PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
Unsprung weight from wheels
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
02-29-2012, 11:43 AM | #1 |
Rep 444
Just a little blurb I saw in European Car
"What you need to know is that changing to tires that are 1 lb heavier will effectively add 8 lb to the car (four tires, remember) and that adding a pound to the wheels will effectively add somewhere around 6 lb to the car." Read more: http://www.europeancarweb.com/tech/0...#ixzz1nnHB34FA
2017 Mineral White M3
Mods to COME |
02-29-2012, 01:35 PM | #3 |
Rep 444
I figured it wasn't new but I have seen different people give different answers as well as people always asking
Mods to COME |
02-29-2012, 02:04 PM | #4 |
2006 330i, TSM, Black, manual, sport
874
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
Preaching to the choir for me!
Many, many, many of people on here are more worried about looks. Thanks for posting.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
02-29-2012, 02:44 PM | #5 |
Rep 444
Currently I have VMR 718 19'' but will probably be going to an 18'' sub 20lbs but am on a budget...There are a few options though
Mods to COME |
02-29-2012, 02:59 PM | #6 | |
Rep 1,029
Remember to factor in tire weight as well. |
02-29-2012, 03:08 PM | #8 |
Rep 444
Im running V12s. Assuming I run them again I will be getting a smiller tire Diameter but more rubber so maybe they will be roughly the same weight..According to tirerack the weight will be +/- 1-2 lbs per tire
Mods to COME |
02-29-2012, 04:29 PM | #10 |
Rep 444
This is specifically about unsprung weight and the debate of what is the ratio of unsprung weight difference compared to regular weight. Some say 1:10 some say 1:8 etc...
No need for the sarcasm and smart ass remarks
Mods to COME |
03-01-2012, 11:53 AM | #11 |
Moderator
369
Rep 4,745
While this may surprise some, the weight of a tire is actually a poor indicator of a tire's real world performance. Using tire weight as an important factor to consider when buying a tire sounds beneficial in theory, but other factors like grip, handling, and steering response have a much greater effect on performance. I've been testing tires on identically setup BMW test cars for over ten years and have found no correlation between tire weight and real world handling on the track or on the street.
Sometimes the heaviest tire will have the best handling and fastest autocross times in a given test; sometimes the lightest tire will. Just one example of the lightest tire performing the worst in a test would be in a recent test is a test of extreme performance summer tires, which many use for autocross. In this test the lightest tire, the Kumho ECSTA XS, came in dead last, while the heavier Bridgestone RE11 and Yokohama AD08 were better. (link to test http://www.tirerack.com/tires/tests/...iate=FH8<br />. ) Keep in mind that while wheel weight can be an important factor to consider, tire weight should actually be one of the last things to consider when making a tire purchase decision. Dry grip, wet grip, and steering response are more far important factors for an enthusiast trying to maximize performance.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
03-01-2012, 12:28 PM | #12 | |
Rep 444
Mods to COME |
03-02-2012, 10:00 PM | #13 | |
Rep 169
"All our knowledge has its origins in our perceptions."
-Leonardo Da Vinci |
03-03-2012, 07:23 AM | #14 |
874
Rep 3,699
Thanks for the info Gary. I never really looked at tire weights, just performance and your tests have been a fantastic tool!
I'm running Michelin PSS purchased from Tirerack (actually I've been buying all my tires from Tirerack for about 10 years), I am very happy with them!
03-03-2012, 08:35 AM | #15 |
Rep 1,556
The nice thing about switching from RFTs to normal tires, aside from the ride, is that regular tires are always lighter by several pounds. You can absolutey feel the difference between a 30 pound runflat and a 23 pound normal tire when accelerating from a stop.
03-03-2012, 02:47 PM | #17 |
Rep 1,556
03-03-2012, 04:21 PM | #18 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
Great post. I'm kicking around the idea of replacing my wheels in order to drop un-sprung weight. I can drop roughly 6 lbs per wheel, going from my type 161s to lightweight replacements...but I wonder, is it worth the 1k+ cost .... will I really see a measurable change in performance?
Has anyone out there tried to measure the benefits in terms of acceleration, braking, gas mileage etc? I know Car and Driver (with TireRack's help) put something together showing a trade-off for larger diameter wheels (due to weight increase); does anyone else have before and after experience they can share regarding the benefits of lowering weight? |
03-03-2012, 05:02 PM | #19 | |
Rep 444
In actual Quarter mile times etc you might gain 1mph and a 1/10 second but nothing real special. Getting new rims in your case though can be both aesthetic and functional (greater width etc)
Mods to COME |
05-09-2012, 09:30 PM | #20 | |
20
Rep 220
I am shopping for a light setup fro street use. I have come up with the Apex EC-7 18" with square wheels (18-21lbs Forged) and the 245/40/18 Pirelli PZero Nero All Season as RFT replacments. Still reasearching the best combination wheel/tire widths fo rthe best looking fit I can use all year. The wheels did not release pricing yet but, thinking about 300 per wheel and $700 for 245/40 tires. 45lbs 18" $1200+700= Now that is equvalent to a 17" custom gravity forged wheel and tire in an 18" stance 41lbs 17" $1100+600= I actually got the 18VMR Staggered and the Hankok evo 110. Hated them, felt like the brakes were stressed and was not confident on the high speed cornering. 52lbs Thats a 7lb unsprung difference per wheel Plus the better fuel economy and less wear Also came a cross a dunlop kevlar that is 20% lighter. probable about 20lbs A 35lb setup would be ideal all around. IMHO...Any feedback on these gary? Last edited by VaDuro; 05-09-2012 at 10:04 PM.. |
rims, tires, unsprung, weight, wheels |
