COBB + RB Turbo Fun: 105 - 200 km/hr - ~8secs?? :)
06-15-2011, 12:09 AM | #23 | |
Rep 1,031
heh, not where were from..... i wish tho |
06-15-2011, 01:27 AM | #24 |
Rep 395
WOW those turbos can run .... Anyway that sort of power can be made with 16-17psi with the BMW.
06-15-2011, 03:13 AM | #25 |
Rep 1,827
I would hope so considering we have an extra liter, 2 more cylinders and another turbo to boot. We run 19psi stock as well. Man I don't even know why I brought this up, but just mentioning it makes me want to get another Evo and run E85 all over again. Nothing like lighting up all 4 tires in the street.
06-15-2011, 06:00 AM | #26 |
1 Stock M
76
Rep 1,650
Drives: Something Slow
Awesome video. OP your car is going to be a bigger beast with Cobb Stage 2 or ATR.
Veteran USMC/Iraqi Freedom
Current: E46 M3 Retired: 2009 E90 AW M3 Retired: 2007 E90 AW 335i. |
06-15-2011, 06:02 AM | #27 | |
ElevenPointFive
324
Rep 2,450
Good luck Dzenno, bring your vbox and vid some runs! Awesome stuff, cant wait to see your results.
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
06-15-2011, 06:18 AM | #28 |
Rep 523
wheres the event dzenno?
18 M2 6 Spd AW - VRSF DP / CP & Race FMIC, ER TIC & GFB DV+ with BM3 Stage 2 Retired 09 135 JB4 G5 ISO w/BEF, N54 Tuning Performance DPs, BMS DCI, ER Charge Pipe |
06-15-2011, 07:53 AM | #29 | ||
Rep 5,876
no idea probably around 380-400 on pump, no idea, maybe I'll dyno it lol
London, ON |
06-15-2011, 09:30 AM | #30 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Its funny how people are comparing boost between cars. That's the most ridiculous thing I've heard in a long long time. Air is a fluid. Boost is nothing more than resistance to flow! That's it! It tells you ABSOLUTELY nothing about how two different engines outputs compare if they have the same amount of boost. Quit comparing boost values from Evos to our cars and saying that our engines run low boost.
Go boost a Toyota Corolla LS and see that the con. rods on those engines begin to twist at 6psi. Now all of a sudden N54 running 14.5psi is insane amount of boost. Long story short: boost values should not be used for comparing engines. Period! OP: nice video. I hope you sort out that misfire problem of yours soon!
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
06-15-2011, 09:37 AM | #31 | |
Rep 5,876
What you missed though is mentioning CFM (volume of air coming out) and how psi with smaller turbos doesn't equal psi on bigger turbos...me running 13.5-14psi with RBs is about a 50-70whp difference from stock turbos with lower EGTs...there's a lot to be said... |
06-15-2011, 12:57 PM | #32 |
Rep 523
completely off topic dzenno & irish we should hit the links some time soon that's gonna be a solid 4 hrs of n54 discussions with some golf stuff in betwen
06-15-2011, 01:17 PM | #33 |
Rep 5,876
06-15-2011, 01:20 PM | #34 | |
130
Rep 2,290
Using PSI as a unit of power is about as good as using compression ratio as an indication of hp. "My Honda civic R is better than your Corvette ZR1 because it has a compression ratio of 11.0:1 while your mullet mobile only has a cr of 9:1. See you on the track, loser!" I'm actually agreeing with Vasil 100%. What is this world coming to? |
06-15-2011, 01:26 PM | #35 | |
3441
Rep 79,212
Drives: C6 Z06, 09 335i, 10 335xi
06-15-2011, 03:49 PM | #36 |
The Blue Beast
142
Rep 5,665
WTB RB Turbos
Cobb AP Stage 2+ | BMS DCI | UR Catless DP | UR Chargepipe | Tial BV 50mm | BSH OCC | ETS FMIC | Eisenmann Race Exhaust | KWv1 Coilovers | Volk TE37 TC Kline Ed. |
06-15-2011, 11:46 PM | #38 |
14
Rep 309
Drives: E92 N54
06-16-2011, 12:11 AM | #39 |
788
Rep 3,972
105-200km/hr in 8 seconds is probably around a low 9 second 60-130mph run
On my 7.28 second 60-130mph run I entered 105-200km hr in the settings instead, and it came out to 6.03 seconds.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
06-16-2011, 06:28 AM | #40 |
Rep 5,876
06-16-2011, 08:16 AM | #41 |
788
Rep 3,972
The 7.28 was during a 1/4 mile run with normal automatic shifting at redline. But to put things in perspective, your time in the video is about as quick as my times on 15psi and meth. My 9.0x runs required 17psi. You will find that dropping a full second or two will be harder than you think. But can't wait to see some RB turbo times in the 60-130 sticky to see the improvements!
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) Last edited by hotrod182; 06-16-2011 at 08:22 AM.. |
06-16-2011, 08:37 AM | #42 | |
Rep 5,876
No worries, I'll try to have a few more videos over the coming days when I make it down to Mexico.. Last edited by dzenno; 06-16-2011 at 08:48 AM.. |
06-16-2011, 08:50 AM | #43 | |
Rep 1,618
Perfect in my book as I don't want to run meth in my car
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
06-16-2011, 08:52 AM | #44 |
Rep 7,378
plus the pull after 6000 rpm and after 200 kmh which is completely different than stock turbos.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
94 octane pump, cobb, fbo, rb turbo, stage 1 |
