SOS Call System malfunction after combox retrofit
10-09-2014, 10:56 PM | #1 |
Rep 508
I retrofitted TCU + MULF modules to a Combox Telematics in my 2011 BMW 335i. Connected everything correctly. Added appropriate options to the Vehicle Order and re-coded kombi, frm and all other related modules with expert mode. All is working as expected; however, I am getting this "SOS Call System malfunction" error. Does anyone know how to get rid of it? Thank you in advance for your replies ...
10-10-2014, 06:54 AM | #2 |
Rep 13,100
Do you want your SOS to work ?
Do you want your SOS to work?
If you don't you can code the Kombi Module to not display the error. http://www.e90post.com/forums/showthread.php?t=805677 note the last entry is the actual solution. Or you might look see what state those parameters are in. |
10-10-2014, 11:04 AM | #3 | |
Rep 508
The values I changed were in the KOMBI (thanks for the links!). Setting the following two values as below successfully turned off the SOS error notification. TCM_ALIVE_MONITOR -> nicht_activ TCM_ID_MONITOR -> nicht_activ |
10-11-2014, 02:59 PM | #4 | |
Rep 508
However, in my case, since I have replaced TCU with Combox, I needed to disable following two parameters in Kombi: COMBOX_ALIVE_MONITOR -> nicht_activ COMBOX_ID_MONITOR -> nicht_activ Took a wild guess and figured it out on my own |
combox, mulf, retrofit, sos, tcu |
