RB Turbo or Upgraded turbo question RE: Do yours leak oil?
08-26-2011, 02:12 PM | #89 | |
Rep 5,876
08-26-2011, 02:16 PM | #90 |
3441
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
08-26-2011, 03:06 PM | #92 | |
Rep 5,876
but in any case, the solution really might not be something that keeps the stock look and frankly I couldn't care less IF that turns out to be the only solution... |
08-26-2011, 03:18 PM | #93 |
3441
Rep 79,211
08-26-2011, 03:28 PM | #94 | |
Rep 5,876
Look what I just googled, find it interesting...might pertain to us as well:
http://www.max-boost.co.uk/max-boost/turbo/turbo.htm Quote:
08-26-2011, 03:43 PM | #95 |
Rep 1,571
There have been points where I've considered some people may have slightly overfilled the crankcase, blocking drains that are already being overworked from the bigger turbo internals. But that is kind of hard to confirm with an electronic dipstick thats seems less than accurate. Which is why I've said to error on the slightly underfilled method (not enough to cause codes/lights/etc).
08-26-2011, 03:47 PM | #96 |
Rep 3,456
Drives: Harrop E90 M3
I can assure you this is not the case with the car in question...
08-26-2011, 04:00 PM | #97 |
Rep 1,571
Not saying this car has or has not, there are plenty of factors to consider all around. But anyway I was speaking in general in response to the above dzenno quote. I am curious as to how you assure such a thing? Not speaking in jest, I'm speaking from a let's figure out all the do's and don'ts- and how's to make it happen... and I don't have a solid "how" to figure out oil level when the electronic gauge seems to be not very picky unless a qt low. I'm quite certain the crankcase can be at least slightly overfilled and not cause warnings, but could be wrong and would appreciate your input on how to rule it out.
08-26-2011, 04:12 PM | #98 | |
The Engineer
26
Rep 329
Drives: AW 07' 335i
08-26-2011, 04:18 PM | #99 | |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Dzenno,
Nice find. I saw this in the article: Quote:
Anyone still not convinced about the OCCs?
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
08-26-2011, 04:41 PM | #100 |
Rep 1,571
That is the exact premise of why OCCs maybe causing a problem (they certainly aren't helping). They are a restriction to the PCV system. This means worse vacuum in the crankcase at high engine loads when the rear inlet turbo vacuum pull is the only thing venting the crankcase. The high(ER) crankcase pressures affect gravity draining returns. Upgraded turbos have bigger internals that pass more oil, which thus need more drain potential- which can push the limits of the drains as is. This maybe compounded with unnecessarily high oil pressure/flow which as a fix we can restrict back if applicable. But adding in a further restriction of OCC is not helping- really anything.
08-26-2011, 06:55 PM | #102 |
ASR Turbos+LSD+Meth= :D
73
Rep 1,517
Drives: E92 335i
2007 335i Coupe Mods: Check the Garage |
08-26-2011, 07:51 PM | #103 |
16
Rep 159
"There is a good possibility they do, however, the cats will mask the smoke more than catless. I beleive Anemouse runs a completely stock exhaust with RB turbos, maybe he can chime in."
Stock exhaust with catless resonated DPs and I got rid of my OCC few months back. I haven't noticed any smoke. Also I have never had the car over 17 PSI, most of the time on the RBs I was running 15.5 PSI, only now with Meth I run 16.5-17 PSI. Given Rob's earlier post i am in no hurry to increase the boost or get rid of my stock exhaust. I'll keep the bad fuel economy and slightly less power for the sake of more back pressure until this issue is identified and resolved. A. |
08-26-2011, 08:33 PM | #104 |
Rep 5,876
What I think about the drains is that they really either need to be enlarged slightly (safe but takes away from the OEM appearance, personally don't care) OR you restrict the oil feed (very risky as journal bearings need considerable oil unlike ball bearing)...this is why for ASR it was easy to go with option 2 as their units are ball bearing and don't carry the same risk as RBs when it comes to oil starvation
08-27-2011, 02:14 PM | #105 |
Rep 444
Would changing from a 3.0 to a 2.5 inch DP exhaust help at all with back pressure and help crankcase pressure?
2017 Mineral White M3
Mods to COME |
08-27-2011, 03:15 PM | #106 |
Rep 5,876
Doubt it'd change it much if at all..3" DPs today all taper to 2.5" at the exhaust flanges..but it'd be interesting to try I guess...i used to have 2.5" catless UR DPs before on stock turbos and never lost much oil or noticed smoke
08-31-2011, 02:18 PM | #107 | |
Rep 5,876
08-31-2011, 02:24 PM | #108 | |
Rep 6,773
OCCs ..Downpipes.. Exhausts..PCVs..Oil feeds etc etc etc..so what?? the whole car has to be redesigned to make it work w these turbos...what about the turbos themselves..is it not possible there is some inherent design flaw in them..talk about denial exterme..think horses people not zebras. geeezuzz |
08-31-2011, 02:29 PM | #109 | |
Rep 5,876
08-31-2011, 02:31 PM | #110 |
Rep 6,773
ar design, oil burning, oil catch can, rb turbos, turbos |
