BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BMW F30 3 Series Coding DIY - Code Auto Start Stop, DVD, Folding Mirrors, Etc.
Extreme Powerhouse
      11-26-2014, 10:22 AM   #7657
shawnsheridan
General
shawnsheridan's Avatar
Originally Posted by quenotte View Post
Hi Shawn,
I received my new M235i yesterday!
Would you be so kind to send me last esys, PSdZData links ?
Many thanks in advance!
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      11-27-2014, 12:34 PM   #7658
agronom99
Drives: X3 30d
Hi Shawn,
please PM me esys & PSdZData too.
Thanks in advance!
      11-27-2014, 12:44 PM   #7659
shawnsheridan
General
Originally Posted by agronom99 View Post
Hi Shawn,
Thanks in advance!
PM sent.
      11-27-2014, 06:05 PM   #7660
MarkG_M5Comp
Supreme Being
MarkG_M5Comp's Avatar
1804
Drives: M5 Comp
Hi Shawn - would you mind helping me diagnose some errors getting with a new install?
I've installed the latest Esys and Psdzdata files onto a Windows 7 laptop and I'm seeing errors:
Mainly when clicking 'read SVT' I get a Psdzdata error.
Sometimes it reads OK but I then see an error when reading coding data.
Other times it doesn't even find the vehicle VIN to connect in the the first place.
All works fine on the old laptop with old program and data files so it's either something related to the new software configuration or the laptop. I have a suspicion it's an intermittent connection issue.
Any ideas? Images of errors attached.
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring
      11-27-2014, 07:50 PM   #7661
shawnsheridan
General
Your connection target settings are most likely wrong.
Select "TargetSelector:Project=F020-xx-xx-xxx, VehicleInfo=F020"
Do NOT select the Target with the "_DIRECT" suffix (e.g. TargetSelector:Project=F020-xx-xx-xxx, VehicleInfo=F020_DIRECT).
In the "Open Connection" window under "Interface" select "Connection via VIN".
In the "Open Connection" window under "vehicle-specific parameter (optional)" select "Series, I-Step Shipment", and leave the two Dropdown boxes blank.
Do NOT select "Read parameters from VCM".
In the "Open Connection", select "Connect" button.
      11-28-2014, 12:12 AM   #7662
MarkG_M5Comp
Supreme Being
1804
Drives: M5 Comp
Thank you,
So those errors indicate a connection issue rather than setup problem or corrupt files?
Reason for asking, I've already tried what you suggest but sometimes don't get that far with 'connect with VIN' occasionally being unavailable. Following the install guide, even the ENET config step sometimes fails to find the car.
I wonder if this could be an issue with this being a newer PC 'managing' the Ethernet port power and sending it into powersave or something.
Any other ideas?
      11-28-2014, 12:15 PM   #7663
TMD29
Don't care
TMD29's Avatar
Drives: 17 SO M3 ZCP
Hi Shawn, I need some help with getting hold of the E-SYS software, token and pin for a 2014 F32.
Thanks in advance
      11-28-2014, 12:19 PM   #7664
shawnsheridan
General
Originally Posted by MarkG335 View Post
Thank you,
Any other ideas?
Are you running the motor?
      11-28-2014, 12:21 PM   #7665
shawnsheridan
General
Thanks in advance
PM sent.
      11-28-2014, 12:45 PM   #7666
MarkG_M5Comp
Supreme Being
1804
Drives: M5 Comp
I've tried it running and with ignition only; same result.
Interestingly the ZGW_SEARCH application seems only to find the vehicle intermittently also. I'm leaning towards a computer hardware issue (I've tried it with two HDDs, Windows 7 and Windows 10 - again, same result).
      11-28-2014, 12:52 PM   #7667
MarkG_M5Comp
Supreme Being
1804
Drives: M5 Comp
I'm thinking I should re-download a fresh copy of E-Sys - can you please PM me with the very latest versions of everything?
      11-28-2014, 01:09 PM   #7668
shawnsheridan
General
That is normal behavior for ZGW_SEARCH, which besides being complete unnecessary for S-Sys, is the main reason it is no longer included in E-Sys package.
      11-28-2014, 01:11 PM   #7669
shawnsheridan
General
PM sent.
      11-28-2014, 01:15 PM   #7670
MarkG_M5Comp
Supreme Being
1804
Drives: M5 Comp
PM sent.
