The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Possible Boost leak?
      09-27-2013, 06:13 PM   #23
deadmn1337
Drives: 2016 EB 435i
I had 30ff code for awhile. Replaced all my vacuum lines the problem is gone. I would replace your vacuum lines with High temp silcone lines. when changing mine, the hose on one of my DV's was halfway broken and that seemed to be the only leak but problem solved. It is much easier and cheaper to replace the hoses than a solenoid.
      09-27-2013, 06:15 PM   #24
parylizer
Drives: 2007 335XI
Where did you get the high temp vacuum lines from?
      09-27-2013, 06:17 PM   #25
deadmn1337
http://www.ebay.com/itm/151093106969...84.m1497.l2649
you can get any red, blue, or black
      09-27-2013, 08:01 PM   #26
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
vacuum lines and solenoids, my advice hasn't changed.
E90 LCI N54 6AT
      09-28-2013, 01:39 AM   #27
parylizer
Drives: 2007 335XI
Thanks, I am ordering all new vacuum lines and will replace any that look worn out and see what happens.
boost, lag, leak, slow, spool
