Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Need help figuring out rim/tire config
      09-16-2014, 07:21 PM   #1
pry_vit
pry_vit's Avatar
Drives: F30 335i xDrive
Hello everyone,
So before I start getting flamed, yes I have used the search tool and spent countless hours trying to figure this out. I recently got a '11 e92 328i LCI RWD with ~33k miles. I have the style 338 rims (225/45/17 with 34mm offset and 8" width), but I'm not really feeling them. Since I will need new tires soon, I decided to upgrade the rims as well. I like the Avant Garde m359 style rims. The only issue is that I cannot figure out the configuration for what exactly to buy. I do know that my e92 has the m sport suspension though, not sure if this makes a difference or not. So I am interested in 19" all around. Could someone please tell me if this is possible and the exact configuration I would need all around so that my car is usable as a daily, no rubbing nor extreme low profile.
I am even more confused in regards to the tires. If front wheels are different from rear i.e. 19x9 vs 19x10 or the offset is different, does this mean I cannot rotate my tires? Since it is RWD, is it a better idea to get wider in the rear with directional tires (so that I can swap side to side by removing off the rim) or same width all around so that I can cross-rotate between front and rear axles?
I apologize if this is confusing. My main goal is to get 19" m359 (not feeling the look of 18") and if it possible to have a reliable, daily setup with them. Oh and I am hoping to put performance all seasons on them, not summer tires. Please help me figure this out and thank you in advance!
-Vitaliy
      09-16-2014, 10:06 PM   #2
bmw325i
Drives: 2006 BMW 325i
Bolt on fitment with no spacers
9et35 245/35/19
10et38 275/30/19
If you use spacers or lower offsets go with 235/35/19 and 265/30/19.
      09-20-2014, 03:15 PM   #3
mbanks21
1268
Drives: 2015 335i MSport
If the fronts and rear are different sizes you cannot rotate them. The sizes posted above are your best bet if you want staggered. If you plan on lowering the car the smaller tires (235/265) would be easier to fit with modification.
      09-24-2014, 04:25 PM   #4
EMITTR
EMITTR's Avatar
Drives: 11 335is Coupe BSM
No you cannot rotate front to back but you can swap front left to right or right to left and do the same to the rear - this helps eave the wear imposed by your wheel camber. As far as tire and rim and aspect the below URL is a good tool. If you go with a low offset you are going to rub on wider tires. You should be good with 265/30Rs in the rear and 235/30Rs in the front with an offset higher than 30. I had not problems here. When I went to the set up I have now...problems due to ---offset and tire size. Rubbing even with a fender roll - not lowered - stock height.
As far as tires and rim sizes - good tool below:
http://www.tyresizecalculator.com/ty...dth-calculator
'11 BSM DCT 7 Spd. 335is | RPi | aFe Magnum Flow Direct Fit | Interad DTM 10 Forged | Smoked Reflectors | Huper Optik Tint | Arkym Rear Diffuser | Cyba CF Quad Tips | iND CF CRT Rear Spoiler | COBB Protune | Turbosmart BPV | AutoCarbon CF Grills | Silver CF e-Brake | BMW CF Mirror Shrouds | M Perf. Steering Wheel v2 | KW DDC Coilovers w/WLAN | Interior Xenon LEDs | Custom 335is Accents | F/R Fenders Rolled & Pulled | New Pipes Baffle Delete
      09-24-2014, 11:17 PM   #5
scrammer
scrammer's Avatar
422
Drives: 2017 M3 Ultimate
Try this link out for size …
It incorporates wheel diameter, width, offset and tire size to give you a great reference point.
http://www.rimsntires.com/specspro.jsp
Or for a trusted spec that works every time …. but maybe not that aggressive
http://www.bbs-usa.com/application-guide.cfm
Current ///M: 2017 M3 Ultimate
Past ///M Cars: E92 M3 ZCP 'CDN LRP' … E85 Z4M-R ... E92 M3 ZCP Frozen ... E90 M3 ... E46 M3 Cab ... E46 M3 ZCP ... E46 M3
avantgarde, e92 335, lci, m sport suspension, m359
