PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
VMR Wheels - VB3 19x9.5 19x10 on E92 335i
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
09-17-2009, 01:10 PM | #25 | |
21
Rep 260
Drives: '09 E93
09-17-2009, 01:28 PM | #27 |
Rep 3,262
sick wheels. i'm seriously considering picking up a set of VMR's pretty soon.
whats the widest tire you can fit on the 10" rear?
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
09-17-2009, 01:57 PM | #28 |
31
Rep 326
You can fit up to a 295 on a 10" wheel, however, I wouldn't recommend it. 285 really is the widest I'd recommend on a 10" wheel. Fitting it on the back of your E92 is another story. Fender rolling will be a must to make them fit without rubbing.
09-17-2009, 02:37 PM | #29 |
Rep 3,262
are the v713's available in 10"?
09-17-2009, 05:08 PM | #31 |
93
Rep 685
09-18-2009, 10:41 PM | #32 |
21
Rep 260
Drives: '09 E93
09-26-2009, 11:25 AM | #33 |
21
Rep 260
Drives: '09 E93
is it lowered yet?
09-28-2009, 05:07 PM | #35 |
21
Rep 260
Drives: '09 E93
09-28-2009, 06:05 PM | #36 |
93
Rep 685
Yes and no....
During initial installation of the D2 suspension setup, I increased the camber to give the wheel/tire more clearance up top. With the 235/35/19 and 19x9.5, it does NOT rub up top. BUT.... because the car is so lowered (more lowered than most), the tires are rubbing on the fender liner over huge bumps. BUT... a big but... the "tuning" isn't complete yet. I need to get this aligned, corner balanced, and adjusted to the ride height of my liking. Between the adjustable camber plates, height, tire width, and ability to roll fenders, I'm confident that it can be tuned to where it does NOT rub. However this will take hours of tinkering to perfect, and it just depends on whether you have the time (or interest) to play with this |
09-29-2009, 12:25 PM | #37 |
21
Rep 260
Drives: '09 E93
does your VB3 19x8.5 ET40 fit flush with fender? or do i have to put spacers?
09-30-2009, 12:57 AM | #38 |
93
Rep 685
After lowering the car, I put a 12mm spacer up front, effectively making it a 19x9.5 ET21. I thought there would be some massive "poke" but not so much with camber at -2.5*
With this wheel/tire combo and a 2" drop, it did cause some rubbing issues. But.... the fenders haven't been touched yet in terms of rolling. |
09-30-2009, 12:59 AM | #39 |
93
Rep 685
These sit just fine with the fender at stock & mildly lowered height. But when you "dump" the car, it starts to camber in more, and you will feel that spacers are necessary when the tire tucks behind the fender. But again, if you get an alignment and bring the car back to OEM specs (very close to 0) you'll probably be happy with what you have
09-30-2009, 09:49 PM | #40 |
21
Rep 260
Drives: '09 E93
How come the VB3 19x8.5 doesn't come in ET35? This will extend out 5mm from the factory setup & should look perfect. Will this offset be manufactured in the future? This will eliminate the need for spacers.
09-30-2009, 10:07 PM | #41 |
93
Rep 685
19x8.5 ET40 is just fine, and well within the offset range for aftermarket wheels being offered for the E90 and E92. If you take a look at pictures of the countless VB3's we've sold, you'll see that it fits just fine. But if your intention is to be "hella flush", you'll literally need all the tricks in the book to chase the fender with your tires. You'll need to have more than just a 8.5 ET35... you'll need a 25-30 offset, 5mm and 12mm spacer, longer bolts, coilovers with adjustable camber plates, fender rollers, and 2-3 visits to the alignment shop. This is what I call a 8 hour tire change
10-05-2009, 08:05 PM | #42 |
21
Rep 260
Drives: '09 E93
Will the 19x9.5 ET33 stick out beyond the fenders when slightly lowered without camber adjustment? From the wheel offset calculator from tire rack, it will extend 20mm further out than stock.
10-05-2009, 08:22 PM | #43 |
93
Rep 685
^^ On the rear, it fits perfect. 9.5ET33 on the front + lowered, it will require fender roll. Camber adjustment is all relative - when you lower your car, your camber becomes more negative. So it gets adjusted without you even adjusting it, if you know what I mean.
Regardless, to go aggressive means you'll have to do a few things AFTER the wheels/tires are bolted on. It is not 100% plug and play. The info based on my car's fitment should be used as a reference, your actual experience may vary... depending on tire size/brand/type/suspension etc. |
10-05-2009, 10:18 PM | #44 |
Rep 1,716
Peter,
I want your EXACT setup on my e90 (stock susp), PM me price with tires shipped 92101 thanks
Formerly addicted to e46fanatics
Formerly addicted to e90post Last edited by bmrm396; 10-06-2009 at 12:33 AM.. |
concavity, csl, vb3, vmr, vmr wheels |
