BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Several warning lights - E91
      10-11-2010, 05:11 AM   #1
ilgidi
Drives: E91 320D Touring Msport
I have a 2008 320d e91 and recently was having problems with the OBC. Several warnings were coming up one after the other, including DTC, ABS, Cruise Control, Airbag, Power Steering. Naturally I took it to the dealer to get a diagnostics report. They said that all it needed was a software upgrade, something which left me dumbfounded as it did not make sense. Anyway, I paid for the service only to realise that the problem re-occured 2 days later. Has anyone had a similar problem? I called them again this morning to get it re-checked and the guy said that this type of fault is not good news.
      10-12-2010, 07:36 AM   #2
ilgidi
Please Help!
Has no one ever come across something similar?? Any help will do!
      02-03-2011, 05:57 PM   #3
sheerin
Drives: 2006 323i
I had that happen tonight with me 323i E90.
I'm taking it in tomorrow to find out what the heck happened.
      02-03-2011, 06:01 PM   #4
gunsekun
Drives: E92 335i
2008.. you must have factory warranty and no clue what's wrong with ur car..
      02-03-2011, 07:37 PM   #5
Juiced46
Drives: 03 Turbo Cobra, 2011 335xi
Do you happen to know what fault codes they found?
Also have you noticed if your clock reset at all? A weak/failing dead battery can possibly cause these warning lights. Or a corroded IBS cable. Check your battery for loose connections and corrosion. Quick easy check. It sounds like a battery problem to me.
      02-03-2011, 08:36 PM   #6
joegeeZe
14
Drives: 2007 328i
I just had something like this happen to me. I would turn the car on and back out of the driveway then get a bunch of lights/symbols. I got the ABS light, seatbelt light, airbag light, tire pressure light and a few others.
I took it to the dealer on a Saturday. He said he didnt have anyone in that could look into it further, but he said that its a low voltage problem. He basically didnt know why but said if it happens again to bring it in on a week day.
I got those combinations of lights and symbols on two occasions and on both occasions the lights eventually went away on their own.
      02-03-2011, 08:48 PM   #7
sheerin
Drives: 2006 323i
When it happened tonight, i had just repositioned my car on my girlfriend's driveway which is kinda steep.
It's really weird. I'm hoping it's nothing major as i'm out of warranty
e91, obc, touring, warning lights
