      11-04-2014, 08:54 PM   #1
sparky_phantom
Drives: 2011 BMW 335i
2011 BMW 135i  [0.00]
Question Is the P3Cars Vent Any Good?
I am wonder if this is worth a buy to show boost and other information for the money. If you have any other ideas on this I would like to see what other people have done.
Website
      11-06-2014, 07:59 PM   #2
VMRWheels
General
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Have few buddies running the P3 vent gauge.. so far nothing but good things to say
      11-06-2014, 08:04 PM   #3
sparky_phantom
Do any of them have Cobb as well running at same time?
      11-07-2014, 09:56 AM   #4
ryan.ferguson
Drives: 2013 335is Coupe DCT
I have the newer one with a jb4g5. I have an n54 so i use the manual boost tap for my boost readings (the piggyback throws off the correct psi if reading it through the obd2 port. I absolutely love it though. Lots of different options and it displaying codes is just an added benefit
Current: 2013 335is Coupe DCT Black/Red
Previous: 2008 135i Coupe Montego Blue
"Speed never killed anyone its very important to get that straight, Speed has never killed a soul. Suddenly becoming stationary thats what gets people." - Jeremy Clarkson
      11-07-2014, 10:56 AM   #5
VMRWheels
General
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Sorry, I believe all of them are running JB4
      11-07-2014, 11:51 AM   #6
takrdown
Other car was a submarine
takrdown's Avatar
94
Drives: i4M50 (waiting), 2013 R56 JCW
I thought they didn't work with a JB4 if you are running any mode other than 0? I hope I'm wrong..am I?
      11-07-2014, 05:01 PM   #7
jsmonet
Drives: 2020 x7 m50i
It can't use the reading off canbus because that reading is adjusted at the JB4 level. It's intercepted so the car still sees the same old stock boost rating. You need a vac source under the hood to get around that, and the gauge has a spot to plug a small vac hose in + the setting to use that.
2020 bmw xHippo, v8tt edition
      11-08-2014, 05:58 AM   #8
K.david
Drives: 07 335i
If your running a COBB tune you'll get the actual boost reading the DME sees because cobb modifies the software in the dme to raise boost unlike the piggy backs.
      11-08-2014, 07:33 AM   #9
Harlequin
Harlequin's Avatar
Australia
331
Drives: F32 Coupé
You can't have the P3 and the Cobb plugged in at the same time but you can use the P3 with the Cobb flash installed. That's what I do.
P3 Gauge is AWESOME!
      11-08-2014, 11:03 AM   #10
takrdown
takrdown's Avatar
94
I understand the boost gauge issue, but what about the other functions?
      11-08-2014, 04:26 PM   #11
jsmonet
you're not likely to have a problem with the other things because most of them aren't being intercepted and the rest usually end up just being passed through.
      11-09-2014, 05:11 PM   #12
totti84
Australia
112
Drives: N54 135i 6MT
Can anyone confirm this?
      11-10-2014, 07:13 AM   #13
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
No you can't use the P3 for other functions as long as the JB4 is active. They will fight over canbus bandwidth and the jb4 will keep resetting. You can only use it as a boost gauge in analog mode with a physical boost line. Provided the version you get supports that, mine didn't.
      11-11-2014, 09:59 AM   #14
takrdown
takrdown's Avatar
94
To much money on a chance then. Thanks guys!
boost gauge, p3cars, performance, vent gauge
