Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > iPhone OS 3.0 and iDrive/6FL
      06-20-2009, 07:23 PM   #23
Kloogy
Kloogy's Avatar
Drives: 2011 BMW X5 Sport
I did the update and everything seems to be working fine as before in my E92.
2011 X5 Sport
Black Sapphire w/ Black Perforated Nevada/ DK Bmboo
Technology/ Vented Seats/ Cold & Convenience / Multi Contour seats/ 20" wheels and more...
2004 Mustang GT Vert. - Modded
      06-20-2009, 11:09 PM   #24
dw_soothill
Drives: 335d Touring
Ipod Touch 1G problems
I have similar problems with my 1G iPod touch since upgrading.
If I power the iPod off then back on and plug it in then it is found fine and there are no problems everything plays back as before.
Switch the car off and then back on again and now it cant find the iPod.
Reboot the iPod and its found again without any problems.
Guess I will be downgrading it to 2.2 until either Apple or BMW fix this issue.
      06-22-2009, 09:28 AM   #25
RonRed89
Drives: 09 335xi CPE
I just confirmed that an iPhone 3G upgraded to 3.0 works in my car for music functions. I don't have a 6NF option in my E92, but after plugging in the newly upgraded 3G phone into the 6FL, it immediately scanned the phone and made all music available.
So, looks like it's the Touch (2G for sure, 1G unknown) that has problems with 09 iDrive and 3.0 firmware.
Anyone else have any updates?
Ron
      06-22-2009, 02:14 PM   #26
iatacs19
iatacs19's Avatar
Drives: 2016 SO M4
I have a 2007 E90 with iDrive and 6FL, latest software version with wastegate fix.
I plugged in my iphone 3GS and it works except I cannot charge. Did the pin-out change for the 3GS?
I have never tried an iphone 3G.
I haven't tried my 3.0 updated 2G iphone yet, will try later this weekend.
For those of you that have a 3G, did you have to get a new 6FL cable? is there a new part number for the cable that works with 3GS?
      06-22-2009, 02:21 PM   #27
dwykstra
dwykstra's Avatar
Drives: BMW 335i
My iphone 3gs doesn't charge either. Works fine otherwise, but it won't charge even with the adaptor I purchased for the original 3g.
07 e90 335i Black Sapphire on Black Leather
ZSP/ZPP/CWP/Navi/Sirius/iPod/CA
20% tint/Blacklines/OEM spoiler/OEM style splitters
      06-23-2009, 09:01 AM   #28
RonRed89
Do you have an iPhone or Touch?
      06-23-2009, 03:53 PM   #29
Weaselboy
Weaselboy's Avatar
Drives: 2021 540i
Charging pinout changed from 2G to 3G and 3GS is same a s 3G. Neither 3G nor 3GS will charge with the 6FL cable.
http://www.cablejive.com/charge-converter
I bought this adaptor and it allows my 3G and 3GS to charge.
I am not aware of a new 6FL cable that fixes this issue.
      06-23-2009, 08:06 PM   #30
benji
Drives: 2009 328i E90
Having the same problem as described by several others -- upgraded iPhone 3G to 3.0, and now I get rapid flashing between the "Accessory Connected" screen and the iTunes playlist; sometimes iDrive says "Reading..." and then fails, but mostly it just says "Not Connected." And once in a great while, after a bunch of soft resets, it syncs up and works fine. Appears to be (as others have suggested) a handshaking problem, because once it works, it's rock solid.
Another thread (not necessarily related to iPhone 3.0 software) suggests starting a song on the iPhone before plugging it in. I will try it next time I'm in the car -- anyone else tried that?
Also noticed that bluetooth seems to transfer contacts fresh every time now, which makes for quite a delay when first trying to use the phone. I can live with that, but no music....
      06-24-2009, 09:20 AM   #31
RonRed89
Did not work for me on the Touch 2G doing this.
Obviously, it works if I disconnect the 6FL USB adapter. It will play through the AUX, but that's not a solution to any of our problems.
      06-27-2009, 10:28 AM   #32
Eddy Current
Eddy Current's Avatar
Drives: 2009 335i E93
Contacts no longer sync
I have an '09 E93, 335i. iPhone2.1/6FL combination worked fine for phone features. When I upgraded the phone to 3.0, I lost the ability to sync phone book. I'm going to downgrade the phone for now, and watch for a fix..
      06-27-2009, 10:38 AM   #33
Kloogy
Kloogy's Avatar
Iphone sir
2011 X5 Sport
      06-27-2009, 10:51 AM   #34
Weaselboy
Weaselboy's Avatar
Drives: 2021 540i
This combo works fine on my 2007 335i. Did you try deleting the phone from the car's BT paired list and repairing?
