Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Canadian DRL Delete
      01-07-2011, 12:17 PM   #1
Noxious_
27
Drives: 08 E90
Canadian DRL Delete
Has anyone been able to delete their DRL's on a Canadian Vehicle???
I have been to two reputable shops here in Calgary and both shops have been unable to code off the DRLs. I am beginning to wonder if this is even possible on a Canadian vehicle.
If anyone know how to or knows someone who could do this please speak up. I have NCSEXPERT and the DCAN cable but I cant even figure out how to get the program to recognize the car with windows 7.
The car is an 08 E90 335xi btw.
      01-07-2011, 12:18 PM   #2
Noxious_
27
Drives: 08 E90
Both shops tired to delete the lights using the autologic program
      01-07-2011, 02:51 PM   #3
gaifaun
gaifaun's Avatar
207
Drives: E90 335i LCI
are you talking about deleting your amber corner lights? because delteing the DRL's will delete your angel eyes unless you switch it on manually.
also, its has been done by many members. If you're in canada, check out Dimsum's coding service. You can also purchase the cables from Patrys yourself and he will help you code the car.
I can help with Coding in Vancouver. PM me
      01-07-2011, 03:47 PM   #4
Noxious_
27
Drives: 08 E90
No I have a preLCI with the daeos kit so deleting my drls won't delete my angels, only the H7 halogen.
Ive sent messages to Patrys but had no response. But thanks, I will check out DimSum and see if he can shed some light.
      01-07-2011, 03:51 PM   #5
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
636
Drives: BMW M3 | X5 xdrive 35i MSport
they werent able to do it with autologic? I had mine done with autologic and it works fine
In this video you can clearly see them using autologic to turn off my DRL
      01-07-2011, 05:59 PM   #6
c_rob85
Drives: 07' 328I
Very interested in this thread as well... hope you find a solution.
      01-10-2011, 04:45 PM   #7
Noxious_
27
Drives: 08 E90
Thanks but the video doesn't show much. Plus that video is showing the corner delete when I am trying to delete my h7 halogen lights.
I am wondering if they are unable to access the correct module because I have my Daeos system connected when they are trying to do the code.
Or is this the type of thing that requires NCSEXPERT (which I havent been able to figure out on a 64bit copy of W7.
      01-13-2011, 07:49 PM   #8
c_rob85
Drives: 07' 328I
Any progress on this Noxious? I'm pretty curious to see how you make out. Would love to do this to mine as well.
      01-13-2011, 11:00 PM   #9
Noxious_
27
Drives: 08 E90
Ive been having trouble using NCSexpert on my windows 7 pc. Ive just got that working tonight so Im just ready to try to follow one of the tutorials. Im going to do the eurolights first and once I got that Ill do that DRL delete.
      01-23-2011, 04:11 PM   #10
matrix76
matrix76's Avatar
61
Drives: 2020 Z4 M40i Black/Red
Delete DRL HB's
In the coding for DRL HB delete , it is TAGFAHRLICHT_ECE_1 in CAS/NFRN but at this point I am unable to turn on AE's as DRL's.
Brian
Black Sapphire, Black w/Burrwood Trim & Shifter, 162's, Mtec H8 AE's, DS1 HID 6000K
      01-23-2011, 05:44 PM   #11
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
I got my DRL turned off by using NCS expert (Dimsum hooked me up).
Do you have the k Dkan cable?
      01-23-2011, 05:56 PM   #12
matrix76
matrix76's Avatar
61
Yes, all coding done except for the AE's as DRL's, if it is even possible.
Brian
      01-24-2011, 08:13 AM   #13
c_rob85
Drives: 07' 328I
Couldn't you use the Daeos Harness to get your AE's on?
      01-24-2011, 08:35 AM   #14
DrDurt
DrDurt's Avatar
Drives: e90 325xi
wait...your saying you want the center highbeams off? Cant you just do that through idrive or the stalk on the steeringwheel column?
      01-24-2011, 08:48 AM   #15
matrix76
matrix76's Avatar
61
Not sure what that is, , ,
Do not have iDrive, coding was the only way to do it , ,
Brian
      01-24-2011, 09:14 AM   #16
c_rob85
Drives: 07' 328I
Not on Canadian cars, its not an option for us. DRL's are mandatory .
      01-24-2011, 09:17 AM   #17
c_rob85
Drives: 07' 328I
http://www.jlevistreetwerks.com/3-Se...duct_info.html
I think that it should work...maybe not though. But if you have coded out the DRL I would think this should work for you to get the AE's on.
      01-24-2011, 09:50 AM   #18
matrix76
matrix76's Avatar
61
Do you think this will work with lights set in AUTO mode?
Brian
      01-24-2011, 04:29 PM   #19
Noxious_
27
Drives: 08 E90
You need the Daeos harness now. There is a DIY that requires some wiring but it is just easier and less messy to order the daeos.
I cant get ncs running or communicating with my car. I have downloaded the drivers for the DCAN cable so well see if that helps.
Every time I start NCSEXPERT on windows 7 virtual XP mode it says cannot find api.dll or something similar to that. I am thinking this is a registry error. Anyone know how to fix it?
      01-24-2011, 10:38 PM   #20
xxxjecxxx
xxxjecxxx's Avatar
Drives: F30 335i M sport
2013 BMW 335i  [0.00]
2006 BMW 325i  [0.00]
read the tutorial. one of 3 things.
1) you are running 64bit , not compatible
2) you do not have ";C:\ediabas\bin" in your system path
3) you did not download the complete version of NCS, another member had the same issue.
      01-25-2011, 12:23 AM   #21
miguex@ecuprogram
miguex@ecuprogram's Avatar
37
Drives: 2010 X5 M
Noxious, I live in Calgary and I can help you (my NCS Expert works perfectly) . just PM me.
      01-25-2011, 01:16 AM   #22
SaviorSelf
SaviorSelf's Avatar
Drives: 2007 BMW 335i
I'm kinda experienced in using NCSExpert. Is there a way to code the Halogen DRL off and code it so the AE's act as the DRL or is it only done thru hardware?
*Sorry for the threadjack.
canada, drl, h7 bulb
