Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > 335xi dyno.. around 400 horsepower. Video
      01-04-2013, 10:08 AM   #1
ColdTestament
Yep.
Drives: 1999 Tahoe z71, 2011 e90 m3
Happy new year all,
Went to ISP Racing in Beltsville, Md on a whim and had my car dynoed. I was pleasantly surprised. I didn't expect the numbers I got. I've always read that it takes a lot more to get to that 400 wheel hp mark on our awd cars. Ended up with 397 hp and 400 torque. Seemed like the tranny started slipping for a second but pulled consistently. The operator said something about it making too much torque and something about the torque converter needing to be a bit looser. He also mentioned that his dyno reads about 13% lower than others in the area.
What was fun is that I went around same time as my friend's RS4 and he was putting down 300ish hp, but man that v8 sounds amazing.
I was running a jb4 on map 7 with 60/40 e85 mix, stock intake with lid off, new plugs, injectors, coil packs, and lpfp.
Numbers seem about right for an xi? They were telling me with the numbers and launch I should see 11s.
Here's the video:
Here's the dyno pic:
      01-04-2013, 01:27 PM   #2
Boosted-M
Drives: F10 535D XDrive (USA)
Can you post datalogs for these runs?
      01-04-2013, 02:09 PM   #3
ColdTestament
Yep.
I didn't have my cord with me. It was kind of a random dyno run.
      01-04-2013, 07:38 PM   #4
Jabber88
Jabber88's Avatar
Drives: E90 335i
Very nice! would have loved to see a baseline, but those numbers are really strong. Im going to be putting my car on the dyno soon I'm hoping to hit somewhere in that range.
      01-04-2013, 07:41 PM   #5
Jabber88
Jabber88's Avatar
Drives: E90 335i
Forgot to ask, do you have a manual or auto?
      01-04-2013, 11:06 PM   #6
pits200
Drives: 09 335i X-Drive Black Sapphire
Nice peak numbers but that's a scary looking dyno.
      01-05-2013, 01:24 AM   #7
ColdTestament
Yep.
I was definitely surprised. I was expecting maybe 360 hp without down pipes and such. The car is an auto. Hey Pits, I'm new to the dyno thing. What makes it look scary? I've been trying to compare it to other xi dynos to better understand it.
      01-05-2013, 09:40 AM   #8
drfrink24
13
Drives: 2008 335xi
The two abrupt dips, logs would show if it was throttle closure and/or timing drops vs. slip.
      01-05-2013, 10:38 AM   #9
ColdTestament
Yep.
Thanks. I'll have to run some logs.
      01-05-2013, 09:56 PM   #10
catchx34
Drives: 07 335xi
his has a torque converter = auto
      01-05-2013, 11:21 PM   #11
Jabber88
Jabber88's Avatar
Drives: E90 335i
Right on, I didn't know that. Learn something new everyday.
      01-06-2013, 01:27 AM   #12
psmitty95
psmitty95's Avatar
Drives: '23 M340i xDrive
I could be wrong but I think map 7 is way too agressive for your car with your mods... I'm FBO and I wouldn't touch map 7 even with 60/40 e85 mix. I asked Terry a few weeks ago if I upped the E85 could I run on map 7 and he said he really wouldn't recommend it. For your mods you should be running map 5 on E85 so you make sure that the car is running well.
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion
Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning
More Pictures: Build Thread /// 683AWHP/675AWTQ
      01-06-2013, 03:11 PM   #13
ColdTestament
Yep.
I could be wrong too but I remember reading that you can run the e85 mix on the race map or 100 octane. Ill have to check with Terry as the wisdom may have changed. This was the thread I read before the dyno about using map 7 for the mix.
http://www.n54tech.com/forums/showthread.php?t=15337
Thanks for the heads up though bro. Psmitty Have you dynoed your car? I've been looking to see what other xi or x drive cars are putting out. A lot of the dynos on dragtimes are a couple years old now.
      01-06-2013, 06:25 PM   #14
psmitty95
psmitty95's Avatar
Unfortunately haven't dynoed yet but i've done a few virtual dyno's with some great results. I think the most i've hit on Virtual Dyno was like 420whp/489wtq so if I could make those numbers it would be amazing. I'm trying to wait until spring when the E85 mix at stations is back to normal though. I'm really hoping for 400awhp or above and over 400wtq but we'll see. Here's a few more recent 335xi dyno's i've come across if you want to check them out:
http://www.e90post.com/forums/showthread.php?t=721630
http://www.n54tech.com/forums/showthread.php?t=18056
335xi, dyno, e85, jb4, n54
