GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      09-06-2014, 03:20 PM   #89
BigMacSmallFries
123
Drives: '19 M5C 911 Turbo F430 GT3 RS
Originally Posted by -JLT- View Post
You are correct. That's why I went with them.
Ok, I get it now. Your setup looks good. I think I'm going to look into the KW Sleeve kit, that may be the best solution but otherwise I will go with H&R. Can drop the front a lot more than the rear and have a spring system that works well not only with the OEM dampers but the front in tangent with the rear.
      09-06-2014, 11:51 PM   #90
BigMacSmallFries
123
Hmm... Tempted to get the 435 sport springs as well. On your car the rear looks almost OEM with the 435s. Just the front is dropped nicely. Sounds like the KW sleeves will be in stock very soon. Maybe I should just wait until I can get those...
      09-09-2014, 11:49 AM   #91
pigwet
Drives: MW F80, CP, DCT
Awesome thread. Thanks Tom.
      09-23-2014, 02:06 AM   #92
Assari
Assari's Avatar
Russia
17
Drives: AW/SS F80 M3 DCT
For stock 18's running KW HAS what spacer size would be the most aggresive but at the same time safe without rubbing while having two adults in the back seat.
Thanks!
      09-23-2014, 11:11 AM   #93
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Thanks!
Depends on overall ride height. Either the 12/15mm combo or you can utilize 10/12mm if you want to be a bit more conservative.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      09-23-2014, 04:36 PM   #94
Assari
Assari's Avatar
Russia
17
Thanks a lot for the reply! Have you done any similar installs, maybe you have some pics to post of the setup?
      09-23-2014, 04:57 PM   #95
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
HAS kits haven't yet been released from KW, but it has no effect on spacers as it would be no different than a lowered setup with springs (with adjustibility).
      09-26-2014, 03:02 AM   #96
htran797
Drives: f82,is350, e46 m3 sold
Anyone have their m4 on the H&R super sport spring 1.6" front and 1" rear? With these springs, what is the most aggressive spaces I can go with?
      09-26-2014, 12:24 PM   #97
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
What wheels (size/style) are you running now? Same tires?
      09-26-2014, 12:26 PM   #98
htran797
Stock 19" wheels
      09-26-2014, 12:37 PM   #99
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Stock 19" wheels
Should be ok with the 12/15mm combo.
      09-26-2014, 12:39 PM   #100
htran797
Stock 19" wheels
Also if later on I want to up my tire from 275 to like 295 would the 12mm still work for the back wheel?
      09-26-2014, 01:25 PM   #101
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
You will need to step down the rear spacer as the intention is to go flush with the current setup.
      09-26-2014, 01:27 PM   #102
htran797
So with 295 rear what size spacer should I go with?
      09-26-2014, 01:54 PM   #103
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Would recommend dropping down to 10mm with the 295s.
      10-07-2014, 06:56 PM   #104
GGreek5
Olimpiakos
GGreek5's Avatar
Greece
91
Drives: M3
M3 on stock 19s with h&r supersports. What is the most aggressive I can go for spacers?
TIA
      10-07-2014, 07:23 PM   #105
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
TIA
You can probably get by with 15/18mm depending on aggressiveness. Would recommend 12/15mm instead.
      10-08-2014, 04:02 PM   #106
Meanie
Meanie's Avatar
South Africa
547
Drives: BMW G82 M4C
Hey guys,
Has anybody noticed an increase in debris and/or dirt with 15/12 spacers? Any damage from kicking up anything?
Waiting for my spacers to come from EAS and just wanted to see if there was any feedback.
- 2021 G82 ///M4C - AW, ZF8, CF Trim - CURRENT
- 2018 F87 ///M2C - HS, DCT, Blue Stitching - SOLD
- 2015 F82 ///M4 - AW, CF Trim, DCT, MPE, M Perf Exterior Trims - SOLD
- 2008 E92 ///M3 - AW, CF Leather Trim, 6MT - Mods: Black Grills, Black Gills, CF mirrors - SOLD
      10-08-2014, 05:41 PM   #107
AntoM3
AntoM3's Avatar
Drives: 2013 F10 M5 + 2008 E92 M3
What would be a good spacer set up for F80 M3 + H&R Super Sport Springs? On Stock 18's.
08 AW E92 M3
13 AW F10 M5
davem3fan185.50
      10-08-2014, 05:45 PM   #108
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Pretty much identical to what GGreek5 was asling a couple of posts back - the rolling diameter is similar between 18" & 19" .
davem3fan185.50
      10-08-2014, 07:00 PM   #109
M3ryder55
Drives: 15' MW/SO
need to order some soon
imo 435i H&R springs > M3/M4 springs .... that rake is killing me. Coilovers need to hurry.
      10-13-2014, 12:58 AM   #110
kinimod
Drives: 911 GT3
Are you guys deciding on this solely based on looks and appearance?
To my understanding, the geometry and handling changes, scrub radius becomes different -- I would guess it makes sense to actually make some calculations to determine the final geometry and preserve either positive or negative scrub radius. Not just randomly install any spacers.
A zero scrub radius could (based on my "investigative" studies) introduce unstable steering as the tire fights itself. As per the article on H&R website: http://www.hrsprings.com/technical/scrub_radius
aggressive, eas, extended lug, lugs, macht schnell, offset, spacers
f80post
