      01-13-2014, 08:47 AM   #1
LW50
LW50's Avatar
50
Drives: 2021 BMW M3 Competition
E92-Lighting Smoked Side Markers
I pulled the trigger on these guys a short while back and finally got them installed.
The smoked color is pretty neutral and blends in with Space Grey perfectly. Illumination is amber through what looks like 3x LEDs.
They appear well built and have the foam backing, but the only part that I've got a gripe about is the connector which you'll see below. I would have preferred either the proper connector, or leads that were a little easier to install into the OEM connector. But with a little encouragement via some needle-nose pliers, they were installed and tested in less than five minutes.
Brightness seems acceptable to me during day time, I'll have to check them out tonight and see how they do in the dark.
$49.99 @ http://www.e92-lighting.com/bmw-acce...ed-sidemarker/
      01-13-2014, 01:59 PM   #2
E92-Lighting
E92-Lighting's Avatar
Drives: Next Generation LED Lighting
looks awesome and we have both clear and smoked in stock, and some with a vast amount of leds.
      01-13-2014, 02:24 PM   #3
MuNkY6913
The Crowing
MuNkY6913's Avatar
Drives: BMW 135i
2009 135i  [8.00]
you should post a link to the E82 version with stock connectors. that would be helpful and save time.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback
      01-13-2014, 02:33 PM   #4
Steve-0
Drives: 2010 dadmobile
Nice. It's funny how small changes like that can drastically alter the look.
      01-13-2014, 04:52 PM   #5
LW50
LW50's Avatar
50
The link at the bottom of my post above fits the E82. I probably should have been more clear on the connector, it's not a direct drop in to the car's wiring harness, but you don't need to do any splicing or soldering. You remove the bulb holder from the OEM marker, and remove the bulb from the socket. The new marker plugs into the bulb socket, and you reconnect the original bulb holder to the harness connector. The video on the product page shows the install procedure.
      01-13-2014, 06:03 PM   #6
Chandon
Chandon's Avatar
Australia
99
Drives: 1M
Definitely bang for your buck.. I bought these a while back for 30$ off ebay. Makes a big difference, also considering my car is black so you no longer have an ugly amber bulb looking like its been misplaced.
It's the little things that count
      01-14-2014, 07:48 AM   #7
___whoosh___
14
Drives: 2010 135i
I also snagged a set of these when I first bought my car
Got mine from ECS tuning
they rock!
      01-14-2014, 12:01 PM   #8
AGAV13
AGAV13's Avatar
Drives: AW 135is (#363/586)
Can you take a pic from farther back showing the whole side?
CURRENT
2017 Boxster S ?718? (07/27/18)
2018 Jeep Wrangler Unlimited Rubicon Recon - (10/28/18)
SOLD
2013 BMW 135is #363/586 - AW, Black Boston Leather w/ Exclusive Blue Stitching, Prem., Tech, DCT, Heated Seats, HK
      01-14-2014, 12:11 PM   #9
LW50
LW50's Avatar
50
Whole side of the car? Sure, I'll do it after work.
      01-14-2014, 01:44 PM   #10
AGAV13
AGAV13's Avatar
Thanks
CURRENT
SOLD
      01-14-2014, 01:58 PM   #11
E92-Lighting
the ebay ones dont have a rubber liner so we stopped selling them years ago (water condensation)
      01-14-2014, 03:27 PM   #12
LW50
LW50's Avatar
50
Thanks
Here you go
      01-14-2014, 03:48 PM   #13
AGAV13
AGAV13's Avatar
They look real good may have to invest in a set for myself.
CURRENT
SOLD
led, markers, side, sidemarkers, smoked
