Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > E92 Fitment ???: 18x8.5 ET13 & 18x10 ET25 - need hub adapter too :-(
      03-06-2012, 12:10 AM   #1
pimp4cheddar
El Capitán
pimp4cheddar's Avatar
Drives: BSM X3M
Exclamation E92 Fitment ???: 18x8.5 ET13 & 18x10 ET25 - need hub adapter too :-(
Hey folks,
I'm about to pull the trigger on a set of wheels within the next day or so. I looked around and searched all over this site and I'm getting mixed reviews. The kicker is I just found out the wheels I'm buying are a 74.1 hub...not 72.56!
The setup is kinda aggressive:
-Front: 18x8.5 ET13 245/40/18
-Rear: 18x10 ET25 265/35/18
The widths are ok with me...it's the damn offsets. Plus I'll have to buy adapters and I have no idea where to get a set so I don't know how thick they usually run!
I have an E92 with ZSP (Sports Suspension). I plan on dropping the car on H&R Sports within the month.
Am I doomed? I've read some threads about people rolling the fenders and others saying nothing worked...
Thoughts?
      03-06-2012, 09:57 AM   #2
pimp4cheddar
El Capitán
Drives: BSM X3M
If needed...I can actually roll the fenders alittle...
      03-06-2012, 10:28 AM   #3
NiVeDh
NiVeDh's Avatar
Drives: '08 E90 335i, '99 E36 M3
If you have to use adapters, your already aggressive offsets will effectively become more aggressive. This setup won't work.
      03-06-2012, 10:41 AM   #4
pimp4cheddar
El Capitán
Drives: BSM X3M
Actually I was wrong...I don't need adapters...just hub rings. Just found out!
So no additional hardware being added
Would it work now??
      03-06-2012, 10:58 AM   #5
Hey Ant
Hey Ant's Avatar
Drives: E90 M3
more camber in the front... rears are good.
      03-06-2012, 12:49 PM   #6
edirtaynine
Drives: e92
yeah u just need hubrings. adapters only if the bolt pattern is different (which its not).
+13 is pretty damn aggressive for the front and u cant roll our plastic fenders with our e92's id run 235 tires, maybe even stretched 225s and camber those suckers in.
      03-06-2012, 02:37 PM   #7
Pcemkr
Pro Hater
49
Drives: Low and slow
8.5" et13 is not bad. I have 9.5" et19 with 225 no problem.
225 on 8.5" is NOT stretch.
Like you found out, you just need hubcentric rings 74.1 -> 72.56
The rears are no problem, just run a 225 up front.
Username is now PSUSMU
      03-06-2012, 02:43 PM   #8
pimp4cheddar
El Capitán
Drives: BSM X3M
Thanks.
I thought you had an E90?
I'm trying to run this on an E92...which doesn't allow as much room vs an E90.
      03-06-2012, 03:12 PM   #9
Pcemkr
Pro Hater
49
Originally Posted by pimp4cheddar View Post
Thanks.
E90 LCI and E92 are nearly identical.
      03-06-2012, 04:11 PM   #10
DriftDreamzSS
DriftDreamzSS's Avatar
22
Drives: e92 335i
Yeah, do the 225's in the front and it should fit fine and look good, alot better than flush rear/sunk front that seems to be popular on e9x.
_
      03-07-2012, 01:27 PM   #11
pimp4cheddar
El Capitán
Drives: BSM X3M
Thanks guys!
Just paid for the wheels...should be here next week!!!
aggressive, e92, low, offset, wtf
