Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > 335xi transmission noise - please help
      08-30-2014, 11:47 AM   #1
jtice
Drives: 2011 335xi Sedan
Hello,
I recently bought a CPO 2011 335xi MT sedan with 35k miles. The car is great, except for a really annoying noise that is coming from the left front end. The noise is in sync with the rotation of the wheels, and only occurs when the car is in gear and I am coasting to a stop (or to otherwise slowing down). The noise goes away instantly if I take the car out of gear or press down the clutch. The noise can best be described as a light thumping noise. The dealership said that the noise is normal, and that some cars make it and some cars don't. That sounds like BS to me. I would really like some more information about the problem before I try to challenge the dealer. Any help would be appreciated.
Thanks - Jason
      08-30-2014, 12:14 PM   #2
sy2767
sy2767's Avatar
145
Drives: 2013 x5
Sounds like a clutch issue ........
      08-30-2014, 08:07 PM   #3
JETmn
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
Front CV or front diff? I would check out the CV's. I wouldn't expect any issues with that low of miles. Did you check to see if it was in an accident? I have 62k on mine with no noises.
      09-02-2014, 10:01 AM   #4
jtice
the car had a clean Carfax and was a lease before I bought it. how do I check the CV joints? do you have any ideas about what I should say to the dealer?
      09-02-2014, 11:23 AM   #5
JETmn
2011 335Xi  [0.00]
Put the car in the air and rotate the tire front to back and listen for a click from the CV. Many times they will start clicking in a tight turn also.
I would tell the dealer that you are sure that BMW would not put out a poor product that some cars randomly made drivetrain noise. Something in the driveline is making noise when under load, but it is really hard to say what without diagnosing.
      09-02-2014, 02:48 PM   #6
cburn
Drives: 2011 335I xDrive
2011 335XI  [0.00]
I've got the same issue on my automatic. They told me it was the runflat tire. I think that's Bullshit.
      09-04-2014, 10:11 AM   #7
jtice
is there somewhere else I should post my problem to get more feedback?
      09-11-2014, 10:03 PM   #8
EZ_C
EZ_C's Avatar
Drives: 2011 335i xdrive sedan automat
I just purchased a CPO'ed 2011 335i xdrive sedan automatic with 30,000 miles and discovered the same issue described above. My dealerships first attempt at a resolve was to rotate and balance the four brand new run flat tires they had put on it.... No luck, the noise is still there (left front?). My sales manager went for a ride and said the sound is not normal.
A BMW service rep happened to be at the dealership today and said it most likely was a wheel bearing. He said the CV joint would sound worse while cornering. My issue disappears under any load... E.g. acceleration and cornering.
Monday they will replace the drivers side front wheel bearing... Fingers crossed!
      09-18-2014, 12:22 PM   #9
EZ_C
EZ_C's Avatar
Update for anyone interested.
It turns out it was the drivers side front half shaft. They replaced the wheel bearing, but the "knock" remained. The half shaft solved the problem.
      09-19-2014, 01:39 PM   #10
jtice
I had an appointment with the lead service tech at BMW bel air MD earlier this week. He insisted the noise is normal and that he would have no way of diagnosing the problem at this time. I kept pushing the issue but got no where. Any suggestions on how to proceed? Does anyone know of a better shop in MD that would help resolve my issue? I am incredibly frustrated and I get angrier everytime I coast in gear and hear the noise!
      09-19-2014, 03:05 PM   #11
JETmn
2011 335Xi  [0.00]
Tell him you rode in 2 other identical cars from the guys in the BMW club and they don't have that noise, so no it is not normal.
      09-29-2014, 09:53 AM   #12
cburn
2011 335XI  [0.00]
Wow man thanks!
I've had this issue for 5000 miles and they tried to blame it on my runflats.
I will make sure I push them in the right direction next service call.
335xi, manual transmission, transmission noise
