can you install an aftermarket cd/dvd player with an idrive unit?
01-24-2010, 12:14 AM | #1 |
Rep 17
reason why I ask is because I am sort of an audio geek and I hate hooking up my system to stock stereos.
thanks. |
01-24-2010, 09:43 AM | #4 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
you probably can if you're willing to give up the idrive screen, BT, nav, radio, gongs, etc as well of a slew of error codes.
you'd have to bypass the car amp and run new speaker wiring and find a installation kit (for mounting unit). alternatively, you can move the current CCC unit (thing you put dvd's / cd's into) to another location (eg trunk / glovebox / etc). Outside extending the electrical wiring, you'd have to extend fiber optic lines too. Once moved you can plug your new unit into your stock "aux" connector. or you can buy a idrive screen interfacing unit that allows you to inject a composite video signal from a camera or a dvd player while still keeping your idrive functions in tact. |
01-24-2010, 11:43 AM | #5 |
Rep 1,885
on '08 or later i-drive is DVD capable, and you can watch movies, videos when car is in "park", but there is a chip that overrides that. There have been numerous posts on that here.
'11 E92 M3 ZCP SG 6MT Tech Sound USB Heat Cloth Aluminium Sunshade
http://www.m3post.com/forums/showthread.php?t=422151 |
01-24-2010, 11:59 AM | #6 |
Rep 7,089
Drives: '06 AW 330xi
You can probably wire a cd palyer to the aux input but as for video it looks like the only option is the tvandnav2go (I think that's what it's called). Pretty pricey though.
01-24-2010, 12:02 PM | #7 |
Rep 1,190
09 and above. I can not play DVDs in my 08 iDrive.
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
01-24-2010, 12:08 PM | #8 |
Rep 1,885
True, '09 and above.
If you find the way to get this work on '08, I would like to know as well... How much is the i-drive replacement unit at the dealer? I was thinking it should be around $2k, and maybe '08 unit could be swapped for an '09... problem solved. Most likely only part of i-drive needs to be replaced, not the entire unit, so it should be a lot cheaper than $2k.
01-24-2010, 12:42 PM | #9 | |
Chicks dig wagons!
43
Rep 1,375
Drives: 2009 E91
Location: Where you can see through the people, but not the air (i.e., Los Angeles!)
Other features of the sound system, like the Sirius receiver, can be replaced - not the CD player. You probably could wire an aftermarket CD player in the trunk area, but that would not lead to any sound improvements. The limitations in the stock systems are mostly in the speakers and amp. The easiest solution to upgrading sound is replacing speakers. And, that is pretty much true in any decent OEM system on the market.
E91 Montego Blue gray leather burl walnut , Idrive, PDC, Logic7, CA, Sirius, xenons, 6FL, ZPP, heated seats, 17" tires.
4, 8, 15, 16, 23, 42 |
01-24-2010, 12:56 PM | #10 | |
General
8115
Rep 18,813
Drives: BMW
OP: The stock radio is very good, amps/speakers is what needs attention - depending on music preference.
01-24-2010, 02:05 PM | #11 |
Rep 1,885
I think the entire '08 i-drive swapped for '09...with '09 LCD screen and dash, would make DVD's playable, figure $2k+labor etc,.... still is cheaper than getting the whole new car....
04-24-2013, 11:31 AM | #12 | |
Rep 3
CIC Optical Drive Repair/Replace
I have a E90 post-LCI 318i European version (manufactured 11/2008), with Professional Navigation package (CIC iDrive, with optical drive and hard disk included in the head unit). CIC faceplate has preset buttons marked 1 to 8 (I mention this as I have seen others with only 6 presets) The CD/DVD drive isn't working, as I can't read any music CDs o movie DVDs. Everything else works OK. I believe this has happened because of lack of use, the previous owner tells me he hasn't used the CD/DVD drive for 3 years. When I insert CDs or DVDs I get "Unknown" in the CIC display. I bought a lens cleaner CD but this didn't fix it. I realized it wasn't a problem with the lens, it seems that the disc isn't even spinning because the sound emitted by the drive was very low, I can just hear an intermittent brief hum every 3 seconds. I have read everywhere that the optical drive cannot be replaced separately. This post (http://www.e90post.com/forums/showpo...43&postcount=9) supports this view also. However, according to page 18 of a CIC Service Manual I found (http://www.e90post.com/forums/attach...hmentid=244402) the "DVD/CD player including the CIC housing cover" is an individual replaceable component of the CIC module. I wonder that I could remove the CIC, and take only the optical drive module to a technician with general knowledge so that hopefully he can repair it. In Peru, where I live in, I haven't found technicians specialized in BMW electronic equipment repair. The BMW dealership I believe won't try to fix the optical drive, they will just opt to replace the whole CIC module (they sell it here for USD$4000) which is VERY expensive. Please advice as to which would be the better solution to this problem. Is it possible for a technician with general knowledge to fix the optical drive? Where could I buy just the optical drive and replace it myself? Is my only option to buy the whole CIC? Thanks for any help |
04-24-2013, 05:44 PM | #13 |
Rep 994
I took idrive out and had errors coded out. Kenwood double din in place of CIC and an alpine screen mounted where the idrive screen was which connected to the kenwood. It displayed either navigation or DVD video while I did other things with the kenwood simultaneously.
