Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 2 cracked BMW 225 19" alloys - will these new ones fit?
      06-04-2014, 02:27 PM   #1
Rich4191
Drives: E93 330d M Sport
Hi all,
I was recently told that I've got 2 cracked alloys on the left side.
Despite being infinitely careful, BMW want £1200 to replace them...
...nope.
Ive found these and like the look of them.
http://www.ozracing.co.uk/car_wheels...24/558583.aspx
If i get the 19's so i can reuse the right side tyres will they fit?
The offset is 39 apparently... I've got a standard pre LCI e93 M-Sport?
Thanks for the help - I'm a little lost...
Rich
      06-05-2014, 10:13 AM   #2
Rich4191
*bump*
if anyone has any advice, i could really use some help
Thanks
      06-05-2014, 10:30 AM   #3
achu
103
Drives: E93 335i
you are better off calling them... we can't say whether it will fit with just offset information...
the bolt pattern needs to be 5x120, the centre bore needs to be 72.5mm (or bigger and use spigot rings) and a recommended width and offset would be: front 8j et30-45 and rear 9j et30-45 although you can run it a lot more aggressive than this...
it's probably best that you go to an official vendor and find alloys with a good fitment if you're not sure
PAST: 2007 E93 335i 6MT
NOW: 2012 F10 M5
Facebook: Achu Ckr|Twitter: AchuCkr|Instagram: AchuCKR|Flickr: AchuCKR|G+: achu.ckr
THE BUILD THREAD|COMPILATION OF PHOTOS
crack, offset, wheel
