:51 PM   #62
JustinS
Member
Australia
Drives: 335i, VB3s, MHD, FMIC, RBs
Hi, quick question for VMR guys. The tyre experts over here in Perth, Oz are saying that stretching a 235 tyre over a 9.5 inch rim is absolutely crazy and are strongly recommending against it. Your pictures look great, and Im trying to copy your look, but Im scared to invest in the 19x9.5s up front if all the local experts (I've spoken to a few now) say the same thing. How would you respond to their concerns and warnings?
      10-14-2010, 01:44 AM   #63
Peter@VMRWheels
Drives: P85D
A 235/35/19 tire is definitely something that a tire chain isn't going to mount on a 9.5" rim, but its a fairly popular wheel/tire combo in the world of aftermarket wheels/tires. The "stretch" allows you to maximize your offset to make the wheels as flush with the fenders as possible. With this setup the wheels are basically wider than the tires, making the lip prone to damage.
If you want a slightly more conservative setup, you can do a 245/35/19 which will also work on a 19x9.5 ET33 as long as you don't lower the car too much!
      10-23-2010, 12:29 AM   #64
Terry℡
Terry℡'s Avatar
Drives: BMW E82 135i
VMR‘s nice wheels!
      01-25-2011, 01:55 PM   #65
SHATX
baby chicken eater
SHATX's Avatar
Drives: 07 E90 335i - 08 3.0si coupe
2007 E90 335i  [10.00]
im a newbie here - I want this same set up on my Black Sapphire E90 335 Pre-LCI but in Hyper black. the only issue is i cant find a good picture that does the Hyper Black justice. makes it hard to decide on the color of rims. also, i am planning on adding the H&R Coil overs but the touring set so not as low as the sport, do think there will be any issues after i roll the rear fenders?
      01-25-2011, 05:36 PM   #66
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
With a fender roll you'll be perfectly fine.
Here are a few other shots to show how different our Hyper Black can look depending on lighting.
-Charles@VMRWheels
concavity, csl, vb3, vmr, vmr wheels
