brake vibration after new replacement parts help
12-17-2014, 08:46 AM | #1 |
15
Rep 78
hey guys, looking for some informative direction on a brake job problem i have. i have just replaced the front rotors/brakes/sensor with proper Brake Disk Quiet application, followed by brake bedding. I used BMW rotors and Textar oem replacement pads from Turner Motorsport (i ordered oem, they sent Textar "oem supplier). earlier this year i did the rear with all BMW parts and no issues.
Here's the problem. Even after bedding i had brake squeal. I thought maybe i didn't do it firm enough so i did again, not really any harder or abusive. The squeal has gone away but now i have a steering wheel vibration upon braking. It happens more at lower speed, but a little at higher speed too. Before i take apart the brakes and re-install is there anything recommended i try? one concern i have is i may have warped the rotors by bedding. I'm pretty careful and particular so i doubt i abused them. I did 5-6 rounds of rolling 60-20 mph braking followed by proper cooling at the end. i will probably try: another bedding process reinstall rotor turning but i don't think its recommended on our rotor material. lastly, replace the textar pads with bmw pads Key info in my situation: i replaced parts like for like, i had brake squeal, now vibration that i didn't have before. Car was basically perfect before this, no wheel balance issue. Help? |
12-26-2014, 07:50 PM | #2 | |
Rep 399
12-27-2014, 10:04 AM | #3 |
15
Rep 78
Thanks for the insight. I swapped the pads to the other side of the car. The vibe is a little better. I will see how it goes over a couple weeks. Then maybe bed them again. I may mic the rotors and see if there's any sign of warp next. Maybe some new pads.
12-27-2014, 10:36 AM | #4 |
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
Did you use a torque wrench to tighten the lugs on the wheels to get the correct tightness on each lug? If the lugs are unevenly tightened, it is possible to cause a warped rotor.
Never actually heard of that happening on a BMW because they have much more robust brakes than most cars sold in the US, but it may be possible.
01-04-2015, 09:01 PM | #6 |
15
Rep 78
I put on the old rotors with the new pads to see what'd happen. Sure enough the vibration went away. From here I Will maybe put a dial indicator on the new rotor out of curiosity but I probably just but new rotors and call it a day
brake, pad, squeal, vibrate, vibration |