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
04-30-2016, 12:22 AM | #14 | |
Rep 10
I'm considering doing this, unless I can move the CCC to the trunk. Do you find you've lost anything?
iDrive is: Nav (I find mine useless, using my phone) Radio (I would probably feel the loss of this when I install the Pioneer SPH-DA120 but honestly I use radio exclusively for music and having modern carplay / pandora / USB will probably be compensation enough) DVD & CD (once I have USB, these will never be used anyway) Service information (I DO find this very useful) Time (this will be taken care of with the aftermarket unit) Quote:
04-30-2016, 12:28 AM | #15 |
Rep 994
You don't need the service info. It's all on the cluster. I don't miss a single thing. Remember, the cars without iDrive have to give the same service info.
04-30-2016, 09:34 AM | #16 |
Rep 10
Thanks for replying, mathematics. A few questions:
Did you have L7? What did you do for PDC (parking distance)? ctuna recommends against this (http://www.e90post.com/forums/showthread.php?t=1255074), and that sort of scares me ... I have thought much about it. As "cool" as L7 and the existing setup is, it is old, and truthfully never served my needs. So what if I can listen to the radio and CD's in high quality. Here's what I want, which can all be provided cheaply with aftermarket HU: 1) good nav (because (2) below and also I prefer Google Maps 2) touch screen (because entering addresses with iDrive is useless to me) 3) Pandora / Internet Radio 4) USB (perhaps the most important) 5) Web connectivity / email / text etc So it seems the only real option here is to tear out L7 and CCC and figure out: 1) Parking PDC (very important) 2) Amp -> 9 speakers (this may be the biggest hurdle) 3) Warning tones (I think if I get PDC figured out, this may follow?) And therefore the options are: 1) relocate CCC to trunk - I thankfully have wiring & free fibre there - seems I'd have to have the CCC reprogrammed to output analog, presuming I toss L7 - requires new amp no matter which option I choose because L7 amp takes nothing after-market (except one HU I'm not interested in) - not sure if iDrive controller works all the way to the trunk / how connected. If it doesn't, then relocation of CCC is not an option. - other than PDC which needs stereo to be practical, nothing prevents me from having CCC reprogrammed to analog & connect it un-amplified to 2 after-market simple stereo speakers for the sole purpose of PDC & chimes , so: - can PDC output be located / redirected to 2 aftermarket speakers? 2) say goodbye to CCC altogether - can PDC & warnings be directed as mentioned above, to separate simple stereo speakers, without CCC? - Figure out what to do with the dash display - aka either let it sit dark or buy after-market screen with (HDMI) input from new HU - requires reprogram (I've done this myself with a laptop in the past, not too difficult) 3) drive the car and act like I like the 2007 technology Last edited by heinrich; 04-30-2016 at 09:47 AM.. |
04-30-2016, 10:19 AM | #17 |
Rep 994
I did not have logic 7 nor PDC.
I'm not sure about retaining PDC without the head unit in place. iDrive controller should still work because it's really just power, ground, and can hi/lo. I have nothing where factory screen was right now because I'm still trying to figure out if I am going to just add a screen and mirror my phone to it and have backup camera or add a small android tablet there for other functions among rear camera. when I had my kenwood double din. I had an aftermarket screen up top that received video out from the head unit. that allowed me to output either navi or movies to the top screen while maintaining radio and control functionality on the bottom screen.
05-05-2016, 10:34 PM | #18 | |
Rep 10
Did you have to loop the MOST and use / enable another fiber line in the trunk?
05-06-2016, 06:04 AM | #19 | ||
Rep 994
aftermarket cd player, idrive |
