N55 VANOS Bolt Failure Prevention
05-08-2014, 07:41 AM | #155 |
Rep 1,192
Drives: 2011 335i MT
Here is the official recall notice at NHTSA:
http://www-odi.nhtsa.dot.gov/owners/..._ids=14V176000
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
05-10-2014, 07:55 AM | #156 | |
Libertarian
132
Rep 1,577
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k Last edited by GB-335xiCoupe; 05-10-2014 at 07:59 AM.. Reason: additional info added |
05-10-2014, 08:12 AM | #157 |
Rep 459
05-10-2014, 08:35 AM | #158 |
Libertarian
132
Rep 1,577
Well hopefully they don't "just miss" it in the recall...
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
05-10-2014, 10:32 AM | #159 |
Rep 1,192
I'm sure that is a clerical error.
05-19-2014, 11:32 PM | #163 |
Libertarian
132
Rep 1,577
06-05-2014, 10:19 AM | #164 |
Initial G
Rep 41
A couple days ago, I got the half engine light/reduced power situation on my 2011 N55 335i (build date 10/10) so I suspected the VANOS issue and pulled over. I turned off the car and started back up to see if the problem remained. The half engine light/reduce power mode remained and the engine's rpm rose and fell for a few seconds until settling. I was able to drive home and drove gently. Unfortunately, I mistakenly cleared the engine codes while readying the car to be taken to the dealer to be looked at. After that the car started up fine and the half engine light/reduce power mode disappeared and hasn't reappeared. Do the symptoms sound like the VANOS issue?
I called BMW yesterday about the recall and they told me I will get the official letter by end of June. She couldn't confirm whether I'll get the actual VANOS fix or the extended warranty. |
06-06-2014, 02:38 PM | #165 |
Rep 1,086
Drives: '11 335i M-Sport [LeMans Blue]
I just got the official letter today. It says they don't have the parts available yet but hope to have them soon.
06-06-2014, 02:44 PM | #166 |
17
Rep 187
Drives: SGM e92 335i M-sport
06-06-2014, 04:26 PM | #167 |
Rep 34
I just a letter today too, the letter states my car is affected but it didn't show up here:
http://www.bmwusa.com/standard/conte...er/recall.aspx |
06-06-2014, 07:45 PM | #168 |
72
Rep 278
Ok. Here is my situation. I live outside the USA. I had exported my 2011 335i to Jamaica and the local dealers here says they know nothing of this recall. I would like to know if there is a way to find my build date other than the door sticker? My sticker is not readable.
Also if I wanted to have the bolts replaced myself at my own risk where can I get said bolts to buy? Thanks
(JB4 stage 2, in my garage)Now CoBB V3 , VRSF 3.5" Stainless Steal catless DP, 7" VRSF FMIC with upgraded lower CP.
06-06-2014, 07:47 PM | #169 |
Rep 158
Drives: 2011 335i Sedan
06-06-2014, 08:21 PM | #171 |
Came to the N55 Darkside
1112
Rep 12,740
Just made a thread on this- just got my letter in the mail today- guess all us tri-state folks got it at the same time
Evidently, parts are not available, and there's no ETA... this could take a while gents. |
06-06-2014, 08:31 PM | #172 | |
Rep 960
06-06-2014, 08:32 PM | #173 | |
Rep 960
06-06-2014, 08:34 PM | #174 |
1112
Rep 12,740
According to the letter, the job will take four hours- give or take.
That said, they don't even have the parts yet- and God only knows when they'll get them in... |
06-07-2014, 10:34 AM | #175 |
72
Rep 278
That is certainly not encouraging even for me. Question are these bolts only unique to the N55? Can it be source from like a N54. I could prob salvage it.
n55, solenoid, vanos |
