      07-12-2012, 10:18 AM   #1
1dirty5
Drives: 2013 M3
Question VMR V710 +45 Front AND Rear
Hi guys. I just purchased a CPO 2008 135i and one of the first things I'm looking to do with the car is change the rims. I'm trying to get 19" VMR V710's, but the local shop I'm dealing with only has +45 offsets in stock for both fronts and rears. Will they be sticking out at all? Or is there very little difference between +45 and +50?
As for tires, I'm probably going to get the Michelin PSS's. 225/35/19 & 255/30/19.
Any feedback would be greatly appreciated!
      07-12-2012, 12:26 PM   #2
addict135i
Drives: 135i
I run those specs on v713s , 19x8.5 et 45 and 19x9.5 et 45..I am dropped on super sport springs, I have my fenders shaved as well, and I still manage to rub, if your not going to drop it , your fine. Hope that helps!
      07-12-2012, 04:38 PM   #3
VMRWheels
General
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Running 8.5 +45, 9.5 +45 is not a problem (exactly 5mm difference between a +45 and +50) You're in the clear just as long as you go with a 245/30/19 rear tire. Since PSS's aren't produced in that size, you can run that 255 if you have your fenders rolled. Most likely you'll rub when you run over larger bumps or have many people in your car. I hope that helps you out.
      07-13-2012, 07:39 AM   #4
1dirty5
Drives: 2013 M3
Thanks! That's really good to know. I guess I'll have to re-evaluate my tire selection to find 245/30/19
      07-13-2012, 08:10 AM   #5
_Ryan_
59
Drives: E87 130i
2005 BMW 130i  [5.24]
is an 18x9+45 with a 235 possible?
I HATE staggered fitment...
      07-13-2012, 12:19 PM   #6
EuroTunerz5
Drives: 2012 AW BMW 135i M-Sport PPK
I have vmr v710 19x8.5 et45 and 19x9.5 et45 on the way at this moment and will be running 225/35/19 and 255/30/19. Does that help at all?
2012 BMW 135i M-Sport PPK AW with Black Boston Leather- SOLD
2010 Acura TSX V6 Tech BSM
2003 Corvette Z06 TR "Widebooty"
      07-13-2012, 12:21 PM   #7
EuroTunerz5
The one advice I can give is to stay away from the Michelin in those sizes... They run huge in comparison to a Khumo etc and may not fit whereas my Khumo in the 225/255 will fit.
      07-13-2012, 03:46 PM   #8
1dirty5
Drives: 2013 M3
Thanks EuroTunerz. When are you expecting your 710's to arrive?
      07-13-2012, 03:58 PM   #9
VMRWheels
General
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
We don't have any 18x9's. We do have a 18x8.5 though! I would recommend running a 18x8.5 +45 with a 225/40/18 all around. Good solid size, no rubbing issues. May look a bit sunk in the rear depending on your taste but you can always run a small spacer to push it out.
You MAY rub but it really depends on the brand of tire. Even if you do rub, it'll be very minor and probably when you run over large bumps or take hard turns.
      07-13-2012, 05:55 PM   #10
1dirty5
Drives: 2013 M3
Any idea if yoko s drives are less prone to rubbing?
      07-13-2012, 08:24 PM   #11
EuroTunerz5
My wheels arrive Tuesday and I plan to mount them on the vehicle Wednesday evening.... The tires are Khumo Ecsta SPT which don't run big at all so I am almost 100% positive on my factory m sport suspension I won't rub!
Pics coming soon with results!
      07-13-2012, 09:03 PM   #12
_Ryan_
59
Drives: E87 130i
Thanks for the response. I don't run spacers, ever. Had a bad experience(purchased a car with them on it).
Do you do an 18x9.5? Will they clear the front?
      07-14-2012, 07:34 AM   #13
EuroTunerz5
Yokohama are typically fine too I was on the fence between the Khumo and Yoko and ultimately went Khumo as folks tend to be more impressed by how quiet they are and how well they perform rain or shine!
      07-19-2012, 09:04 PM   #14
EuroTunerz5
Btw mine are installed now 255 rear 225 front... SLIGHT RUB in the rear. Getting rolled slightly to fix that issue!
      07-20-2012, 12:34 AM   #15
sparkyblue
sparkyblue's Avatar
Drives: E82 135i & F80 M3
2008 BMW 135i  [0.00]
I apologize for thread-crapping, but VMRWheels, I am running your V718's in 18" 8.5 ET45 & 18" 9.5 ET50 with 225's & 255's MPSS.
What would it take to fit 235 & 265's? Just rolled fenders?
      07-22-2012, 10:02 PM   #16
EuroTunerz5
Sparky I can answer that one... With Michelin PSS you will need a fender roll. Others have run 265 in Hankook, Khumo, and Yokohama without need for major fender work. The Michelin tend to run large as far as tires go. Example: I am running a 19x9.5 et45 rear with Khumo 255/30/19... Another guy has the same wheels and could only fit 245 in the MPSS. Hope that helps!
      07-23-2012, 01:13 AM   #17
sparkyblue
sparkyblue's Avatar
Thanks for your response, I am not as worried about the rears as to the fronts. I know the front tire clearance even with 225's is running extremely closely to the struts. How would 235's fare with OEM Suspension + 8.5IN ET45 235/40/18's?
However today, I went to a car meet/luncheon and I saw some guy running Breyton 18" 7.5IN 265's in the Fronts! I was absolutely shocked that he was rocking that wide of rubber in the front.
Unfortunately I did not get the chance in meeting him, so I wasn't able to discuss what he had done. But the fenders look rolled, and his ride height looked stock to me.
offset, v710
Search this Thread:
