BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Fuel Tank Plate Fallen In HELP!!!
      06-22-2014, 03:16 PM   #1
Sunlight1
Drives: 3 Series E90 320d SE
Hi after filling up some diesel, I noticed when I got home that the 'metal flap' that covers the fuel diesel tank hole was no longer present. Now I'm pretty sure there was a flap last time I remember however I'm not sure if it has fallen into the fuel tank? If so will it cause damage (get sucked into a fuel injector...)
Is there a way this can be checked or remedied cheaply??
I'm pretty sure it was the dodgy nozzle at the filling station that caused this.
As per the pic, you can see a straight hole down, as opposed to a mates pic on his 318i he has a metallic plate covering the nozzle hole. I'm pretty sure mine looked similar..
Please help.
My car is a 320d E90 05 Plate.
http://i62.tinypic.com/1zvz70p.jpg
http://i62.tinypic.com/2qvcyuc.jpg
      06-22-2014, 03:25 PM   #2
JesseJames
JC
10
Drives: E93
Uh ohhhh
      06-22-2014, 03:53 PM   #3
e92_enthusiast_1
e92_enthusiast_1's Avatar
Drives: '10 AW/CR e92 6mt 335i
2010 BMW 335i  [0.00]
Weird. Didn't even think it'd be able to fall in.
      06-22-2014, 04:29 PM   #4
Miller335
291
Drives: 2007 E92
Get sucked into a fuel injector?
Even if it fell into the tank I doubt it would ever find it's way into the fuel bucket in the tank that holds the fuel pump.
      06-22-2014, 05:21 PM   #5
Dsport
Dsport's Avatar
24
Drives: E91 320d Lci
On the e36 and 46 Lift the rear seat and remove the liner and there are some screws to remove the plate below that is the tank and the sender unit unblot the sender unit and try retrieve the flap that way, personally I'd just leave it in there it won't do any Damage
      06-23-2014, 12:48 PM   #6
BashShah
295
Drives: 2012 335i Sedan
I think the Only way to fix and possible Retrieve the Broken Tab, is to Remove and Inspect the Filler Neck.
Go to a good Body Shop, not dealer.
This should not take more than 2 Hours to fix completely.
Also recommend finding a Fuel Filler Neck complete from Auto Wrecker, or Ebay and take it to Body shop on first visit.
And,
If the Broken Tab has fallen into Tank...
well option 1, Leave it there.
Option 2, get it OUT....and Make sure the Rubber Seals on the Tank Access are Replaced (NOT REUSED OLD Ones), It a one time thing.
DN
      06-24-2014, 09:41 AM   #7
Sunlight1
Thanks for the all responses guys, you've really put my mind at ease. Much appeciated
320d, diesel, flap, fuel, tank
