Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > VMR Wheels - VB3 19x9.5 19x10 on E92 335i
      11-22-2013, 07:52 PM   #89
Chris_506
Drives: 2016 f82
Looks good man
      11-23-2013, 12:53 AM   #90
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
Originally Posted by jevanh View Post
Hi mate thanks for you help.
Sorry to sound dumb but i dont really understand the rear wheel. if i buy 19x10 et38 and add a 10mm spacer for the pre lci wont that make it 48et. i thought it would add not minus? =\ from what i have read et is the amount of offset is "The distance between the rim's center line and its mounting surface."so if i add 10mm spacer i am increasing the distance of the wheel from the mounting surface, so it wouldnt be 28mm?
im new to all this and maybe my understanding is just flawed..=\
No worries we all have start somewhere, but offset really works other way around. When you add spacer it will decrease the offset and push the wheel more out. So et38+10mm spacer really is et28. Basically low offset push the wheel out and high offset will retract the wheel in.
      11-24-2013, 09:15 PM   #91
jevanh
10
Drives: BMW 323i E90
Thanks so much its heaps clearer now =D will post up pics once i decide which route to go down =]
      11-26-2013, 05:31 PM   #92
Whiteout335i
30
Drives: 2010 335i alpine white
Originally Posted by Peter@VMRWheels View Post
We took the time this week to take some quick shots of my daily driver, an '07 E92 335i running a super aggressive fitment. The car originally had 19x8.5 ET40 and 19x9.5 ET33, but I decided to go crazy on the concavity
Wheel Specs:
Front Wheels: VMR Wheels VB3 19x9.5 ET33
Front Tires: 235/35/19 General Exclaim UHP
Rear Wheels: VMR Wheels VB3 19x10 ET38 + 5mm Spacer (19x10 ET33)
Rear Tires: 265/30/19 General Exclaim UHP
After 200-300 miles of driving, I can report no rubbing.... fenders are not rolled either! Same tires before/after, and as expected, no change in performance or handling characteristics.
Have a great long weekend
I got this exact set up after reading this post minus spacers but I rub slightly when turning wheel all the way to make sharp turns-__-
      12-03-2013, 01:16 AM   #93
ichibanumba1
Drives: '08 E92 335i
I was about to get this setup... so you rub on your inner fender on full lock?
Same tires and size?
      03-02-2014, 08:30 PM   #94
Whiteout335i
30
Sorry for late reply but yes when pulling out of my drive way and sharp turns but only on the right side. The fenfer linder has a vent that it rubs on
      04-06-2014, 06:02 AM   #95
TVPhoto
Living Life on the Fast Lane
Drives: 2007 335I SGM E92
Did anyone else have trouble clearing the strut with this set up? Apparently i did
      04-06-2014, 06:15 AM   #96
MonacoBlueE90
Finland
163
Do you have coilovers? Some of those have less clearance than stock shocks. Also if the tyre is wider than the wheel edge, then it's the tyre that hits. Any way add 3-5mm spacer and problem solved.
      04-08-2014, 02:59 AM   #97
TVPhoto
Yes i do have coilovers. I had to use my 15mm or 12mm for the front. My friend said it fit just perfectly, but kind of sticks out too much. Hopefully adding a 5mm would be a better fit. I am running 235/35 on the 9.5. BTW this is a E92. I am currently deployed.
      06-11-2014, 09:19 AM   #98
Andrew5
Drives: 2007 335i Alpine White
Originally Posted by Intense66 View Post
Here's my 07 E90 335
orig set up
front 8.5" 40 et 235/35/19 12mm spacer falken 452
rear 9.5" 33 et 265/30/19 5mm spacer falken 452
new set up
front 9.5" 33et 265/30/19
rear 10.5 38et 275/30/19 10 mm spacer
H&R sports
no rubbing in the front, but only in the rear so I rolled it just a little and it cleared.
Thanks to Charles VMR for his great customer service and 1clean335 for his advise on getting the 19x10.
I have the sport springs too and I was wondering if I'd be able to do this same setup... now I'm sold
JB4, AFE Intake, Transmission Flash
Active Autowerke: Intercoolers, BOV, Downpipes, Exhaust
H&R Sport Springs, Depot Headlights and Tail lights
LCI Front Bumper and Hood
      06-11-2014, 12:30 PM   #99
MonacoBlueE90
Finland
163
Sure you can, but if you want to fit 265/30/19 to front you will need negative camber, which means camber plates. http://www.e90post.com/forums/showpo...6&postcount=38 Also possibly 3-5mm spacer, so the wider tyre clears inside.
