Focal IFBMW-S vs JL C5/C2
03-11-2014, 10:51 PM | #1 |
Rep 15
Anyone know direct comparisons between the two? The specs seem similar to me but I don't really know what I'm looking at and wondering if there are any differences in sound. Having my upgrade professionally installed and have one installer suggesting focal and the other works with JL and he is actually pushing the more expensive jl lines. I was all set for the jl set up as suggested by technic and its cheaper but as I liked the focal dealer better I wanted to see if it was worth the extra money. Have only seen positive reviews of both so any idividual experiences would be much appreciated.
Im going to get the jl xd 600/6 amp and leave the oem underseat subs. My future possibilies: http://www.jlaudio.com/cart http://www.crutchfield.com/p_091IFBM...95#details-tab Side note I could still get the installer I like more to use the jl set up just trying to do my due diligence on the focals. |
03-12-2014, 12:21 AM | #2 |
Rep 13,102
Morels have a better lower end for 4 inch speakers
and that is where the hole is in the 4 inch to 8 inch gap. If the Jl plays lower I would go for that . Some have commented that the Focals are kind of trebly and harsh . Which system are you starting out with. Not doing the under seats is generally a mistake. I think that Focal kit is overpriced for what you get they are only 50 watt speakers not the ones you usually think of when you talk about Focals. At least there overpriced at Crutch field which does not tend to be bargain place to buy things. Have these guys actually done BMW's before are they using the Technic Harness. Last edited by ctuna; 03-12-2014 at 11:16 AM.. |
03-12-2014, 08:15 AM | #3 |
Rep 15
Im gonna go with the jl set up but after speaking with the installer his recommendations are a little different than what I was thinking. Starting with the HiFi system And using a technic harness. He says he has a lot of experience with BMWs
His recommendation and setup: HD 900/5 amp ZR tweeters- 1 channel C5-400- 1 channel for each speaker Under seat subs- 1 channel Rear speakers- 1 channel He says 6 channel amp is unnecessary and that he's worried about a separate channel for each OEM under seat sub bc itd be too much power. It seems most on here use the xd 600/6 so I'm wondering if that's really the case. The HD amp is 500 dollars more expensive so I want the xd and he suggested 700/5 with the same set up as above. He is suggesting replacing the subs as well but I wanna keep the price tag down for now and have heard good things about the OEM subs with aftermarket amp so its worth trying. |
03-12-2014, 09:26 AM | #4 |
10
Rep 91
I recently installed the Focal IFBMW-S kit and they sound great! The treble is not harsh. The improvement over my stock hi-fi is amazing! I am powering them with a XD600/6. I can confirm that not doing the underseats is a mistake, I am sorely in need of some aftermarket 8" subs. I have no experience with the JL series so I can't comment on those.
Georgia Tech Graduate, BS in Electrical Engineering
03-12-2014, 09:26 AM | #5 |
Rep 3,969
Don't listen. The underseats should be in stereo and the xd600 is perfect with 75w per channel especially if you want to keep your existing 8 inch underseats. BTW the HD900 has 500w on tap for the underseats, how is that less than 75x2 ?
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
03-12-2014, 11:01 AM | #6 |
Rep 13,102
Stay with the xd 600/6 and do the underseats.
Stay with the xd 600/6 and do the under seats.
1 channel per door and floor each. stereo underseats. Better to do the underseats than the rear seats. Also consider a set of Jehnerts. At least for the underseats. The xd 600 is enough power to make you deaf. Also its less load on the electrical system. xd 600 is the defacto amp of choice here for Hi Fi . Last edited by ctuna; 03-12-2014 at 11:18 AM.. |
03-13-2014, 09:33 AM | #7 |
Rep 15
Thanks guys I just wanted reassurance on my original plan bc this guy doesn't seem to be liking it. Think I'm gonna keep OEM under seats for now and get jehnerts in the near future. Thanks all!
03-13-2014, 11:25 AM | #8 |
Rep 13,102
You will actually get some bass out of the OEM
You will actually get some bass out of the OEM underseats
but its pretty muddy compared to almost anything you could put in . |
03-13-2014, 11:54 AM | #9 |
10
Rep 91
You summed my experience up perfectly. After installing the IFBMW-S and cranking up the gain on the XD600/6 I get some decent bass from the underseats but it is very muddy compared to the new clarity you get from upgrading the mids and highs.
03-13-2014, 12:13 PM | #10 | |
Rep 5,120
http://www.jehnert.de/2011/09/28/bmw...unting-places/ http://unexpectedcreations.com |
03-15-2014, 11:20 PM | #11 |
Rep 15
I haven't really considered the jehnert 3 way kit but I'm pretty set on my jl set up. Im trying to look into it though. However one last question the jehnert underseats seem great but I'm wondering since I listen mostly to bass heavy music like rap and certain types of reggae if the sws earthquakes would be a better option (jehnerts would be great for the bass guitar of the reggae right?). I just really don't want a trunk sub so wondering which is the best compromise. I think I would happiest with the mid-bass specialist jehnerts bc I'm sure they still sound good with the music I listen too. (I do mix it up but I'd say %70 rap)
03-15-2014, 11:41 PM | #12 |
Rep 13,102
Based on what you said SWS would probably
Based on what you said SWS would probably more along the lines
of what you want if you don't want to a trunk sub and you like a lot of bass. Jehnerts are more about total accruacy and mid range. There is another alternative that has both but its super expensive. German Mastro and the underseat housing has to be modified to accept them. |
03-16-2014, 09:42 AM | #13 |
Rep 5,120
I like alot of bass and I actually think the jehnerts sound pretty good on there own without the subs and with only 75 watts each.
I wouldn't use the sws it's going to sound like crap and still won't compare to a good trunk sub. Just my opinion. |
focal, hifi, ifbmw-s, jl c5, technic |
