BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 335i won't start????
      03-16-2010, 09:39 PM   #1
-lina-
335i
Drives: 335i
i have a 2007 335i and the airbags where deploid now the car won't start any ideas??? somebody had told me its a battery clamp cable
      03-17-2010, 07:03 PM   #2
rrosen
rrosen's Avatar
Drives: 335i, sparkling graphite
When airbags deploy, an explosive wire disconnects the battery. You need to replace that wire on the battery.
___________________
Robert
      02-08-2012, 03:46 PM   #3
sea335i
Drives: 2008 335i Coupe
Same problem here... rrosen, is that wire actually on the battery or it is connected to it?
      02-08-2012, 03:49 PM   #4
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
Big red plastic thingie on the battery is what you need to replace.
      02-08-2012, 05:12 PM   #5
rrosen
rrosen's Avatar
No start after airbags deploy
I believe that's correct.
___________________
Robert
      02-08-2012, 05:20 PM   #6
John 070
Drives: 335i cpe
Should the airbags be replaced and inspected before driving?
      02-08-2012, 05:22 PM   #7
rrosen
rrosen's Avatar
I would think so. Question is, why did they deploy. If in an accident, I assume the body shop will replace them. If they popped by themselves, then there is an electrical problem that has to be fixed before replacing them.
___________________
Robert
      02-08-2012, 10:33 PM   #8
sea335i
Thanks guys for the quick response. The car got into a fender bender, and airbags are not hard to replace if you have time on your hands and you're semi tech savy. They do need to be reset, but the car should start without resetting it.
      02-08-2012, 10:45 PM   #9
bsamoul
bsamoul's Avatar
165
Drives: E90 325i
Don't you also have to replace the seat belt tensioners if the airbags go off?
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines
http://www.tech-shine.com
      02-08-2012, 11:12 PM   #10
sea335i
usually yes, but I got lucky. They dont always bust
      02-08-2012, 11:26 PM   #11
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
Your ABG (airbag) module will have to be replaced as well, you can't "reset" it.
Once airbags are triggered it keep on showing restraint errors.
      02-09-2012, 01:40 PM   #12
sea335i
I was getting mixed opinions on this and more stated that I dont need the modules, bags can be reset with a computer, even the dealer can do it.
      02-09-2012, 05:55 PM   #13
Juiced46
Drives: 03 Turbo Cobra, 2011 335xi
The airbag module does not need to be replaced.
You CANNOT reuse air bags, all deployed air bags must be replaced.
Not all airbags go off in the event of a crash either. It all depends where the car was hit, how hard and if there were passengers.
Its possible the BST (battery safety terminal) located on the B+ of the battery cable triggered. If thats the case it needs to be replaced.
      02-10-2012, 09:50 AM   #14
sea335i
Yep! It was hit in the front, so the steering wheel deployed and right side curtain. Both have been replaced(thanks for this forum's how-tos). Just bought the BST yesterday, will replace it tomorrow and will keep you updated if interested.
      02-12-2012, 09:15 PM   #15
sea335i
well changing the big red thingy on the battery didnt help start the car Im lost, all it does is just a click, no starter sound...
      02-13-2012, 08:12 AM   #16
avocet
Drives: 2007 328i 2011 X5d
how long has it been parked? charge/check your battery.
      02-13-2012, 08:54 AM   #17
anerbe
Drives: Red E90M 6MT
^+1 click sounds like a dead battery. make sure you fully charge it - check the color sensor on the battery to make sure it's still good. you can also check the production date - I had to replace my battery just recently because CA was too sporadic.
      02-13-2012, 10:09 AM   #18
sea335i
Yeah the car been parked for a while, so the old battery died and I bought a new one few days ago.
It shows a flat front tire, which I fixed but still shows up on the dash. The dash also shows airbags light, and service needed, which is probably related. Could that be the problem? Last time Ive checked the car should start no problems.
      02-13-2012, 02:38 PM   #19
sea335i
found a thread with an exact same problem http://www.e90post.com/forums/showth...0#post11337260
