BMW M3 Forum (E90 E92)
  TireRack
      10-24-2011, 12:01 PM   #1
Skateboard_P
Drives: BMW e92 330D
E92 - using aggressive tyre/wheel offsets
Hi guys,
New to the site and really could do with some help on this!
I know this subject has been covered in various threads by I'm looking for a definitive answer as to whether the following set up will work for an E92 330D on stock suspension:
Front: Alpina Classic 19x8.5 ET 24 with 245/35/19
Rear: Alpina Classic 19x9.5 ET 30 with 275/30/19
Offsets are aggressive as the wheels have come of an e39. (I have the bore size adapter ring sorted.)
Will I rub on front/rear? Also, what's the possibility I can drop it on this set-up? Trying to avoid rolling or camber adjustments.
I occasionally need to carry passengers as well.
Thanks in advance!
      10-24-2011, 07:59 PM   #2
LarThaL
LarThaL's Avatar
336
Drives: 2011 M3
Originally Posted by Skateboard_P View Post
Hi guys,
Thanks in advance!
I think you are on the wrong forum
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner
      10-24-2011, 08:01 PM   #3
Black Gold
Drives: M3
he is asking for a 330d if you read the post
from what i remember from my 335i, those offsets are fairly aggressive. check e90post.com for better info. this is m3post
      10-24-2011, 08:14 PM   #4
Malek@MRF
Malek@MRF's Avatar
Drives: E92 M3, E46 M3, G82 M4
Those offsets will work just fine on your 330d. However, the 275/30 rear tire may require a slight roll/shave in the rear depending on the brand of tire.
-Malek
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport.
Facebook | Instagram | Yelp! | Flikr
Phone: 949-233-0448 | E-Mail: info@mrfengineering.com
      10-25-2011, 04:16 AM   #5
Skateboard_P
Yep, sorry guys, wrong forum, I've reposted on e90 so hopefully will get some responses there.
Thanks Malek - using Falken 452s - from what I've read, they're relatively slim compared to other tyres. I was more concerned about the front - ET 24 seems quite aggressive.
      10-25-2011, 05:10 AM   #6
Robmaster
Robmaster's Avatar
Switzerland
151
Drives: 2010 E82 135, 2005 E87 130i
sorry, but this offset isnt aggressiv.... had way aggressiver offset on my old E92 335i:
19x8.5 ET20
19x9.5 ET20
      10-25-2011, 05:48 AM   #7
Skateboard_P
Hi Robmaster,
Did you rub at all? Did you have camber/arch modifications? Also, what suspension were you running? Were you on the same tyre package - 245/275?
On the similar threads I've read, most seem to be running ET 30+ on front to avoid rubbing.
Thanks for your comments so far!
      01-10-2012, 07:35 AM   #8
Robmaster
Robmaster's Avatar
Switzerland
151
Hi Robmaster,
sorry for the late response.
tire was 225/35/19 and 255/30/19. at the front there was no rubbing, no fender or camber mod.
at the rear i had the fenders sligthley rolled and it rub like hell. so for this you need heavy fender mod and some negative camber.
245/35/19, 275/30/19, aggressive, e92, offset
m3post