Thank you sir - I'll see if this solves my issues.
      11-28-2014, 04:53 PM   #7671
MarkG_M5Comp
Supreme Being
1804
Drives: M5 Comp
Didn't work, same issues I'm thinking this laptop just isn't built for it - cheap Dell sh1t.
      11-29-2014, 02:26 PM   #7672
quenotte
France
60
Drives: F87N M2 Competition
Hi Shawn,
I've properly set-up e-sys with pszdata v54.1
However my F22 M235i is from 11/2014 and V54.1 seems outdated.
I've some errors about missing CAFD files for FEM_BODY & HU_NBT.
In the meantime, I was able to code Digital Speed to Kombi.
Do you have the following CAFD files:
FEM_BODY:
CAFD_00000794_012_035_117
HU_NBT:
CAFD_00000DED_003_013_025
It would be nice to activate Auto Start/Stop memory...
      11-29-2014, 03:55 PM   #7673
shawnsheridan
General
Hi Shawn,
FEM_BODY:
HU_NBT:
These two CAFD are not part of any PSdZData release.
You can inject the following replacement CAFD's into the ECU's, VO Code them, and then you can FDL Code them:
FEM_BODY - cafd_00000794.caf.012_035_116
HU_NBT - cafd_00000ded.caf.003_013_024
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from above => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
Afterwards you will be able to FDL Code ECU.
      11-30-2014, 02:20 AM   #7674
quenotte
France
60
Ok Thank you Shawn.
On the other hand, do you have an idea when next psdzdata release will be issued?
      11-30-2014, 03:54 AM   #7675
shawnsheridan
General
Ok Thank you Shawn.
No, but if you are making an assumption that these two CAFD files will be in it and are waiting on it, that may be the case or it may not be the case. We have seen before with other CAFD files that car's received during production where those same CAFD files never appeared in any later PSdZData release. So you can wait and hope if you like, or just inject the replacement CAFD files into the ECU's as I wrote above. It has already been tested on several car's and it works fine.
      11-30-2014, 07:54 AM   #7676
nortin
nortin's Avatar
Japan
Drives: F30 320d M-Sport
Hi Guys,
I've got error in KOMBI as
KOMBI [60] [*******]
readCPS o.k.
cafd_000009c8-006_000_030 Fehler:
NCD read from ECU "ECUId:KOMBI_0x60" for CAF "cafd_000009c8-006_000_030" failed! [C069]
Error processing XML data [1660]
Do u hav any idea?
      11-30-2014, 08:00 AM   #7677
shawnsheridan
General
Originally Posted by nortin View Post
Hi Guys,
readCPS o.k.
Do u hav any idea?
.xml error is usually incorrect Connection parameters.
On E-Sys Toolbar Press the "Connect" Button and in the "Open Connection" window under "Target", select desired Target Vehicle based on car's Chassis.
(e.g. "TargetSelector:Project=F020-xx-xx-xxx, VehicleInfo=F020")
*NOTE: Do NOT select the Target with the "_DIRECT" suffix (e.g. TargetSelector:Project=F010-xx-xx-xxx, VehicleInfo=F020_DIRECT).
*NOTE: Do NOT select "Read parameters from VCM".
      11-30-2014, 08:33 AM   #7678
nortin
nortin's Avatar
Japan
Thanx Shawn,
But I succeeded other module e.g. FEM_Body,HU_NBT...
Any issue?
3 series coding, 3 series f30, 3 series f30 coding, 3 series f30 forum, 3 series forum, 3-series forum, 5 series f10 coding, ass, ass disable, auto start stop, auto start stop disable, bmw 3 series coding, bmw 3 series f30, bmw 3 series forum, bmw 3-series f30, bmw 3-series forum, bmw 5 series coding, bmw auto start stop disable, bmw auto start stop disabling, bmw coding, bmw coding directions, bmw coding diy, bmw coding instructions, bmw diy, bmw diy forum, bmw f10 coding, bmw f30, bmw f30 3 series, bmw f30 3-series, bmw f30 coding, bmw f30 forum, coding 3 series, coding f30, coding f30 3 series, disable ass, disable auto start stop, disable bmw auto start stop, disabling auto start stop, disabling bmw auto start stop, f10 5 series coding, f10 coding, f30 3 series, f30 3 series coding, f30 3 series forum, f30 3-series, f30 3-series forum, f30 coding, f30 forum, f30 forums