If you go with 19x9.5 et33 with 235/35/19 front and 19x10 et25 with 265/30/19 rear. Only thing you need is fender roll to rear. http://www.e90post.com/forums/showpo...89&postcount=3
      06-12-2014, 01:00 PM   #100
335m
Drives: 08 e92 M3
VMR v710
Think I can do this same fitment using the VMR v710 wheels on an LCI M-Sport e92?
      06-12-2014, 02:19 PM   #101
CWysong
tuned n dropped 335xi
Drives: '09 335i Xdrive e90
so what makes your wheels (VMR) more concave? I love the 718s and the vb3s and want to get as concave as possible... is it the wheel width or offset? I know vb3 is more concave than the 718 by default but what makes it so you can "go crazy with the concavity?"
335xi - BMS DCI - VRSF DP's - JB4 Tune - KW v1 -
      06-12-2014, 05:25 PM   #102
MonacoBlueE90
Finland
163
Width. Wider is more concave. Lower offset is just thicker backside.
      01-17-2015, 01:00 PM   #103
Jsoboti
Jsoboti's Avatar
28
Drives: 2011 335i E92 M-Sport 6MT
I've been asking around trying to get a concurrence on tire fitment.
I'm about to pull the trigger on V810's for my E92
f: 19x8.5 ET 33
R: 19x9.5 ET 35
Fronts will be 245/35/19 and for the rears I would like to run S-04's which only come in 275/35/19 not the usual 275/30/19.
Is it stupid/wrong/silly in any way to run the 275/35? The front is lowered about .5 inch on SP perches and the rear is stock height. Rear Fenders are rolled btw
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
      01-20-2015, 12:29 AM   #104
MonacoBlueE90
Finland
163
f: 19x8.5 ET 33
R: 19x9.5 ET 35
It could cause issues with DSC/ABS etc, because the tyres rotate different speeds. I have 225/40/18 and 235/40/18 which has 1.2% difference and i occaosionally get red light from tyre pressure, but my system monitors the rotating speeds from ABS system. It could have also been caused my bad battery, but still less difference is better.
      01-21-2015, 01:11 PM   #105
kevin_wei0429
Drives: E92 335i N55
Exclamation 2011 E92 335i LCI M-sport
Wheel Specs:
Fitting Question to Peter@VMRWheels:
I'm planning to put V710 19x8.5" ET35/19x10" ET38 on my 2011 E92 335i LCI M-sport with F:245/35ZR19 and R:285/30ZR19. Suspension will remain original M-sport, Don't want any fender work and spacer as needed. Will this setup fit my car which is a daily drive with no problem?
best regards,
Kevin
      02-06-2015, 04:18 PM   #106
Jus123
Jus123's Avatar
Drives: 2007 335i "E90"
2007 BMW 335i  [0.00]
Hey so im trying to fit 2014 513m (18x9 et29) wheels on my pre-lci
e90. I did a test fit (with out tires) and the rim looked to come past of the fender slightly and looked REALLY close to the shocks on the inside, any recomendations on how I can make this set up work and what tire size? Im currently running stock sports suspension.
      03-07-2015, 03:19 PM   #107
moreno1
moreno1's Avatar
73
Drives: BMW 335i E93
Question to the VMR pros
I just got used V703 with the following specs
Front: 19x8.5 et40
Rear: 19x9.5 et 35
I'm planning on putting 235x19 in front and 265x19
I have 12mm spacer in front and back and was wondering if there will be any rubbings once I install the wheels/tires in the spring on my pre-lci e93 with stock suspensions??
Thanks,
      03-08-2015, 12:37 AM   #108
MonacoBlueE90
Finland
163
Front: 19x8.5 et40
Rear: 19x9.5 et 35
Thanks,
Front shouldn't be problem, but rear will most likely rub.
      03-17-2015, 07:08 PM   #109
moreno1
moreno1's Avatar
73
Front: 19x8.5 et40
Rear: 19x9.5 et 35
Thanks,
Thanks for the input. I'm gonna try to find 5mm instead of the ones I have now.
Cheers
2009 335i E93 /// BSM /// Sport /// Premium /// /// 19" M pack 225 wheels /// M6 wheels winter set /// 35% Tint /// Gloss Black Grills /// PE Exhaust /// Lux H8 V3 /// Interior LEDs /// JB4-DCI /// Combox & CIC Retrofit /// M3 side skirts /// M3 front bumper ///
      02-28-2017, 03:11 PM   #110
Jewel's335i
22
Drives: Black 09 335i
Have an 09 e90 335istocl suspension and no fender mods with 19x10 et38. Will a 275 35 19 hankook ventus v12 be a problem in the rear?
concavity, csl, vb3, vmr, vmr wheels
Search this Thread:
