Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > N55 FBO turbo whine
      01-15-2014, 10:00 AM   #23
iuhutch
iuhutch's Avatar
Drives: 18%E2%80%99 F80 ZCP
Originally Posted by dewme5
What oil are your running now, and is it different then what you were running before the noise.
As a fairly cheap test, I would suggest a good oil change. Something that holds a better film may be all that you need to remedy. rated LL-01 and Full SAPS.
I run BMW's Castroil 5w-30 Full Syn. Car came with the maintenance warranty and they do the oil changes 1yr/12k miles. I also do 1 oil change myself in between that as 12k is redic, esp on a modified engine. I just changed my oil back in Oct (using the same oil) for the winter. Current oil has ~2k miles on it...
      01-15-2014, 03:29 PM   #24
iuhutch
iuhutch's Avatar
I've researched and read as much as I can find regarding this noise (Turbo sounds like supercharger, turbo whine, turbo siren, etc.). I found a video on another forum where a it mad a similar noise but was at a much lower RPM and had no load / was in neutral. That case ended up being a leaking WG.
I also just saw another similar issue with a chargepipe on the STi forums. This is interesting because my ER charge pipe does not fit perfectly flush against the throttle body. It is on good enough for the uclap to hold it on but the left side (or towards the front of the car) of the Charepipe is off the throttle body by maybe 1-2mm. It's been like this since day one (was my first mod) and again never made this noise when I was running Cobb.
Boosted and I plan to diagnoise a bit more this weekend. What i'd like to know are any idea's, tricks or ways we can further troubleshoot to identify rootcause. If it is truly the turbo going out then so be it but my intuition tells me that there something else that is either leaking or causing the turbo to work hard to meet target than it actually needs to... Just posting up a few updates on what i've found in research.
      01-15-2014, 05:34 PM   #25
iuhutch
iuhutch's Avatar
Sounds identical to this guys issue: http://www.focusst.org/forum/focus-s...e-install.html
The only part I did not install was the downpipe...could the down pipe be loose or have a bad gasket and great this noise?
      01-15-2014, 05:52 PM   #26
evo335xi
Drives: 335
Downpipe leak would make it sound boxerish/running on less cylinders or even like an open wastegate. The leak would be very audible underneath you.
It's possible the turbo is on its way out and causing some noise, my money is on the chargepipe/intercooler not being secure enough. Tighten everything down and see what happens!
      01-17-2014, 06:58 AM   #27
Tony@vargasturbotech
Drives: N54
I cant hear anything in that video and I turned it all the way up. If your turbo whistle is changing and getting louder, there is a reason for it, either you have a boost leak or your turbo could be on its way out.
      01-17-2014, 12:26 PM   #28
iuhutch
iuhutch's Avatar
Recorded some solid video under the hood this morning.
Still trying to diagnose the "whine" sound and where it might be coming from or what's producing the sound.
Gut tells me it's a leak at the charge pipe side.
Thoughts? Please help guys!
      01-17-2014, 03:50 PM   #29
iuhutch
iuhutch's Avatar
This just made my day/week/month so far. I've known something wasnt right with my car sounding like it had a supercharger
Looking back, it was good practice going back through all of the induction and piping. As you can see in the video below, the CP was WAY too loose. I was able to ever bolt the middle section down due to how kinked the piping was from the intercooler. Car feels butter smooth now, appears to build boost much more smoothly, throttle response and power all seemed to be increased. Not sure exactly where the leak was but i'm pretty sure I was loosing power and overworking the turbo to meet target with a leak. Any other ideas? on what this was impacting?
Look at how loose the ChargePipe was!!
First start after redoing induction system and piping. Much better
      01-17-2014, 06:08 PM   #30
evo335xi
Drives: 335
Good, glad it got sorted out!
      01-17-2014, 07:16 PM   #31
say_oh_shin
Drives: 2011 335i
glad you got it figured out -- good work
      01-18-2014, 12:23 AM   #32
iuhutch
iuhutch's Avatar
Thank you for your thoughts. I agreed with your assessment and you were right
Hope this helps others...
      01-21-2014, 09:27 PM   #33
Andrewe92
enthusiast
Andrewe92's Avatar
Drives: 2011 e92 lci 335xi
OP soo your final verdict is that you had a boost leak and that was over working the turbo?
      01-22-2014, 02:24 PM   #34
iuhutch
iuhutch's Avatar
That or it was just enough of a leak to allow air through causing the whistle. It's hard to say because we re did the intercooler piping, ChargePipe connection and intake connections. Whine is gone and the car does feel a little more peppy
      01-22-2014, 02:28 PM   #35
Andrewe92
enthusiast
Andrewe92's Avatar
I think it was a very small leak.. enough to be making that sound. but not enough of a leak to throw a 30FF boost leak code or lower your psi. eh whatever glad you got it worked out!!
      01-29-2014, 03:44 PM   #36
madmanhiker
madmanhiker's Avatar
Drives: '11 E92 335i
I'm FBO and I don't have a sound like that... not xi though, and I have exhaust. But that whine was easily reproducible is 3 of your runs. I'm stumped. It pulls fine, psi looks good. hmmm...
edit: I've suffered several boost leaks in the past, and NEVER have I heard a whine like that. It almost sounds like an impeller or oscillation under stress. definitely rotary, not wind, not boost leak. just my .02
-madmanhiker jax,fl
      01-29-2014, 06:26 PM   #37
iuhutch
iuhutch's Avatar
It's been a week (with multiple WOT pulls) and the noise hasn't come back. Car seems to be much more happy too. Who knows, I'm glad it's gone
      01-31-2014, 01:35 PM   #38
Bobby_Sardells
Bobby_Sardells's Avatar
Drives: 2017 BMW M3 30 Jahre
This is great I'm glad you figured it out. Im off to go mount a go pro in my engine bay now lol
Minus the whistle the sound was incredible in there!
      02-24-2014, 08:05 PM   #39
kiggy74
Drives: 2011 335i Xdrive
I've noticed a similar sound on my '11 n55 sedan, except mine is stock except for a jb4. Also seems to only happen in 3rd gear WOT.
fbo, n55, turbo whine
