Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Adaptive Cruise Control Retrofit?
      03-12-2012, 02:29 PM   #23
checkerj
Drives: 2011 335d
2011 335d  [0.00]
Just found some details on the wiring behind the ACC system. http://www.bmw-planet.com/diagrams/r.../e90/index.htm
Search for the term "Active Cruise" and you'll see several repeated sections that show the wiring diagram and overview data behind the ACC system.
I found some cheap sensors (relative to the USA price of $2k+) on Germany's eBay site:
http://www.ebay.de/sch/i.html?_from=...All-Categories
Based on my research, in order to even consider an ACC retrofit, you'll need to ensure that your E90 already has the dynamic cruise control feature (BMW option S544A) which applies the brakes during cruise control to regulate speed.
For me, the biggest hurdle in this retrofit is the additional wiring required. If anyone has info on this, please share.
SPECIAL REQUEST: If you know anyone that already has this feature installed on their E9x, try to get some photos of the wiring harness where it connects to the ACC sensor itself. Also, try to get some photos of where the ACC sensor harness taps into the existing electrical system and/or control module.
      07-06-2012, 02:53 PM   #24
WilliamS
GoofBall
Drives: 2008 E92 N54 Xdrive
I hate doing this kind of thing, but I can see in the dash the markers for the Adaptive cruise is there, and my 335xi does have the Dynamic cruise. I know the cruise stalk would have to change as well add the radar to the system. Has anyone accomplished this yet? In theory or practice? I drive 90% highway in Florida and this option is my favorite on the vehicles I sell.
      07-30-2012, 02:57 PM   #25
WilliamS
GoofBall
Anyone know where the coding would be. Im soon to tackle this solo if I have to. I see the dash is already for it, I need the criuse stalk setup. Im certain of coding will be required.
      09-23-2012, 12:41 AM   #26
zigsman
36
Drives: 2009 M3 E92; 2006 330i E90
Update?
Have you tackled this project yet?
      09-24-2012, 02:07 PM   #27
WilliamS
GoofBall
waiting for someone to tell me the coding is possible. I will buy the hardware, get the wiring tackled and do it, the software is my current hang up.
As well is there a module between the sensor and brain of the car? I need someone with the full layout of the setup so I can make it happen. And I will.
      11-28-2012, 07:48 AM   #28
Patrys@BimmerTech
Poland
620
Drives: 2007 E92 335i
We can help you code this retrofit if you are still thinking of doing it.
Patryk
      12-18-2012, 01:28 PM   #29
klipseracer
Drives: 2007 E90 335i, 05 E46 330i
2007 335i  [0.00]
2005 330i  [0.00]
He called you out! Do the retro fit.
      12-18-2012, 01:39 PM   #30
srcstc
Drives: 2016 Camaro 2SS
      07-16-2013, 01:29 PM   #31
fazman
Drives: 335 e90
Was this ever done?
      03-14-2014, 12:00 PM   #32
AWDBooSTIn90
Nomore
AWDBooSTIn90's Avatar
Drives: 335i Coupe 6MT N54
Anyone ever figure this out?
      04-29-2014, 08:29 AM   #33
Space Fox
Space Fox's Avatar
1042
Drives: 2012 Space Grey e92 M3 ZCP
2012 BMW M3 ZCP  [0.00]
I have an ACC sensor laying around from my e92 335i. Pm me if you're interested.
      04-29-2014, 02:04 PM   #34
ptpending
ptpending's Avatar
456
Drives: e91
coding if this feature will not complete retrofit, because sensor require special alignment which can be done only at dealer
      06-01-2014, 01:15 PM   #35
bennyball
Drives: 335d
Have you had this done retrofitted then?
      06-01-2014, 01:26 PM   #36
ptpending
ptpending's Avatar
456
Drives: e91
i have parts for this retrofit but not installed yet
      06-28-2014, 02:17 PM   #37
ka_rai
Drives: F20 118D
hi firends
what is price about this part please ?
thanks
      06-28-2014, 02:44 PM   #38
WilliamS
GoofBall
My 2009 was taken out by a deer over a year ago so I abandoned the project. Now I have a 2008 and would love to see it done. I have adaptive cruise on my Grand Cherokee and love it I want it bad on my BMW. Someone has to do it and get it coded.
      06-28-2014, 02:57 PM   #39
ka_rai
Drives: F20 118D
yes williams is possible, just warning to the module you buy ( about options ) and need coded kombi
but i'm looking for more info about it, my car is also 2008 ( new engine ), if you found more info say me
      01-08-2015, 10:24 AM   #40
9mmkungfu
Drives: 335d, 535d, 750i, X5 35d
Bump for the biannual update
      01-09-2015, 04:03 PM   #41
MichelleJD
MichelleJD's Avatar
Drives: 2012 650i Cabriolet
Ordered it factory on mine. Will never own another car without it!
      03-22-2015, 01:41 PM   #42
GreaseJunkie
Drives: 2006 E90 330i Black Sapphire
Is nav required? Does the car have to be AT equipped?
      03-22-2015, 04:25 PM   #43
ptpending
ptpending's Avatar
456
Drives: e91
no, yes
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes.
      12-22-2015, 12:25 AM   #44
glamprecht
glamprecht's Avatar
Drives: 330iE90, F15X5, F25X3, F15X5
That is not correct. I have manual transmission with ACC and it works well. It occasionally indicate shift down but my 330 runs from 30km/h up to any legal speed in 5th gear. So I don't really miss a automatic transmission with ACC. I have driven over 200, 000 km with ACC mostly on. It made probably less than 10 or 20 mistakes and at no time it was uncomfortable on a mistake where it applied brakes unnecessarily. Its in my opinion the greatest option on my car.
canada, cuise, dynamic, modification, retrofit