      06-27-2009, 11:50 AM   #35
Dwill335i
Drives: 2012 535i White/Beige
My phone book syncs fine after the upgrade to 3.0
2012 F10 Alpine White/Venetian Beige ZPP/ZTP/Sat Radio (previous 09 335i E92)
      06-29-2009, 03:56 AM   #36
scant
Drives: BMW 320i Touring (07/2007)
Hi all
New to the forum, also new to all things iPod/iPhone having just bought a 3GS.
My 2007 E90 Touring has bluetooth and the USB/Aux input in the centre console (armrest) and I was sold a "Cable Adapter for Apple iPod" from my local dealer (not cheap at £40/$65).
When plugging in, the 3GS states that the cable is not Apple authorised will not charge the unit. I also get interference every 10 seconds where the music will fade out and then back in.
On the plus side, I had no problems pairing the 3GS and all contacts are now available.
Any ideas on the cable/charging/fading issues?
Cheers
      06-29-2009, 04:47 AM   #37
Dwill335i
Not charging an iPhone is common. Even in my 09 with 6FL, it won't charge my phone. Also the popup message about it not being an authorized apple accessory is normal. Just dismiss the message.
The interference problem is something that shouldn't happen, though.
      06-29-2009, 05:05 AM   #38
scant
I wondered if it was something to do with the iPhone checking for new email every 15 minutes, but the fading happens more frequently than that...every 30 seconds or so!
      06-30-2009, 09:27 AM   #39
mkoesel
Moderator
Drives: No BMW for now
What's really strange, though, is that I know for certain that my 3G used to charge through my 6FL cable. It did display the message about the accessory being incompatible, etc., but it would indeed still charge the phone (albeit not very quickly).
But now it won't even do that anymore, and I am not sure if it is due to a change in OS 3.0, or if it was something that changed in a previous OS update and I just didn't notice until now.
Anyone else have the same thing happen? If so were you able to get the old behavior back, or is it a hopeless issue?
Thanks for that link. I suppose I'll just have to pick one of these up, since it doesn't look like there will be any other way to get my 6FL to charge my 3G like it used to.
      07-02-2009, 09:36 AM   #40
RonRed89
I submitted a request to BMW Customer Relations on bmwusa.com and got this message in response, so what we can see here is that BMW is aware of the problem
Rony:
Thank you for contacting BMW of North America, LLC regarding your 2009 BMW 335xi. We appreciate your inquiry.
Unfortunately, the 3.0 version of the Apple iPod software is currently not compatible with the BMW. BMW is currently researching to see what is able to be done with the software levels to assist with the compatibility to the iPod. I apologize for any inconvenience this may cause. Please stay in touch with www.bmwusa.com and you dealer for any further information as it becomes available.
If you have any further comments or questions, please respond to this e-mail or contact the Customer Relations and Services Department at 1-800-831-1117, Monday through Friday from 9:00 A.M. to 9:00 P.M., Eastern Standard Time. Again, thank you for contacting BMW.
Sincerely,
Christa McGrew
Representative
      07-02-2009, 12:05 PM   #41
dmurray14
The Stig
dmurray14's Avatar
Drives: Quickly
FWIW, after upgrading to 3.0 on my 3G, when I have an incoming call the name and number only show up about half the time now, the other half of the time I just get *****
      08-21-2009, 10:07 AM   #42
RonRed89
Has anyone been having success recently? After working through the case with BMW, I upgraded the phone to 3.0 on advice that BMW had made a change to the way that the ipod was recognized and beamed the fix to the car over Assist.
It actually sort of worked on 3.0 in that after multiple disconnects and resets, it would eventually connect to iDrive, but when you shut the car off and returned, you were met with the iDrive not recognizing the device again and you having to do those multiple soft or full resets on the Touch to get it back.
I've since gone back to 2.2.1, but am now running into the issue where many of my purchased apps require 3.0 and are now no longer working.
I have taken other people's iPhone 3G and 3GS devices and successfully plugged them into my car and they all seem to work (I didn't check the charging issue that others are having an issue with). This is really getting annoying.
Ron
      08-21-2009, 11:20 AM   #43
lucas.kent
lucas.kent's Avatar
Drives: M3
2016 BMW M3  [0.00]
I have the same exact problem and didn't think about how it might be related to the 3.0 upgrade until I saw your post....
      08-21-2009, 11:31 AM   #44
snappca
Drives: Graphite '08 135i Convertible
iPod Touch 2nd Generation
I just purchased a 2008 135i convertible that came with the 61.12.0.440.796 dongle and I'm seeing exactly the same issue with my iPod Touch 2G with 3.0 OS. I called my local BMW dealer and they said I needed part # 61.12.0.440.812 but I don't think she was knowledgeable of the exact issue that was occurring. I'd hate to blow $74 bucks on a duplicate dongle. Anyone else heard about this part number?
3.0, 6fl, idrive, iphone, touch
Search this Thread:
